Irradium (based on crux linux) SpacemiT Banana Pi BPI-SM10 K3 riscv64
irradium - source based Linux distribution CRUX adhering to ideology keep it simple, has its own package system, also supports the port system.
irradium development or
packages aarch64
packages riscv64
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
U-Boot SPL 2022.10-k3 (May 31 2026 - 14:34:11 +0000)
DDR Part Number: MT62F4G32D8DV, Size: 16384MB, Data Rate: 6400MT/s
DDR training consume 5602ms
[   6.624]
U-Boot 2022.10-k3 (May 31 2026 - 14:34:11 +0000)
[   6.627] CPU:   rv64imafdcvh
[   6.630] Model: spacemit k3 com260 ifx board
[   6.634] DRAM:  32 GiB
[   6.669] reset driver probe finish
[   6.859] eSPI not ready, skipping EC probe
[   6.863] Core:  626 devices, 35 uclasses, devicetree: board
[   6.867] WDT:   Started watchdog@d4014000 with servicing (60s timeout)
[   6.872] MMC:   spacemit_sdhci sdh@d4280000: probe done.
[   6.879] sdh@d4280000: 0
[   6.882] Loading Environment from MMC... spacemit_sdhci sdh@d4280000: set tx_delaycode: 31
[   7.180] spacemit_sdhci sdh@d4280000: pass window [3 166)
[   7.200] spacemit_sdhci sdh@d4280000: pass window [170 183)
[   7.276] spacemit_sdhci sdh@d4280000: pass window [230 255]
[   7.279] spacemit_sdhci sdh@d4280000: tuning done, use delay_code:84
[   7.776] *** Warning - bad CRC, using default environment
[   7.796] Cannot find partition: bootfs
[   7.797] Failed to get partition index for bootfs
[   7.802] In:    serial
[   7.804] Out:   serial
[   7.806] Err:   serial
[   7.810] CTF2301: Start probing ctf2301@4c
[   7.817] Found device 'mipi@d421a800', disp_uc_priv=00000003fbe9b310
[   7.820] spacemit_panel_of_to_plat panel lcd_tc358762xbg_dpi_800x480
[   7.841] pll_ctrl_reg0 = 0x3A155555
[   7.841] pll_ctrl_reg1 = 0x4582820B
[   7.845] Panel is lcd_tc358762xbg_dpi
[   7.849] fb=3fe000000, size=800x480
[   7.853] dpi_panel_probe: Warning: cannot get enable GPIO: ret=-2
[   7.968] dpi_panel_probe: Atmel I2C read failed: 0
[   7.970] panel device error -1
[   7.975] Found device 'dp1@cac88000', disp_uc_priv=00000003fbe9b250
[   8.136] dp cannot get HPD signal
[   8.136] spacemit_display_init: device 'dpu@c0340000' display won't probe (ret=-1)
[   8.300] dp cannot get HPD signal
[   8.301] display devices not found or not probed yet: -1
[   8.366] Found 4 valid MAC addresses.
[   8.367] TLV item: product_name = k3_com260_ifx
[   8.371] TLV item: serial# = COM3K3321280022
[   8.376] TLV item: ddr_partnumber = MT62F4G32D8DV
[   8.380] save DDR training info
[   8.387] k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26000000Hz
[   8.394] k1x_qspi spi@d420c000: rx buf size:128, tx buf size:256, ahb buf size=512
[   8.401] k1x_qspi spi@d420c000: AHB read enabled
[   8.406] k1x_qspi spi@d420c000: AHB buf size: 512
[   8.411] k1x_qspi spi@d420c000: Speed Change: 26000000 Hz -> 26500000 Hz
[   8.417] SF: Detected gd25lq64c with page size 256 Bytes, erase size 4 KiB, total 8 MiB
write 38912byte to spinor @offset 65536
[   8.819] spacemit reboot: read PMIC reg 0xab value 0xf0
[   8.840] NO partition bootfs in card
[   8.841] SRAM cleared: addr=0xc0800000 size=0x80000
[   9.281] Autoboot in 0 seconds
[   9.291] Try to boot from mmc 0:2 ...
[   9.333] irradium boot from mmc 0:2
[   9.384] irradium boot partition UUID=32539e08-a5c0-4084-9f32-0932043d95e3
[   9.388] product_name: k3_com260_ifx
[   9.392] match dtb by product_name: dtb/spacemit/k3_com260_ifx.dtb
[   9.398] select dtb/spacemit/k3_com260_ifx.dtb to load
[   9.403] Loading kernel...
