full boot log @ericwoud
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 1041 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 380E 5012
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0600 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
MK: 0000 0000 [0000]
T0: 0000 013D [0101]
Jump to BL
NOTICE: BL2: v2.13.0(release):OpenWrt v2025.07.11~78a0dfd9-1 (mt7988-sdmmc-comb)
NOTICE: BL2: Built : 20:18:25, Oct 17 2025
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7988
NOTICE: EMI: Using DDR unknown settings
NOTICE: EMI: Detected DRAM size: 4096 MB
NOTICE: LVTS: Enable thermal HW reset
NOTICE: Located partition 'fip' at 0x680000, size 0x400000
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.13.0(release):OpenWrt v2025.07.11~78a0dfd9-1 (mt7988-sdmmc-comb)
NOTICE: BL31: Built : 20:18:25, Oct 17 2025
U-Boot 2025.10-OpenWrt-r0-0f724d7 (Oct 17 2025 - 20:18:25 +0000)
CPU: MediaTek MT7988
Model: Bananapi BPI-R4
DRAM: 4 GiB
Core: 64 devices, 24 uclasses, devicetree: embed
spi-nand: spi_nand spi_nand@0: CASN page check failed
spi-nand: spi_nand spi_nand@0: Fallback to read ID
spi-nand: spi_nand spi_nand@0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
MMC: mmc@11230000: 0
Loading Environment from MMC... Reading from redundant MMC(0)... OK
In: serial@11000000
Out: serial@11000000
Err: serial@11000000
reset button found
Net: MediaTek MT7988 built-in switch
eth0: ethernet@15110100
e[?25le[2Je[1;1He[1;1He[2Ke[2;3H e[0;34m( ( ( e[1;39mOpenWrte[0;34m ) ) ) e[0;36m[SD card]e[0m e[33mU-Boot 2025.10-OpenWrt-r0-0f724d7 (Oct 17 2025 - 20:18:25 +0000)e[0me[0Ke[3;1He[2Ke[15;1He[2Ke[16;3HPress UP/DOWN to move, ENTER to select, ESC to quite[0Ke[17;1He[2Ke[4;7He[7m1. Run default boot command.e[0me[5;7H2. Boot system via TFTP.e[6;7H3. Boot production system from SD card.e[7;7H4. Boot recovery system from SD card.e[8;7H5. Load production system via TFTP then write to SD card.e[9;7H6. Load recovery system via TFTP then write to SD card.e[10;7H7. e[31mInstall bootloader, recovery and production to NAND.e[0me[11;7H8. Reboot.e[12;7H9. Reset all settings to factory defaults.e[13;7H0. Exite[15;3HHit any key to stop autoboot: 3 e[15;3HHit any key to stop autoboot: 2 e[15;3HHit any key to stop autoboot: 1 e[15;1He[2Ke[?25he[2Je[1;1HMMC read: dev # 0, block # 131072, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 131072, count 36136 ... 36136 blocks read: OK
## Loading kernel (any) from FIT Image at 50000000 ...
Using 'config-mt7988a-bananapi-bpi-r4' configuration
Description: ARM64 OpenWrt Linux-6.12.51
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x50001000
Data Size: 6081802 Bytes = 5.8 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x46000000
