Kernel crash, 6.19.0-rc1-bpi-r4, kernel BUG at lib/string_helpers.c:1043!
So i wanted to update the kernel to check if the SFP ports are working already. Because on 6.15 they were not. Bad luck. This is kernel 6.19.0-rc1 from @frank-w’s repo. Not sure how i will fix this. Because there is no rescue system. Or maybe i’ll boot from sd card?
[  OK  ] Started systemd-udevd.serv…nager for Device Events and Files.
[    5.788301] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[  OK  ] Found device dev-mmcblk0p5.device - /dev/mmcblk0p5.
[  OK  ] Found device dev-ttyS0.device - /dev/ttyS0.
[    6.328229] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.358672] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.364864] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    6.572057] mt7921e 0001:01:00.0: vgaarb: pci_notify
[    6.577056] mt7921e 0001:01:00.0: assign IRQ: got 124
[    6.582169] mt7921e 0001:01:00.0: enabling device (0000 -> 0002)
[    6.589860] mt7921e 0001:01:00.0: enabling bus mastering
[    6.595266] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[    6.613425] mt7921e 0001:01:00.0: ASIC revision: 79220010
[  OK  ] Listening on systemd-rfkil…l Switch Status /dev/rfkill Watch.
         Mounting boot.mount - /boot...
[    6.704685] mt7921e 0001:01:00.0: vgaarb: pci_notify
[    6.710820] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    6.712606] ------------[ cut here ]------------
[    6.725382] strnlen: detected buffer overflow: 17 byte read of buffer size 16
[    6.732539] WARNING: lib/string_helpers.c:1035 at __fortify_report+0x54/0x64, CPU#0: kworker/0:1/11
[    6.741591] Modules linked in: mt7921e mt7921_common mt792x_lib mt76_connac_lib mt76 mac80211 cfg80211 libarc4 fuse ip_tables x_tables
[    6.753686] CPU: 0 UID: 0 PID: 11 Comm: kworker/0:1 Not tainted 6.19.0-rc1-bpi-r4 #2 NONE
[    6.761941] Hardware name: Banana Pi BPI-R4 (2x SFP+) (DT)
[    6.767416] Workqueue: events mt7921_init_work [mt7921_common]
[    6.773250] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    6.780201] pc : __fortify_report+0x54/0x64
[    6.784376] lr : __fortify_report+0x54/0x64
[    6.788551] sp : ffffffc081c43bb0
[    6.791855] x29: ffffffc081c43bb0 x28: 0000000000000000 x27: 0000000000000000
[    6.798983] x26: ffffff80c00f5580 x25: ffffff80c9201ee8 x24: ffffff80c920fae8
[    6.806109] x23: 0000000000000002 x22: ffffffc0827b5000 x21: 0000000000001000
[    6.813236] x20: 0000000000000000 x19: ffffff80c9202060 x18: 00000000ffffffff
[    6.820362] x17: 3120657a69732072 x16: 656666756220666f x15: 2064616572206574
[    6.827487] x14: 00000000ffffffea x13: ffffffc081c43978 x12: ffffffc0818e9bc0
[    6.834613] x11: 0000000000000001 x10: 0000000000000001 x9 : 0000000000017fe8
[    6.841739] x8 : c0000000ffffefff x7 : ffffffc081891b48 x6 : 0000000000000001
[    6.848865] x5 : ffffff80ff74c688 x4 : 0000000000000000 x3 : 0000000000000001
[    6.855990] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff80c0179c80
[    6.863117] Call trace:
[    6.865554]  __fortify_report+0x54/0x64 (P)
[    6.869730]  __fortify_panic+0x10/0x14
[    6.873471]  mt76_connac_mcu_wtbl_generic_tlv+0x0/0x19c [mt76_connac_lib]
[    6.880251]  mt792x_load_firmware+0x48/0x18c [mt792x_lib]
[    6.885645]  mt7921_run_firmware+0x28/0x548 [mt7921_common]
[  OK      6.891211]  mt7921e_mcu_init+0x54/0x84 [mt7921e]
[    6.897287]  mt7921_init_work+0x80/0x250 [mt7921_common]
[    6.902590]  process_one_work+0x164/0x39c
[    6.906597]  worker_thread+0x278/0x464
[    6.910337]  kthread+0x114/0x1c8
[    6.913557]  ret_from_fork+0x10/0x20
[    6.917127] ---[ end trace 0000000000000000 ]---
0m] Mounted     6.921805] ------------[ cut here ]------------
[    6.927756] kernel BUG at lib/string_helpers.c:1043!