[   9.798] 33802752 bytes read in 360 ms (89.5 MiB/s)
[   9.799] Loading dtb...
[   9.841] 143639 bytes read in 22 ms (6.2 MiB/s)
[   9.842] Loading ramdisk ...
[  10.487] 59302878 bytes read in 625 ms (90.5 MiB/s)
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
[  10.519] Moving Image from 0x140000000 to 0x102200000, end=1042c7000
[  10.531] ## Flattened Device Tree blob at 138000000
[  10.533]    Booting using the fdt blob at 0x138000000
[  10.538]    Loading Ramdisk to 3f84e2000, end 3fbd703de ... OK
[  10.639]    Loading Device Tree to 00000003f84bb000, end 00000003f84e1116 ... OK
Starting kernel ...
[    0.000000] Booting Linux on hartid 0
[    0.000000] Linux version 6.18.3 (root@irradium) (riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT_DYNAMIC Sat May 30 16:58:58 UTC 2026
[    0.000000] random: crng init done
[    0.000000] Machine model: SpacemiT K3 Com260 IFX
[    0.000000] SBI specification v2.0 detected
[    0.000000] SBI implementation ID=0x1 Version=0x10006
[    0.000000] SBI TIME extension detected
[    0.000000] SBI IPI extension detected
[    0.000000] SBI RFENCE extension detected
[    0.000000] SBI SRST extension detected
[    0.000000] SBI DBCN extension detected
[    0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[    0.000000] printk: legacy bootconsole [sbi0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000140000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000140000000..0x000000015fffffff (524288 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x00000003fe000000..0x00000003ffffffff (32768 KiB) map non-reusable framebuffer@3,fe000000
[    0.000000] OF: reserved mem: 0x0000000100000000..0x00000001000fffff (1024 KiB) nomap non-reusable mmode_resv0@1,0
[    0.000000] OF: reserved mem: 0x0000000100200000..0x00000001004fffff (3072 KiB) nomap non-reusable rcpu0_pwr@100200000
[    0.000000] OF: reserved mem: 0x0000000100500000..0x00000001006fffff (2048 KiB) nomap non-reusable rcpu0_heap@100500000
[    0.000000] OF: reserved mem: 0x00000000c0876000..0x00000000c0878fff (12 KiB) nomap non-reusable vdev0vring0@c0876000
[    0.000000] OF: reserved mem: 0x00000000c0879000..0x00000000c087bfff (12 KiB) nomap non-reusable vdev0vring1@c0879000
[    0.000000] OF: reserved mem: 0x00000000c087c000..0x00000000c087cfff (4 KiB) nomap non-reusable vdev0vring2@c087c000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000100700000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@100700000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000100700000..0x00000001007fbfff (1008 KiB) nomap non-reusable vdev0buffer@100700000
[    0.000000] OF: reserved mem: 0x00000001007fc000..0x00000001007fffff (16 KiB) nomap non-reusable rcpu0_rsc_table@1007fc000
[    0.000000] OF: reserved mem: 0x0000000100800000..0x0000000100afffff (3072 KiB) nomap non-reusable rcpu1_runtime@100800000
[    0.000000] OF: reserved mem: 0x0000000100b00000..0x0000000100cfffff (2048 KiB) nomap non-reusable rcpu1_heap@100B00000
[    0.000000] OF: reserved mem: 0x00000000c086c000..0x00000000c086efff (12 KiB) nomap non-reusable vdev0vring0@c086c000
[    0.000000] OF: reserved mem: 0x00000000c086f000..0x00000000c0871fff (12 KiB) nomap non-reusable vdev0vring1@c086f000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000100d00000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@100d00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000100d00000..0x0000000100dfbfff (1008 KiB) nomap non-reusable vdev0buffer@100d00000
[    0.000000] OF: reserved mem: 0x0000000100dfc000..0x0000000100dfffff (16 KiB) nomap non-reusable rcpu1_rsc_table@100dfc000
[    0.000000] OF: reserved mem: 0x0000000100e00000..0x0000000100e03fff (16 KiB) nomap non-reusable rpmi0@100e00000
[    0.000000] OF: reserved mem: 0x0000000100f00000..0x00000001011fffff (3072 KiB) nomap non-reusable rcpu_dtb_table@100f00000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000101b00000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node dpu_reserved@101b00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000101b00000..0x0000000101d7ffff (2560 KiB) nomap non-reusable dpu_reserved@101b00000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000101d80000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node dpu_reserved1@101d80000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000101d80000..0x0000000101ffffff (2560 KiB) nomap non-reusable dpu_reserved1@101d80000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000102000000-0x00000008ffffffff]
[    0.000000]   node   0: [mem 0x0000000102000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000102000000-0x00000008ffffffff]
[    0.000000] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.000000] SBI HSM extension detected
[    0.000000] riscv: base ISA extensions acdfhimv