Entry Point: 0x46000000
Hash algo: crc32
Hash value: c49d4fae
Hash algo: sha1
Hash value: 7e71654b7ca1b5be8bfc5216e37b9143fa0c83d6
## Loading fdt (any) from FIT Image at 50000000 ...
Trying 'fdt-1' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x505ce000
Data Size: 43784 Bytes = 42.8 KiB
Load Address: 0x45f00000
Hash algo: crc32
Hash value: 1ffe3ef6
Hash algo: sha1
Hash value: c6091c1c4aaef501949a290679aaa423738f540f
Loading fdt from 0x505ce000 to 0x45f00000
Loading Device Tree to 00000000fe7de000, end 00000000fe7ebfff ... OK
Working FDT set to fe7de000
Using 'mt7988a-bananapi-bpi-r4-sd' configuration
Trying 'fdt-mt7988a-bananapi-bpi-r4-sd' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd
Data Start: 0x505db000
Data Size: 1462 Bytes = 1.4 KiB
Hash algo: crc32
Hash value: dc3d838d
Hash algo: sha1
Hash value: 47c779b5fb7acc9baf4e57810ddca89a4bef2615
Could not find configuration node
load of <NULL> failed
Booting using the fdt blob at 0xfe7de000
## Loading loadables (any) from FIT Image at 50000000 ...
Trying 'rootfs-1' loadables subimage
Description: ARM64 OpenWrt bananapi_bpi-r4 rootfs
Type: Filesystem Image
Data Start: 0x505dc000
Data Size: 12357632 Bytes = 11.8 MiB
Hash algo: crc32
Hash value: ad55c826
Hash algo: sha1
Hash value: 896c461f34afbc567b78d6c1dbcb5f074c8970a6
Uncompressing Kernel Image to 46000000
Loading Device Tree to 00000000fe7d1000, end 00000000fe7ddd92 ... OK
Working FDT set to fe7d1000
set /chosen/rootdisk to bootrom media: rootdisk-sd (phandle 0x0000009c)
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.12.51 (runner@runnervmzdgdc) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 14.3.0 r0-0f724d7) 14.3.0, GNU ld (GNU Binutils) 2.44) #0 SMP Fri Oct 17 20:18:25 2025
[ 0.000000] Machine model: Banana Pi BPI-R4 (2x SFP+)
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[ 0.000000] OF: reserved mem: 0x0000000047cc0000..0x0000000047dbffff (1024 KiB) nomap non-reusable wmcpu-reserved@47cc0000
[ 0.000000] OF: reserved mem: 0x000000004f600000..0x000000004f63ffff (256 KiB) nomap non-reusable wo-emi@4f600000
[ 0.000000] OF: reserved mem: 0x000000004f640000..0x000000004f67ffff (256 KiB) nomap non-reusable wo-emi@4f640000
[ 0.000000] OF: reserved mem: 0x000000004f680000..0x000000004f6bffff (256 KiB) nomap non-reusable wo-emi@4f680000
[ 0.000000] OF: reserved mem: 0x000000004f700000..0x000000004fefffff (8192 KiB) nomap non-reusable wo-data@4f700000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x0000000047cbffff]
[ 0.000000] node 0: [mem 0x0000000047cc0000-0x0000000047dbffff]
[ 0.000000] node 0: [mem 0x0000000047dc0000-0x000000004f5fffff]
[ 0.000000] node 0: [mem 0x000000004f600000-0x000000004f6bffff]
[ 0.000000] node 0: [mem 0x000000004f6c0000-0x000000004f6fffff]
[ 0.000000] node 0: [mem 0x000000004f700000-0x000000004fefffff]
[ 0.000000] node 0: [mem 0x000000004ff00000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 20 pages/cpu s42520 r8192 d31208 u81920
[ 0.000000] pcpu-alloc: s42520 r8192 d31208 u81920 alloc=20*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048576
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7d1000-0x00000000fe7d1000] (64MB)
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=0
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000065] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000071] pid_max: default: 32768 minimum: 301
[ 0.002143] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002157] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003654] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.004112] rcu: Hierarchical SRCU implementation.
[ 0.004114] rcu: Max phase no-delay instances is 1000.
[ 0.004204] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.004373] smp: Bringing up secondary CPUs ...
[ 0.004588] Detected VIPT I-cache on CPU1
[ 0.004627] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.004647] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.004917] Detected VIPT I-cache on CPU2
[ 0.004937] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.004948] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.005181] Detected VIPT I-cache on CPU3
[ 0.005202] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.005212] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.005247] smp: Brought up 1 node, 4 CPUs
[ 0.005251] SMP: Total of 4 processors activated.
