Hello, All,
- Why do I keep seeing this “errors” in the logs?
- What am I missing in my configuration?
- How do I get rid of
Management frame protection is required in 6 GHzandPre-RSNA security methods are not allowed in 6 GHzerrors?
Logs
$ logread -f -t
Fri Aug 14 23:18:50 2026 [1786745930.828] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:18:50 2026 [1786745930.832] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Fri Aug 14 23:18:52 2026 [1786745932.052] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:18:52 2026 [1786745932.493] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Fri Aug 14 23:18:54 2026 [1786745934.782] daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.5 c4:62:37:07:c3:43
Fri Aug 14 23:18:54 2026 [1786745934.782] daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.5 c4:62:37:07:c3:43 asus-zenbook-14-sfp
Fri Aug 14 23:18:56 2026 [1786745936.832] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:18:56 2026 [1786745936.837] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Fri Aug 14 23:18:58 2026 [1786745938.056] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:18:58 2026 [1786745938.496] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Fri Aug 14 23:19:02 2026 [1786745942.836] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:19:02 2026 [1786745942.840] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Fri Aug 14 23:19:04 2026 [1786745944.060] daemon.err hostapd: Management frame protection is required in 6 GHz
Fri Aug 14 23:19:04 2026 [1786745944.499] daemon.err hostapd: Pre-RSNA security methods are not allowed in 6 GHz
Configuration
root@OpenWrt:~# cat /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
option radio '0'
option band '2g'
option channel '1'
option htmode 'EHT40'
option country 'NL'
option disabled '0'
option noscan '1'
option rnr '1'
option tx_burst '0.0'
option cell_density '0'
config wifi-iface 'default_radio0_mld'
option device 'radio0'
option network 'lan'
option mode 'ap'
option mld_id '1'
option ieee80211w '1'
option encryption 'psk2'
option encryption_rsno 'sae'
config wifi-iface 'default_radio0'
option mode 'ap'
option ssid '12-Rochford-Close_E6-1QR_2G'
option encryption 'none'
option mbo '0'
config wifi-device 'radio1'
option radio '1'
option band '5g'
option channel '36'
option htmode 'EHT160'
option country 'NL'
option disabled '0'
option noscan '1'
option rnr '1'
option background_radar '1'
config wifi-iface 'default_radio1_mld'
option device 'radio1'
option mode 'ap'
option mld_id '1'
config wifi-iface 'default_radio1'
option mode 'ap'
option ssid '12-Rochford-Close_E6-1QR_5G'
option mbo '0'
config wifi-device 'radio2'
option radio '2'
option band '6g'
option channel '37'
option htmode 'EHT320'
option country 'NL'
option disabled '0'
option mbssid '1'
config wifi-iface 'default_radio2_mld'
option device 'radio2'
option mode 'ap'
option mld_id '1'
option ieee80211w '2'
option encryption 'sae'
config wifi-iface 'default_radio2'
option mode 'ap'
option ssid '12-Rochford-Close_E6-1QR_6G'
option mbo '1'
option key '1234567890'
option sae_pwe '2'
option ocv '0'
config wifi-mld 'ap_mld_1'
option ifname 'ap-mld-1'
option mld_id '1'
option ssid '12-Rochford-Close_E6-1QR'
option encryption_rsno_2 'sae-ext'
option sae_pwe '2'
root@OpenWrt:~# wifi status | jq '.'
"radio0": {
"up": true,
"pending": false,
"autostart": true,
"disabled": false,
"retry_setup_failed": false,
"config": {
"path": "soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0",
"radio": 0,
"band": "2g",
"channel": "1",
"htmode": "EHT40",
"country": "NL",
"noscan": true,
"rnr": 1,
"tx_burst": "0.0",
"cell_density": 0,
"disabled": false
"interfaces": [
"section": "default_radio0_mld",
"ifname": "ap-mld-1",
"config": {
"mode": "ap",
"mld_id": 1,
"ieee80211w": 1,
"encryption": "psk2",
"encryption_rsno": "sae",
"network": [
"lan"
"vlans": [],
"stations": []
"section": "default_radio0",
"ifname": "phy0.0-ap0",
"config": {
"mode": "ap",
"ssid": "12-Rochford-Close_E6-1QR_2G",
"encryption": "none",
"mbo": false,
"network": [
"lan"
"vlans": [],
"stations": []
"radio1": {
"up": true,
"pending": false,
"autostart": true,
"disabled": false,
"config": {
"radio": 1,
"band": "5g",
"channel": "36",
"htmode": "EHT160",
"country": "NL",
"noscan": true,
"rnr": 1,
"background_radar": true,
"tx_burst": "0.0",
"cell_density": 0,
"disabled": false
"interfaces": [
"section": "default_radio1_mld",
"config": {
"mode": "ap",
"mld_id": 1,
"ieee80211w": 1,
"network": [
"lan"
"vlans": [],
"stations": []
"section": "default_radio1",
"ifname": "phy0.1-ap0",
"config": {
"mode": "ap",
"ssid": "12-Rochford-Close_E6-1QR_5G",
"mbo": false,
"network": [
"lan"
"vlans": [],
"stations": []
"radio2": {
"up": true,
"pending": false,
"autostart": true,
"disabled": false,
"config": {
"radio": 2,
"band": "6g",
"channel": "37",
"htmode": "EHT320",
"country": "NL",
"mbssid": 1,
"tx_burst": "0.0",
"cell_density": 0,
"disabled": false
"interfaces": [
"section": "default_radio2_mld",
"config": {
"mode": "ap",
"mld_id": 1,
"ieee80211w": 2,
"encryption": "sae",
"network": [
"lan"
"vlans": [],
"stations": []
"section": "default_radio2",
"ifname": "phy0.2-ap0",
"config": {
"mode": "ap",
"ssid": "12-Rochford-Close_E6-1QR_6G",
"mbo": true,
"key": "1234567890",
"sae_pwe": 2,
"ieee80211w": 2,
"ocv": 0,
"network": [
"lan"
"vlans": [],
"stations": []