[    0.000000] riscv: ELF capabilities acdfimv
[    0.000000] Ticket spinlock: enabled
[    0.000000] percpu: Embedded 51 pages/cpu s85400 r8192 d115304 u208896
[    0.000000] pcpu-alloc: s85400 r8192 d115304 u208896 alloc=51*4096
[    0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[    0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11 [0] 12 [0] 13 [0] 14 [0] 15
[    0.000000] Kernel command line: earlycon=sbi earlyprintk plymouth.ignore-serial-consoles plymouth.prefer-fbcon splash clk_ignore_unused random.trust_bootloader=1 rootwait rootfstype=ext4 root=UUID=32539e08-a5c0-4084-9f32-0932043d95e3 bootfs=PARTUUID=8298ffc6-c268-438a-a562-68ad3f761501 boot_mode=sdcard console=ttyS0,115200 loglevel=8 unaligned_scalar_speed=fast unaligned_vector_speed=fast
[    0.000000] Unknown kernel command line parameters "earlyprintk splash bootfs=PARTUUID=8298ffc6-c268-438a-a562-68ad3f761501 boot_mode=sdcard", will be passed to user space.
[    0.000000] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 31MB
[    0.000000] software IO TLB: area num 16.
[    0.000000] software IO TLB: mapped [mem 0x00000008d9ad0000-0x00000008dbad0000] (32MB)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8380416
[    0.000000] mem auto-init: stack:all(pattern), heap alloc:on, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.000000]
[    0.000000] **********************************************************
[    0.000000] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    0.000000] **                                                      **
[    0.000000] ** trace_printk() being used. Allocating extra memory.  **
[    0.000000] **                                                      **
[    0.000000] ** This means that this is a DEBUG kernel and it is     **
[    0.000000] ** unsafe for production use.                           **
[    0.000000] **                                                      **
[    0.000000] ** If you see this message and you are not debugging    **
[    0.000000] ** the kernel, report this immediately to your vendor!  **
[    0.000000] **                                                      **
[    0.000000] Dynamic Preempt: voluntary
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.000000] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.000000] riscv-intc: 64 local interrupts mapped using AIA
[    0.000000] riscv-imsic: interrupt-controller@e0400000: providing IPIs using interrupt 1
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.007987] riscv-timer: Timer interrupt in S-mode is available via sstc extension
[    0.015775] init_sbi_dbtr: mcontrol6 trigger available.
[    0.020824] Console: colour dummy device 80x25
[    0.025203] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.035418] pid_max: default: 32768 minimum: 301
[    0.040100] LSM: initializing lsm=capability,landlock,apparmor
[    0.045937] landlock: Up and running.
[    0.049667] AppArmor: AppArmor initialized
[    0.053729] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.061144] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.071071] riscv: ELF compat mode unsupported
[    0.071088] ASID allocator using 16 bits (65536 entries)
[    0.078878] rcu: Hierarchical SRCU implementation.
[    0.083597] rcu:     Max phase no-delay instances is 1000.
[    0.088920] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.097138] EFI services will not be available.
[    0.101693] smp: Bringing up secondary CPUs ...
[    0.118050] smp: Brought up 1 node, 16 CPUs
[    0.119952] Memory: 32203904K/33521664K available (14942K kernel code, 6020K rwdata, 8192K rodata, 2414K init, 549K bss, 753108K reserved, 524288K cma-reserved)
[    0.137046] devtmpfs: initialized
[    0.153543] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.160367] posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.167901] futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
[    0.178846] pinctrl core: initialized pinctrl subsystem
[    0.183102] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.188552] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.194909] audit: initializing netlink subsys (disabled)
[    0.200385] audit: type=2000 audit(0.120:1): state=initialized audit_enabled=0 res=1
[    0.200553] display class register
[    0.211461] thermal_sys: Registered thermal governor 'step_wise'
[    0.212056] riscv-sdtrig: Writing 'PID' to scontext CSR is enabled
[    0.223576] scalar unaligned access speed set to 'fast' (3) by command line
[    0.230481] vector unaligned access speed set to 'fast' (3) by command line
[    0.237424] suspend: SBI SUSP extension detected
[    0.242024] arch_hw_breakpoint_init: total number of type 6 triggers: 3
[    0.248629] CPU 0: HW Breakpoint shared memory registered.