[ 0.005253] CPU: All CPU(s) started at EL2
[ 0.005255] CPU features: detected: 32-bit EL0 Support
[ 0.005258] CPU features: detected: CRC32 instructions
[ 0.005285] alternatives: applying system-wide alternatives
[ 0.005363] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005467] Memory: 4019728K/4194304K available (9216K kernel code, 976K rwdata, 2740K rodata, 448K init, 300K bss, 171012K reserved, 0K cma-reserved)
[ 0.008381] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008392] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.008441] 29296 pages in range for non-PLT usage
[ 0.008443] 520816 pages in range for PLT usage
[ 0.009545] pinctrl core: initialized pinctrl subsystem
[ 0.010454] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.010754] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.010857] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.010952] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.011231] thermal_sys: Registered thermal governor 'fair_share'
[ 0.011234] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.011235] thermal_sys: Registered thermal governor 'step_wise'
[ 0.011237] thermal_sys: Registered thermal governor 'user_space'
[ 0.011279] ASID allocator initialised with 65536 entries
[ 0.011786] pstore: Using crash dump compression: deflate
[ 0.011793] printk: legacy console [ramoops-1] enabled
[ 0.012049] pstore: Registered ramoops as persistent store backend
[ 0.012053] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.013929] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[ 0.017286] /soc/pcie@11280000: Fixed dependency cycle(s) with /soc/pcie@11280000/interrupt-controller
[ 0.017389] /soc/pcie@11290000: Fixed dependency cycle(s) with /soc/pcie@11290000/interrupt-controller
[ 0.017494] /soc/pcie@11300000: Fixed dependency cycle(s) with /soc/pcie@11300000/interrupt-controller
[ 0.017590] /soc/pcie@11310000: Fixed dependency cycle(s) with /soc/pcie@11310000/interrupt-controller
[ 0.027529] cryptd: max_cpu_qlen set to 1000
[ 0.029229] SCSI subsystem initialized
[ 0.029316] libata version 3.00 loaded.
[ 0.030341] clocksource: Switched to clocksource arch_sys_counter
[ 0.032028] NET: Registered PF_INET protocol family
[ 0.032164] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.034456] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.034480] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.034490] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.034600] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.035059] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.035368] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.035484] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.035534] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.035733] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.035772] PCI: CLS 0 bytes, default 64
[ 0.036631] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.040430] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.040437] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.072343] mtk-xsphy soc:xs-phy@11e10000: failed to get ref_clk(id-1)
[ 0.072923] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.072939] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.072952] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.072966] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.073070] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.073082] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.073093] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.073104] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.073123] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.073132] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.073196] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.073206] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.073216] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.073226] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.073244] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.073252] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.073328] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.073337] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.073348] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.073358] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.073375] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.073383] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.077679] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.078403] printk: legacy console [ttyS0] disabled
