Issues Activating Wi-Fi 6 (802.11ax) and Bluetooth on BPI-M7
  1. Issues
  • BPI-M7 is running on compiled iStoreOS22 and 24 firmware.
  • LuCI only enables 802.11bg, and 802.11ax (Wi-Fi 6) activation is unsuccessful.
  • Despite compiling and running hostapd, even 802.11ac fails to load properly.
  • BlueZ was compiled, but the Bluetooth driver does not activate, possibly due to unsupported drivers.
  1. Questions
  • I am using a 5V 2A USB to C adapter. Is it related to the power?
  • How to enable 802.11ax?
  • How to resolve hostapd issues?
  • Any solutions to activate the Bluetooth driver?
  1. Firmware Logs [ 616.974177] [dhd-pcie] dhd_bus_download_firmware: firmware path=/lib/firmware/rkwifi/fw_bcmdhd.bin, nvram path=/lib/firmware/rkwifi/nvram.txt [ 616.974247] [dhd-pcie] dhd_conf_set_path_params : Final fw_path=/lib/firmware/rkwifi/fw_bcm43752a2_pcie_ag.bin [ 616.974257] [dhd-pcie] dhd_conf_set_path_params : Final nv_path=/lib/firmware/rkwifi/nvram_AP6275P.txt [ 616.974267] [dhd-pcie] dhd_conf_set_path_params : Final clm_path=/lib/firmware/rkwifi/clm_bcm43752a2_pcie_ag.blob [ 616.974277] [dhd-pcie] dhd_conf_set_path_params : Final conf_path=/lib/firmware/rkwifi/config_bcm43752a2_pcie_ag.txt [ 616.974334] [dhd-pcie] dhd_os_open_image1: /lib/firmware/rkwifi/config_bcm43752a2_pcie_ag.txt (336 bytes) open success [ 616.974725] [dhd-pcie] dhdpcie_download_code_file: download firmware /lib/firmware/rkwifi/fw_bcm43752a2_pcie_ag.bin [ 616.974765] [dhd-pcie] dhd_os_open_image1: /lib/firmware/rkwifi/fw_bcm43752a2_pcie_ag.bin (936074 bytes) open success [ 617.070192] [dhd-pcie] dhd_os_open_image1: /lib/firmware/rkwifi/nvram_AP6275P.txt (7458 bytes) open success [ 617.198072] [dhd-pcie] dhd_legacy_preinit_ioctls: use firmware generated mac_address 54:78:c9:29:4b:52 [ 617.198093] [dhd-pcie] dhd_os_open_image1: /lib/firmware/rkwifi/clm_bcm43752a2_pcie_ag.blob (30993 bytes) open success [ 617.257775] [dhd-pcie] Firmware up: op_mode=0x0005, MAC=54:78:c9:29:4b:52 [ 617.304515] [dhd-pcie] Firmware: wl0: Jul 12 2022 18:54:54 version 18.35.387.23.146 (g412cc5ec) FWID 01-93c53be6