[    0.254100] CPU 1: HW Breakpoint shared memory registered.
[    0.259573] CPU 2: HW Breakpoint shared memory registered.
[    0.265040] CPU 3: HW Breakpoint shared memory registered.
[    0.270510] CPU 4: HW Breakpoint shared memory registered.
[    0.275979] CPU 5: HW Breakpoint shared memory registered.
[    0.281448] CPU 6: HW Breakpoint shared memory registered.
[    0.286917] CPU 7: HW Breakpoint shared memory registered.
[    0.292391] CPU 8: HW Breakpoint shared memory registered.
[    0.297862] CPU 9: HW Breakpoint shared memory registered.
[    0.303331] CPU 10: HW Breakpoint shared memory registered.
[    0.308886] CPU 11: HW Breakpoint shared memory registered.
[    0.314444] CPU 12: HW Breakpoint shared memory registered.
[    0.319998] CPU 13: HW Breakpoint shared memory registered.
[    0.325553] CPU 14: HW Breakpoint shared memory registered.
[    0.331108] CPU 15: HW Breakpoint shared memory registered.
[    0.366362] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.370204] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.376799] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.383567] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.389819] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.396588] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.404211] iommu: Default domain type: Translated
[    0.407703] iommu: DMA domain TLB invalidation policy: strict mode
[    0.421981] SCSI subsystem initialized
[    0.422872] libata version 3.00 loaded.
[    0.426699] usbcore: registered new interface driver usbfs
[    0.432088] usbcore: registered new interface driver hub
[    0.437391] usbcore: registered new device driver usb
[    0.442481] mc: Linux media interface: v0.10
[    0.446682] videodev: Linux video capture interface: v2.00
[    0.452145] pps_core: LinuxPPS API ver. 1 registered
[    0.457066] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.466186] PTP clock support registered
[    0.470302] Advanced Linux Sound Architecture Driver Initialized.
[    0.476662] NetLabel: Initializing
[    0.479546] NetLabel:  domain hash size = 128
[    0.483891] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.489572] NetLabel:  unlabeled traffic allowed by default
[    0.495236] mctp: management component transport protocol core
[    0.500908] NET: Registered PF_MCTP protocol family
[    0.505853] vgaarb: loaded
[    0.508741] clocksource: Switched to clocksource riscv_clocksource
[    0.514875] VFS: Disk quotas dquot_6.6.0
[    0.518546] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.525854] AppArmor: AppArmor Filesystem Enabled
[    0.533712] NET: Registered PF_INET protocol family
[    0.535816] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.549913] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.555760] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.563550] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.571951] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.579281] TCP: Hash tables configured (established 262144 bind 65536)
[    0.585793] MPTCP token hash table entries: 32768 (order: 8, 786432 bytes, linear)
[    0.593347] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    0.600276] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    0.607743] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.612974] NET: Registered PF_XDP protocol family
[    0.617738] PCI: CLS 0 bytes, default 64
[    0.621775] Trying to unpack rootfs image as initramfs...
[    0.627015] kvm [1]: hypervisor extension available
[    0.627018] kvm [1]: using Sv39x4 G-stage page table format
[    0.627021] kvm [1]: VMID 14 bits available
[    0.627023] kvm [1]: AIA available with 7 guest external interrupts
[    0.649035] Initialise system trusted keyrings
[    0.652419] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.659161] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.664703] fuse: init (API version 7.45)
[    0.693414] Key type asymmetric registered
[    0.694556] Asymmetric key parser 'x509' registered
[    0.699462] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.706912] io scheduler mq-deadline registered
[    0.713063] riscv-imsic: interrupt-controller@e0400000:  hart-index-bits: 4,  guest-index-bits: 6
[    0.720169] riscv-imsic: interrupt-controller@e0400000: group-index-bits: 0, group-index-shift: 24
[    0.729106] riscv-imsic: interrupt-controller@e0400000: per-CPU IDs 511 at base address 0x00000000e0400000
[    0.738741] riscv-imsic: interrupt-controller@e0400000: total 8160 interrupts available
[    0.746996] riscv-aplic e0804000.interrupt-controller: 512 interrupts forwarded to MSI base 0x00000000e0400000
[    0.757704] OF: /soc/phy@81f00000: Read of boolean property 'combo-usb-bit' with a value.