[ 0.098660] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.098697] printk: legacy console [ttyS0] enabled
[ 1.139626] random: crng init done
[ 1.144781] loop: module loaded
[ 1.149302] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.154639] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 1.162948] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.169307] OF: Bad cell count for /soc/spi@11007000/flash@0/partitions
[ 1.175923] OF: Bad cell count for /soc/spi@11007000/flash@0/partitions
[ 1.182659] Creating 2 MTD partitions on "spi0.0":
[ 1.187441] 0x000000000000-0x000000200000 : "bl2"
[ 1.193485] 0x000000200000-0x000008000000 : "ubi"
[ 1.268046] ubi0: default fastmap pool size: 50
[ 1.272579] ubi0: default fastmap WL pool size: 25
[ 1.277360] ubi0: attaching mtd1
[ 1.754478] ubi0: scanning is finished
[ 1.762800] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 1.768282] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.775151] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.781930] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.788878] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 1.794961] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 1.802172] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 660246019
[ 1.811206] ubi0: available PEBs: 0, total reserved PEBs: 1008, PEBs reserved for bad PEB handling: 20
[ 1.820507] ubi0: background thread "ubi_bgt0d" started, PID 210
[ 1.941818] i2c_dev: i2c /dev entries driver
[ 1.946518] /soc/i2c@11003000/rt5190a@64: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
[ 1.958270] mtk-lvts-thermal 1100a000.lvts: golden temp=60
[ 1.965197] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.973677] mtk-msdc 11230000.mmc: Got CD GPIO
[ 1.973824] NET: Registered PF_INET6 protocol family
[ 1.983541] Segment Routing with IPv6
[ 1.987212] In-situ OAM (IOAM) with IPv6
[ 1.991180] NET: Registered PF_PACKET protocol family
[ 1.996287] 8021q: 802.1Q VLAN Support v1.8
[ 2.004527] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=52 arg=00000C00; host->error=0x00000002
[ 2.014130] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=52 arg=80000C08; host->error=0x00000002
[ 2.031163] phy phy-soc:[email protected]: type_sw - reg 0x194, index 0
[ 2.038274] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=5 arg=00000000; host->error=0x00000002
[ 2.047584] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.054946] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=5 arg=00000000; host->error=0x00000002
[ 2.064034] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=5 arg=00000000; host->error=0x00000002
[ 2.073101] mtk-msdc 11230000.mmc: msdc_track_cmd_data: cmd=5 arg=00000000; host->error=0x00000002
[ 2.082134] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.088407] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.096850] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.127898] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.137932] mmc0: new high speed SDHC card at address 0001
[ 2.143959] mmcblk0: mmc0:0001 00000 7.38 GiB
[ 2.157744] Alternate GPT is invalid, using primary GPT.
[ 2.163122] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.420350] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.429147] mtk-pcie-gen3 11280000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[ 2.438162] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.445477] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.451747] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.460178] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 2.699241] mtk-pcie-gen3 11290000.pcie: set IO trans window[0]: cpu_addr = 0x28000000, pci_addr = 0x28000000, size = 0x200000
[ 2.710625] mtk-pcie-gen3 11290000.pcie: set MEM trans window[1]: cpu_addr = 0x28200000, pci_addr = 0x28200000, size = 0x200000
[ 2.722091] mtk-pcie-gen3 11290000.pcie: set MEM trans window[2]: cpu_addr = 0x28400000, pci_addr = 0x28400000, size = 0x400000
[ 2.733556] mtk-pcie-gen3 11290000.pcie: set MEM trans window[3]: cpu_addr = 0x28800000, pci_addr = 0x28800000, size = 0x800000
[ 2.745020] mtk-pcie-gen3 11290000.pcie: set MEM trans window[4]: cpu_addr = 0x29000000, pci_addr = 0x29000000, size = 0x1000000
[ 2.756570] mtk-pcie-gen3 11290000.pcie: set MEM trans window[5]: cpu_addr = 0x2a000000, pci_addr = 0x2a000000, size = 0x2000000
