Is 20V voltage acceptable on BE14 WiFi?
I purchased the device with a PD20V power supply. Unfortunately, I couldn’t get the included WiFi7 BE14 to work. The board specifies that SW4 enables 12V for the mPCIe slots, and it does. However, the WiFi card is receiving 20V, the same as the power supply, not 12V as the board specifies. Could this have damaged the BE14 module?
Hi, although the power supply of the BE14 is listed as 12V, it is the same as the BPI-R4 and can use 20V power supply without any problems (the BE14 can actually be powered up to 24V).