[    0.771168] spacemit-reboot c087c000.reboot-mode-helper: initializing...
[    0.775470] Serial: 8250/16550 driver, 17 ports, IRQ sharing disabled
[    0.784861] [drm] spacemit_drm_probe()
[    0.785787] [drm] spacemit_drm_probe()
[    0.789623] [drm] spacemit_dsi_probe()
[    0.793610] [drm] dphy driver probe success
[    0.803558] brd: module loaded
[    0.807697] loop: module loaded
[    0.808183] tcm 0.tcm: direct mmap phys 0x0 size 0x300000 block_size 0x60000 block_num 8 via /dev/tcm
[    0.818077] Rounding down aligned max_sectors from 4294967295 to 4294967288
[    0.824139] db_root: cannot open: /etc/target
[    0.829386] tun: Universal TUN/TAP device driver, 1.6
[    0.834024] EtherCAT: 1 master waiting for devices.
[    0.838417] usbcore: registered new interface driver ax88179_178a
[    0.844379] usbcore: registered new interface driver cdc_ether
[    0.850194] usbcore: registered new interface driver cdc_ncm
[    0.855950] VFIO - User Level meta-driver version: 0.3
[    0.863006] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    0.866413] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    0.874199] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    0.880034] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000808000000010
[    0.889428] xhci-hcd xhci-hcd.0.auto: irq 21, io mem 0xc0a00000
[    0.895469] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.903557] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.910763] usb usb1: Product: xHCI Host Controller
[    0.915618] usb usb1: Manufacturer: Linux 6.18.3 xhci-hcd
[    0.920999] usb usb1: SerialNumber: xhci-hcd.0.auto
[    0.926132] hub 1-0:1.0: USB hub found
[    0.929612] hub 1-0:1.0: 1 port detected
[    0.933791] usbcore: registered new interface driver uas
[    0.938827] usbcore: registered new interface driver usb-storage
[    0.944799] usbcore: registered new device driver onboard-usb-dev
[    0.951624] i2c_dev: i2c /dev entries driver
[    0.955402] IR NEC protocol handler initialized
[    0.960100] d420a000.csiphy probed
[    0.960146] d420a800.csiphy probed
[    0.963062] d4206000.csiphy probed
[    0.966930] rsvd_phy_addr=0x10e278040 size=4096
[    0.977031] ccic mmu tbl size alloc:3145728 needed:3145728
[    0.978609] d420a000.cam_ccic probed
[    0.984533] d420a800.cam_ccic probed
[    0.988061] d4206000.cam_ccic probed
[    0.991421] d420f000.cam_ccic_dma probed
[    0.994890] usbcore: registered new interface driver uvcvideo
[    1.068948] System boots up not because of SoC watchdog reset.
[    1.080800] device-mapper: uevent: version 1.0.3
[    1.082600] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: [email protected]
[    1.091526] sdhci: Secure Digital Host Controller Interface driver
[    1.097485] sdhci: Copyright(c) Pierre Ossman
[    1.101823] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.107912] ufshcd-spacemit c0e00000.ufshc: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.118584] ufshcd-spacemit c0e00000.ufshc: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.129343] ufshcd-spacemit c0e00000.ufshc: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.140192] ufshcd-spacemit c0e00000.ufshc: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.158641] ufshcd-spacemit c0e00000.ufshc: UniPro v1.6 init completed
[    1.442532] scsi host0: ufshcd
[    1.443327] Timer 0: loop_delay_fastclk is 26
[    1.444035] scsi 0:0:0:49488: Well-known LUN    KINGSTON TY7B-128         0004 PQ: 0 ANSI: 6
[    1.447217] hid: raw HID events driver (C) Jiri Kosina
[    1.455408] ufshcd-spacemit c0e00000.ufshc: lu 49488 scsi queue depth limited to 1
[    1.460796] usbcore: registered new interface driver usbhid
[    1.473399] scsi 0:0:0:49476: Well-known LUN    KINGSTON TY7B-128         0004 PQ: 0 ANSI: 6
[    1.473631] usbhid: USB HID core driver
[    1.482056] ufshcd-spacemit c0e00000.ufshc: lu 49476 scsi queue depth limited to 1