[ 2.768120] mtk-pcie-gen3 11290000.pcie: set MEM trans window[6]: cpu_addr = 0x2c000000, pci_addr = 0x2c000000, size = 0x4000000
[ 2.779920] mtk-pcie-gen3 11290000.pcie: PCI host bridge to bus 0002:00
[ 2.786533] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 2.792014] pci_bus 0002:00: root bus resource [io 0x200000-0x3fffff] (bus address [0x28000000-0x281fffff])
[ 2.801831] pci_bus 0002:00: root bus resource [mem 0x28200000-0x2fffffff]
[ 2.808694] pci_bus 0002:00: scanning bus
[ 2.812723] pci 0002:00:00.0: [14c3:7988] type 01 class 0x060400 PCIe Root Port
[ 2.820033] pci 0002:00:00.0: BAR 0 [mem 0x00000000-0x00007fff 64bit]
[ 2.826471] pci 0002:00:00.0: PCI bridge to [bus 00]
[ 2.831430] pci 0002:00:00.0: bridge window [io 0x0000-0x0fff]
[ 2.837514] pci 0002:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 2.844299] pci 0002:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 2.852085] pci 0002:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.858169] pci 0002:00:00.0: PME# disabled
[ 2.863438] pci_bus 0002:00: fixups for bus
[ 2.867613] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 2.874306] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.882304] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 2.889041] pci_bus 0002:01: scanning bus
[ 2.893069] pci 0002:01:00.0: [144d:a802] type 00 class 0x010802 PCIe Endpoint
[ 2.900300] pci 0002:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[ 2.906739] pci 0002:01:00.0: BAR 2 [io 0x0000-0x00ff]
[ 2.912117] pci 0002:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0002:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 2.940375] pci_bus 0002:01: fixups for bus
[ 2.944548] pci_bus 0002:01: bus scan returning with max=01
[ 2.950110] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.956721] pci_bus 0002:00: bus scan returning with max=01
[ 2.962299] pci 0002:00:00.0: bridge window [mem 0x28200000-0x282fffff]: assigned
[ 2.969771] pci 0002:00:00.0: BAR 0 [mem 0x28300000-0x28307fff 64bit]: assigned
[ 2.977077] pci 0002:00:00.0: bridge window [io 0x200000-0x200fff]: assigned
[ 2.984203] pci 0002:01:00.0: BAR 0 [mem 0x28200000-0x28203fff 64bit]: assigned
[ 2.991511] pci 0002:01:00.0: BAR 2 [io 0x200000-0x2000ff]: assigned
[ 2.997942] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 3.002899] pci 0002:00:00.0: bridge window [io 0x200000-0x200fff]
[ 3.009329] pci 0002:00:00.0: bridge window [mem 0x28200000-0x282fffff]
[ 3.016112] pci_bus 0002:00: resource 4 [io 0x200000-0x3fffff]
[ 3.022022] pci_bus 0002:00: resource 5 [mem 0x28200000-0x2fffffff]
[ 3.028277] pci_bus 0002:01: resource 0 [io 0x200000-0x200fff]
[ 3.034191] pci_bus 0002:01: resource 1 [mem 0x28200000-0x282fffff]
[ 3.040457] pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.048895] pci 0002:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 3.057406] pcieport 0002:00:00.0: assign IRQ: got 114
[ 3.062546] pcieport 0002:00:00.0: enabling device (0000 -> 0003)
[ 3.068636] pcieport 0002:00:00.0: enabling bus mastering
[ 3.074374] mtk-pcie-gen3 11290000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11290c00 data 0
[ 3.082812] mtk-pcie-gen3 11290000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11290c00 data 1
[ 3.091240] mtk-pcie-gen3 11290000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11290c00 data 2
[ 3.099665] mtk-pcie-gen3 11290000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11290c00 data 3
[ 3.108092] mtk-pcie-gen3 11290000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11290c00 data 4
[ 3.116519] mtk-pcie-gen3 11290000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11290c00 data 5
[ 3.124945] mtk-pcie-gen3 11290000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11290c00 data 6
[ 3.133372] mtk-pcie-gen3 11290000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11290c00 data 7
[ 3.141798] mtk-pcie-gen3 11290000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11290c00 data 8
[ 3.150222] mtk-pcie-gen3 11290000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11290c00 data 9
[ 3.158648] mtk-pcie-gen3 11290000.pcie: msi#0xa address_hi 0x0 address_lo 0x11290c00 data 10
[ 3.167162] mtk-pcie-gen3 11290000.pcie: msi#0xb address_hi 0x0 address_lo 0x11290c00 data 11
[ 3.175675] mtk-pcie-gen3 11290000.pcie: msi#0xc address_hi 0x0 address_lo 0x11290c00 data 12
[ 3.184191] mtk-pcie-gen3 11290000.pcie: msi#0xd address_hi 0x0 address_lo 0x11290c00 data 13
[ 3.192710] mtk-pcie-gen3 11290000.pcie: msi#0xe address_hi 0x0 address_lo 0x11290c00 data 14