[    6.932713] Internal error: Oops - BUG: 00000000f2000800 [#1]  SMP
[    6.938882] Modules linked in: mt7921e mt7921_common mt792x_lib mt76_connac_lib mt76 mac80211 cfg80211 libarc4 fuse ip_tables x_tables
[    6.950974] CPU: 0 UID: 0 PID: 11 Comm: kworker/0:1 Tainted: G        W           6.19.0-rc1-bpi-r4 #2 NONE
[    6.960789] Tainted: [W]=WARN
[    6.963746] Hardware name: Banana Pi BPI-R4 (2x SFP+) (DT)
[    6.969220] Workqueue: events mt7921_init_work [mt7921_common]
[    6.975052] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    6.982002] pc : __fortify_panic+0x10/0x14
[    6.986093] lr : __fortify_panic+0x10/0x14
[    6.990179] sp : ffffffc081c43bc0
[    6.993483] x29: ffffffc081c43bc0 x28: 0000000000000000 x27: 0000000000000000
[    7.000610] x26: ffffff80c00f5580 x25: ffffff80c9201ee8 x24: ffffff80c920fae8
[    7.007736] x23: 0000000000000002 x22: ffffffc0827b5000 x21: 0000000000001000
[    7.014862] x20: 0000000000000000 x19: ffffff80c9202060 x18: 00000000ffffffff
[    7.021989] x17: 3120657a69732072 x16: 656666756220666f x15: 2064616572206574
[    7.029115] x14: 00000000ffffffea x13: ffffffc081c43978 x12: ffffffc0818e9bc0
[    7.036242] x11: 0000000000000001 x10: 0000000000000001 x9 : 0000000000017fe8
[    7.043367] x8 : c0000000ffffefff x7 : ffffffc081891b48 x6 : 0000000000000001
[    7.050493] x5 : ffffff80ff74c688 x4 : 0000000000000000 x3 : 0000000000000001
[    7.057619] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff80c0179c80
[    7.064746] Call trace:
[    7.067183]  __fortify_panic+0x10/0x14 (P)
[    7.071271]  mt76_connac_mcu_wtbl_generic_tlv+0x0/0x19c [mt76_connac_lib]
[    7.078053]  mt792x_load_firmware+0x48/0x18c [mt792x_lib]
[    7.083445]  mt7921_run_firmware+0x28/0x548 [mt7921_common]
[    7.089009]  mt7921e_mcu_init+0x54/0x84 [mt7921e]
[    7.093704]  mt7921_init_work+0x80/0x250 [mt7921_common]
[    7.099008]  process_one_work+0x164/0x39c
[    7.103011]  worker_thread+0x278/0x464
[    7.106751]  kthread+0x114/0x1c8
[    7.109972]  ret_from_fork+0x10/0x20
[    7.113544] Code: d503233f a9bf7bfd 910003fd 97ffffe4 (d4210000)
[    7.119626] ---[ end trace 0000000000000000 ]---
[    7.125766] pstore: backend (ramoops) writing error (-28)
[    7.131154] Kernel panic - not syncing: Oops - BUG: Fatal exception
[    7.137408] SMP: stopping secondary CPUs
1;39mboot.mount   7.141325] Kernel Offset: disabled
[    7.146179] CPU features: 0x000000,00810001,00008001,0400420b
[    7.151915] Memory Limit: none
[    7.156497] Rebooting in 10 seconds..
This crash seems to be related to mt7921 and not sfp. You should try 6.18-main instead of rc. Which sfp do you use? Maybe they are incompatible (moddef0-power issue)…
You need to check the file system on the mmcblk0p5 partition.
Yeah, related to mediatek. I fixed this by booting in NAND, which had OpenWRT installed, and fixing stuff from there. Booted the old kernel 6.15, worked as usuall. Then compiled 6.18 in another machine and installed it. Now the SFP ports work, no crashes and the mt7921 card works fine with hostapd.
With 6.15 the SFP ports (eth1 and 2) were not even showing up in ip a. So, not a SFP module problem. Had to use a RJ45 port.
@admin_ka Yeah, from all the kernel crashes and auto rebooting. Later i’ll do it. Now i’m hapy the router is finally working.