[    1.494032] riscv-sbi-mpxy-mbox soc:mpxy_mbox@0: mailbox registered with 5 channels
[    1.498068] ufshcd-spacemit c0e00000.ufshc: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    1.502703] remoteproc remoteproc0: rcpu_rproc1 is available
[    1.509588] scsi 0:0:0:0: Direct-Access     KINGSTON TY7B-128         0004 PQ: 0 ANSI: 6
[    1.514558] remoteproc remoteproc0: attaching to rcpu_rproc1
[    1.522591] ufshcd-spacemit c0e00000.ufshc: lu 0 scsi queue depth limited to 1
[    1.528303] remoteproc remoteproc0: remote processor rcpu_rproc1 is now attached
[    1.540608] sd 0:0:0:0: [sda] 31266816 4096-byte logical blocks: (128 GB/119 GiB)
[    1.543072] riscv-pmu-sbi: SBI PMU extension is available
[    1.550429] sd 0:0:0:0: [sda] Write Protect is off
[    1.555686] riscv-pmu-sbi: 16 firmware and 18 hardware counters
[    1.560437] sd 0:0:0:0: [sda] Mode Sense: 00 32 00 10
[    1.571486] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[    1.571958]  cs_system_cfg: CoreSight Configuration manager initialised
[    1.579926] sd 0:0:0:0: [sda] Preferred minimum I/O size 524288 bytes
[    1.592904] sd 0:0:0:0: [sda] Optimal transfer size 524288 bytes
[    1.595358] usbcore: registered new interface driver snd-usb-audio
[    1.606185] NET: Registered PF_PACKET protocol family
[    1.650364]  sda: sda1 sda2 sda3
[    1.650969] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.697838] Freeing initrd memory: 57912K
[    1.703909] NET: Registered PF_RXRPC protocol family
[    1.705937] Key type rxrpc registered
[    1.709578] Key type rxrpc_s registered
[    1.713770] Key type dns_resolver registered
[    1.725179] Loading compiled-in X.509 certificates
[    1.739959] Key type .fscrypt registered
[    1.740935] Key type fscrypt-provisioning registered
[    1.745995] AppArmor: AppArmor sha256 policy hashing enabled
[    1.778988] v2d irq num = 37
[    1.781019] probe v2d driver done!
[    1.784085] spacemit,k3-usb3-phy cad30000.phy: Using orientation-switch mode, flip: 0
[    1.790184] OF: /soc/phy@81f00000: Read of boolean property 'combo-usb-bit' with a value.
[    1.799149] k1-pinctrl d401e000.pinctrl: Wake-up interrupt initialized (IRQ 40)
[    1.806812] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.814722] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.823572] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.832384] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.841626] spacemit-k1-pcie 80000000.pcie: iommu bypassed
[    1.841830] spacemit-k1-pcie 80c00000.pcie: host bridge /soc/pcie@80c00000 ranges:
[    1.841881] spacemit-k1-pcie 81000000.pcie: host bridge /soc/pcie@81000000 ranges:
[    1.841904] spacemit-k1-pcie 81000000.pcie:       IO 0x12c0010000..0x12c010ffff -> 0x0000000000
[    1.841922] spacemit-k1-pcie 81000000.pcie:      MEM 0x12c0110000..0x12ffffffff -> 0x00c0110000
[    1.841931] spacemit-k1-pcie 81000000.pcie:      MEM 0x1300000000..0x13ffffffff -> 0x1300000000
[    1.842240] mmp-pdma d4000000.pdma: initialized 16 channels
[    1.844023] spacemit,k3-pcie-phy 82200000.phy-pcie: waiting PLL lock...
[    1.846518] spacemit-k1-pcie 80000000.pcie: host bridge /soc/pcie@80000000 ranges:
[    1.850843] input: soc:pwrkey_monitor@1101 as /devices/platform/soc/soc:pwrkey_monitor@1101/input/input0
[    1.854025] spacemit-k1-pcie 80c00000.pcie:       IO 0x1280010000..0x128010ffff -> 0x0000010000
[    1.861575] spacemit-k1-pcie 80000000.pcie:       IO 0x1100010000..0x110010ffff -> 0x0000010000
[    1.870260] spacemit-k1-pcie 80c00000.pcie:      MEM 0x1280110000..0x12bfffffff -> 0x0080110000
[    1.878934] spacemit-k1-pcie 80000000.pcie:      MEM 0x1100110000..0x117fffffff -> 0x0000110000
[    1.887610] spacemit-k1-pcie 80c00000.pcie:      MEM 0x1400000000..0x14ffffffff -> 0x1400000000
[    1.893167] spacemit-k1-pcie 80000000.pcie:      MEM 0x1800000000..0x18ffffffff -> 0x1800000000
[    1.901860] spacemit,k3-pcie-phy 82100000.phy-pcie: waiting PLL lock...