[ 3.201223] mtk-pcie-gen3 11290000.pcie: msi#0xf address_hi 0x0 address_lo 0x11290c00 data 15
[ 3.209734] mtk-pcie-gen3 11290000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11290c00 data 16
[ 3.218334] mtk-pcie-gen3 11290000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11290c00 data 17
[ 3.226935] mtk-pcie-gen3 11290000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11290c00 data 18
[ 3.235535] mtk-pcie-gen3 11290000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11290c00 data 19
[ 3.244136] mtk-pcie-gen3 11290000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11290c00 data 20
[ 3.252736] mtk-pcie-gen3 11290000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11290c00 data 21
[ 3.261337] mtk-pcie-gen3 11290000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11290c00 data 22
[ 3.269934] mtk-pcie-gen3 11290000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11290c00 data 23
[ 3.278535] mtk-pcie-gen3 11290000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11290c00 data 24
[ 3.287135] mtk-pcie-gen3 11290000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11290c00 data 25
[ 3.295735] mtk-pcie-gen3 11290000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11290c00 data 26
[ 3.304338] mtk-pcie-gen3 11290000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11290c00 data 27
[ 3.312937] mtk-pcie-gen3 11290000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11290c00 data 28
[ 3.321537] mtk-pcie-gen3 11290000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11290c00 data 29
[ 3.330135] mtk-pcie-gen3 11290000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11290c00 data 30
[ 3.338734] mtk-pcie-gen3 11290000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11290c00 data 31
[ 3.347734] mtk-pcie-gen3 11290000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11290c00 data 0
[ 3.356235] pcieport 0002:00:00.0: PME: Signaling with IRQ 115
[ 3.362178] pcieport 0002:00:00.0: AER: enabled with IRQ 115
[ 3.367877] pcieport 0002:00:00.0: save config 0x00: 0x798814c3
[ 3.373798] pcieport 0002:00:00.0: save config 0x04: 0x00100407
[ 3.379707] pcieport 0002:00:00.0: save config 0x08: 0x06040001
[ 3.385619] pcieport 0002:00:00.0: save config 0x0c: 0x00010000
[ 3.391530] pcieport 0002:00:00.0: save config 0x10: 0x28300004
[ 3.397438] pcieport 0002:00:00.0: save config 0x14: 0x00000000
[ 3.403349] pcieport 0002:00:00.0: save config 0x18: 0x00010100
[ 3.409257] pcieport 0002:00:00.0: save config 0x1c: 0x00000101
[ 3.415168] pcieport 0002:00:00.0: save config 0x20: 0x28202820
[ 3.421080] pcieport 0002:00:00.0: save config 0x24: 0x0001fff1
[ 3.426989] pcieport 0002:00:00.0: save config 0x28: 0x00000000
[ 3.432899] pcieport 0002:00:00.0: save config 0x2c: 0x00000000
[ 3.438806] pcieport 0002:00:00.0: save config 0x30: 0x28002800
[ 3.444716] pcieport 0002:00:00.0: save config 0x34: 0x00000080
[ 3.450627] pcieport 0002:00:00.0: save config 0x38: 0x00000000
[ 3.456535] pcieport 0002:00:00.0: save config 0x3c: 0x00020172
[ 3.462705] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.470009] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.476277] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.484711] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.810361] mtk-pcie-gen3 11300000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.819144] mtk-pcie-gen3 11300000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[ 3.828054] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 3.835365] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 3.841630] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 3.850060] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 4.170348] mtk-pcie-gen3 11310000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 4.179127] mtk-pcie-gen3 11310000.pcie: probe with driver mtk-pcie-gen3 failed with error -110
[ 4.189427] FIT: Detected U-Boot 2025.10-OpenWrt-r0-0f724d7
[ 4.194998] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 4.204042] FIT: kernel sub-image 0x00001000..0x005cdd09 "kernel-1" (ARM64 OpenWrt Linux-6.12.51)
[ 4.213868] FIT: flat_dt sub-image 0x005ce000..0x005d8b07 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[ 4.225080] FIT: flat_dt sub-image 0x005d9000..0x005d95fd "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 4.241413] FIT: flat_dt sub-image 0x005da000..0x005da11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 4.257570] FIT: flat_dt sub-image 0x005db000..0x005db5b5 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 4.273555] FIT: filesystem sub-image 0x005dc000..0x011a4fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[ 4.284364] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 4.292085] block mmcblk0p7: mapped remaining space as /dev/fitrw
