How is the MAC address determined? I am using the official debian image 2021-06-21-debian-10-buster-bpi-m5-m2pro-aarch64-sd-emmc.img.zip, and the MAC address on mine seems locally generated with the U/L bit set:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.24 netmask 255.255.255.0 broadcast 192.168.2.255
ether 02:00:00:1c:0d:01 txqueuelen 1000 (Ethernet)
RX packets 789 bytes 128666 (125.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 72 bytes 12225 (11.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 21
When I tried to override it in boot.ini like:
setenv bootargs "root=${rootfsdev} rootwait ro fastboot noswap ${condev} ${splash} ${amlogic} no_console_suspend fsck.mode=force fsck.repair=yes board=${board} mac=**22:33:44:55:66:77** serial=${serial} net.ifnames=0 elevator=noop hdmimode=${hdmimode} cvbsmode=576cvbs max_freq_a55=${max_freq_a55} maxcpus=${maxcpus} voutmode=${voutmode} ${cmode} disablehpd=${disablehpd} cvbscable=${cvbscable} overscan=${overscan} ${hid_quirks} monitor_onoff=${monitor_onoff} logo=osd0,loaded ${cec_enable} sdrmode=${sdrmode}"
The MAC address is unchanged and still 02:00:00:1c:0d:01.
What is the proper way to set MAC address?
Thank you!