[    1.902249] spacemit,k3-pcie-phy 82200000.phy-pcie: PHY PLL Locked.
[    1.909402] spacemit,k3-pcie-phy 81d00000.phy-pcie: waiting PLL lock...
[    1.916772] spacemit,k3-pcie-phy 82100000.phy-pcie: PHY PLL Locked.
[    1.925453] spacemit,k3-pcie-phy 81d00000.phy-pcie: PHY PLL Locked.
[    2.000808] spacemit,k3-pcie-phy 81e00000.phy-pcie: waiting PLL lock...
[    2.004288] spacemit-k1-pcie 81000000.pcie: iATU: unroll T, 16 ob, 16 ib, align 64K, limit 4G
[    2.007396] spacemit,k3-pcie-phy 81e00000.phy-pcie: PHY PLL Locked.
[    2.016199] spacemit-k1-pcie 81000000.pcie: PCI host bridge to bus 0004:00
[    2.029018] pci_bus 0004:00: root bus resource [bus 00-ff]
[    2.032505] printk: legacy console [ttyS0] disabled
[    2.034484] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff]
[    2.034489] pci_bus 0004:00: root bus resource [mem 0x12c0110000-0x12ffffffff] (bus address [0xc0110000-0xffffffff])
[    2.036167] spacemit-k1-pcie 80c00000.pcie: iATU: unroll T, 16 ob, 16 ib, align 64K, limit 4G
[    2.064604] pci_bus 0004:00: root bus resource [mem 0x1300000000-0x13ffffffff pref]
[    2.064632] pci 0004:00:00.0: [201f:0002] type 01 class 0x060400 PCIe Root Port
[    2.072248] d4017000.serial: ttyS0 at MMIO 0xd4017000 (irq = 47, base_baud = 921600) is a XScale
[    2.079545] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    2.093513] pci 0004:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.093519] pci 0004:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.106362] pci 0004:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.106410] pci 0004:00:00.0: supports D1
[    2.118076] pci 0004:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.121981] pci 0004:01:00.0: [10ec:b852] type 00 class 0x028000 PCIe Endpoint
[    2.124207] spacemit-k1-pcie 80000000.pcie: iATU: unroll T, 31 ob, 31 ib, align 64K, limit 4G
[    2.132754] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[    2.140305] pci 0004:01:00.0: BAR 0 [io  0x0000-0x00ff]
[    2.151855] printk: legacy console [ttyS0] enabled
[    2.151860] pci 0004:01:00.0: BAR 2 [mem 0x00000000-0x000fffff 64bit]
[    2.156831] printk: legacy bootconsole [sbi0] disabled
[    2.163568] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[    2.199079] [drm] spacemit_dpu_probe()
[    2.200600] [drm] dpu_parse_dt, read bitclk failed from dts!
[    2.206239] [drm] can not get lcd lpm commit qos value
[    2.206278] pci 0004:01:00.0: ASPM: default states L0s
[    2.211349] [drm] can not get lcd bl lpm qos value
[    2.216541] pci_bus 0004:01: busn_res: [bus 01-ff] end is updated to 01
[    2.221233] [drm] can not get lcd lpm period value
[    2.227840] pci 0004:00:00.0: bridge window [mem 0x12c0200000-0x12c02fffff]: assigned
[    2.227922] spacemit-k1-pcie 80000000.pcie: PCI host bridge to bus 0000:00
[    2.227932] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.227940] pci_bus 0000:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x10000-0x10ffff])
[    2.227944] pci_bus 0000:00: root bus resource [mem 0x1100110000-0x117fffffff] (bus address [0x00110000-0x7fffffff])
[    2.227948] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x18ffffffff pref]
[    2.227974] pci 0000:00:00.0: [201f:0002] type 01 class 0x060400 PCIe Root Port
[    2.227988] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x07ffffff]
[    2.227993] pci 0000:00:00.0: BAR 1 [mem 0x00000000-0x07ffffff]
[    2.227998] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.228003] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.228008] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.228015] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.228061] pci 0000:00:00.0: supports D1
[    2.228063] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.233790] OF: /soc/dsi0@d421a800/panel0@0: Read of boolean property 'compatible' with a value.