[ 4.411786] mtk_soc_eth 15100000.ethernet: generated random MAC address 20:08:02:00:00:00
[ 4.424975] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082500000, irq 105
[ 4.434616] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082500000, irq 105
[ 4.444245] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082500000, irq 105
[ 4.542913] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 4.550423] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 4.577543] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=117)
[ 4.616268] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=118)
[ 4.655067] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=119)
[ 4.693639] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=120)
[ 4.704595] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 4.711305] DSA: tree 0 setup
[ 4.714539] clk: Disabling unused clocks
[ 4.718880] PM: genpd: Disabling unused power domains
[ 4.739418] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 4.746657] Freeing unused kernel memory: 448K
[ 4.751132] Run /sbin/init as init process
[ 4.755218] with arguments:
[ 4.758174] /sbin/init
[ 4.760876] with environment:
[ 4.764006] HOME=/
[ 4.766355] TERM=linux
[ 4.938538] init: Console is alive
[ 4.942061] init: - watchdog -
[ 5.241989] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.258443] usbcore: registered new interface driver usbfs
[ 5.263980] usbcore: registered new interface driver hub
[ 5.269310] usbcore: registered new device driver usb
[ 5.274895] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 5.285015] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 5.292439] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 5.300356] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.305584] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 5.316037] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 5.325195] xhci-mtk 11200000.usb: irq 121, io mem 0x11200000
[ 5.331014] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.336231] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 5.343620] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 5.350902] hub 1-0:1.0: USB hub found
[ 5.354654] hub 1-0:1.0: 1 port detected
[ 5.358724] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.366965] hub 2-0:1.0: USB hub found
[ 5.370722] hub 2-0:1.0: 1 port detected
[ 5.377425] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.388407] init: - preinit -
[ 5.605927] mtk_soc_eth 15100000.ethernet sfp-lan: renamed from eth1
[ 5.613972] mtk_soc_eth 15100000.ethernet sfp-wan: renamed from eth2
[ 5.632115] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 5.640279] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 5.650066] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 5.800381] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 5.953031] hub 1-1:1.0: USB hub found
[ 5.956988] hub 1-1:1.0: 5 ports detected
[ 6.082744] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 6.103003] hub 2-1:1.0: USB hub found
[ 6.106985] hub 2-1:1.0: 4 ports detected
[ 6.680343] usb 1-1.2: new full-speed USB device number 3 using xhci-mtk
[ 6.910343] usb 1-1.5: new high-speed USB device number 4 using xhci-mtk
[ 10.200364] F2FS-fs (fitrw): Mounted with checkpoint version = 3999c50a
[ 10.209701] mount_root: switching to f2fs overlay
[ 10.217385] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 10.229900] urandom-seed: Seeding with /etc/urandom.seed
[ 10.273815] procd: - early -
[ 10.276752] procd: - watchdog -
[ 10.822768] procd: - watchdog -
[ 10.831310] procd: - ubus -
[ 10.899608] procd: - init -
[ 11.142373] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.161412] pca954x 1-0070: supply vdd not found, using dummy regulator
[ 11.168620] i2c i2c-1: Added multiplexed i2c bus 2
[ 11.173544] i2c i2c-1: Added multiplexed i2c bus 3
[ 11.178386] i2c i2c-1: Added multiplexed i2c bus 4
[ 11.183258] i2c i2c-1: Added multiplexed i2c bus 5
[ 11.188042] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[ 11.198887] crypto-safexcel 15600000.crypto: EIP197:331(7,1,8,4)-HIA:272(2,5,5),PE:151/450(alg:7fe1fc00)/240/240/450
[ 11.199653] urngd: v1.0.2 started.
[ 11.210498] crypto-safexcel 15600000.crypto: TRC init: 8704d,48a (32r,128h)
[ 11.338806] at24 2-0057: supply vcc not found, using dummy regulator
[ 11.346094] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 11.353216] Loading modules backported from Linux version v6.16-0-g038d61fd6422
[ 11.360535] Backport generated by backports.git v6.1.145-1-47-g6194bf852a3e
[ 11.372813] rtc-pcf8563 2-0051: registered as rtc0
[ 11.378815] rtc-pcf8563 2-0051: setting system clock to 2025-10-18T08:39:56 UTC (1760776796)
[ 11.389222] sfp sfp1: Host maximum power 3.0W
[ 11.394170] sfp sfp2: Host maximum power 3.0W
[ 11.427882] PPP generic driver version 2.4.2
[ 11.432722] NET: Registered PF_PPPOX protocol family
[ 11.439337] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.219655] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 13.253487] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 13.261654] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 13.263835] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 13.279126] br-lan: port 1(lan1) entered blocking state
[ 13.284397] br-lan: port 1(lan1) entered disabled state
[ 13.289651] mt7530-mmio 15020000.switch lan1: entered allmulticast mode
[ 13.296317] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[ 13.303370] mt7530-mmio 15020000.switch lan1: entered promiscuous mode
[ 13.318785] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 13.327250] br-lan: port 2(lan2) entered blocking state
[ 13.332534] br-lan: port 2(lan2) entered disabled state
[ 13.337781] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[ 13.344683] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[ 13.355032] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 13.364456] br-lan: port 3(lan3) entered blocking state
[ 13.369699] br-lan: port 3(lan3) entered disabled state
[ 13.375024] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[ 13.382052] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[ 13.391255] mtk_soc_eth 15100000.ethernet sfp-lan: configuring for inband/10gbase-r link mode
[ 13.424395] br-lan: port 4(sfp-lan) entered blocking state
[ 13.429897] br-lan: port 4(sfp-lan) entered disabled state
[ 13.435461] mtk_soc_eth 15100000.ethernet sfp-lan: entered allmulticast mode
[ 13.442777] mtk_soc_eth 15100000.ethernet sfp-lan: entered promiscuous mode
[ 13.452756] mtk_soc_eth 15100000.ethernet sfp-wan: configuring for inband/10gbase-r link mode
[ 13.485321] br-wan: port 1(sfp-wan) entered blocking state
[ 13.490861] br-wan: port 1(sfp-wan) entered disabled state
[ 13.496384] mtk_soc_eth 15100000.ethernet sfp-wan: entered allmulticast mode
[ 13.504066] mtk_soc_eth 15100000.ethernet sfp-wan: entered promiscuous mode
[ 13.516485] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 13.524938] br-wan: port 2(wan) entered blocking state
[ 13.530092] br-wan: port 2(wan) entered disabled state
[ 13.535286] mt7530-mmio 15020000.switch wan: entered allmulticast mode
[ 13.542007] mt7530-mmio 15020000.switch wan: entered promiscuous mode
[ 17.304888] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 17.305503] br-wan: port 2(wan) entered blocking state
[ 17.318207] br-wan: port 2(wan) entered forwarding state