[    2.234013] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.234030] pci 0000:00:00.0: BAR 0 [mem 0x1108000000-0x110fffffff]: assigned
[    2.234036] pci 0000:00:00.0: BAR 1 [mem 0x1110000000-0x1117ffffff]: assigned
[    2.234042] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.234050] pci_bus 0000:00: resource 4 [io  0x200000-0x2fffff]
[    2.234054] pci_bus 0000:00: resource 5 [mem 0x1100110000-0x117fffffff]
[    2.234057] pci_bus 0000:00: resource 6 [mem 0x1800000000-0x18ffffffff pref]
[    2.234111] spacemit-k1-pcie 80c00000.pcie: PCI host bridge to bus 0003:00
[    2.234119] pci_bus 0003:00: root bus resource [bus 00-ff]
[    2.234127] pci_bus 0003:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x10000-0x10ffff])
[    2.234131] pci_bus 0003:00: root bus resource [mem 0x1280110000-0x12bfffffff] (bus address [0x80110000-0xbfffffff])
[    2.234135] pci_bus 0003:00: root bus resource [mem 0x1400000000-0x14ffffffff pref]
[    2.234160] pci 0003:00:00.0: [201f:0002] type 01 class 0x060400 PCIe Root Port
[    2.234176] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[    2.234183] pci 0003:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.234187] pci 0003:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.234195] pci 0003:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.234238] pci 0003:00:00.0: supports D1
[    2.234241] pci 0003:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.238502] pci_bus 0003:01: busn_res: [bus 01-ff] end is updated to 01
[    2.238511] pci 0003:00:00.0: PCI bridge to [bus 01]
[    2.238519] pci_bus 0003:00: resource 4 [io  0x100000-0x1fffff]
[    2.238523] pci_bus 0003:00: resource 5 [mem 0x1280110000-0x12bfffffff]
[    2.238526] pci_bus 0003:00: resource 6 [mem 0x1400000000-0x14ffffffff pref]
[    2.238676] spacemit-k1-pcie 80000000.pcie: spacemit-pcie: link is down after host_init
[    2.238735] spacemit-k1-pcie 80c00000.pcie: spacemit-pcie: link is down after host_init
[    2.240412] pci 0004:00:00.0: bridge window [io  0x1000-0x1fff]: assigned
[    2.247285] [drm] is_oled: 0
[    2.252739] pci 0004:01:00.0: BAR 2 [mem 0x12c0200000-0x12c02fffff 64bit]: assigned
[    2.252781] pci 0004:01:00.0: BAR 0 [io  0x1000-0x10ff]: assigned
[    2.262291] Reserved memory: detected framebuffer at 0x00000003fe000000, size 32 MB
[    2.272628] pci 0004:00:00.0: PCI bridge to [bus 01]
[    2.281549] usb 1-1: New USB device found, idVendor=0bda, idProduct=b85b, bcdDevice= 0.00
[    2.282541] [drm] spacemit_dpu_probe()
[    2.282570] dpu_parse_dt, read hclk failed from dts!
[    2.282582] [drm] can not get lcd lpm commit qos value
[    2.282585] [drm] can not get lcd bl lpm qos value
[    2.282586] [drm] can not get lcd lpm period value
[    2.283124] spi-nor spi4.0: supply vcc not found, using dummy regulator
[    2.284626] dwmac-spacemit-ethqos cac82000.ethernet: IRQ eth_lpi not found
[    2.284631] dwmac-spacemit-ethqos cac82000.ethernet: IRQ sfty not found
[    2.284812] dwmac-spacemit-ethqos cac82000.ethernet: rgmii tx clk is derived from the rx clk
[    2.284817] dwmac-spacemit-ethqos cac82000.ethernet: phy clk is provided by a external crystal oscillator
[    2.284837] dwmac-spacemit-ethqos cac82000.ethernet: phy-mode=rgmii val=0x00000008
[    2.284975] dwmac-spacemit-ethqos cac82000.ethernet: User ID: 0x10, Synopsys ID: 0x54
[    2.284983] dwmac-spacemit-ethqos cac82000.ethernet:         DWMAC4/5
[    2.284988] dwmac-spacemit-ethqos cac82000.ethernet: DMA HW capability register supported
[    2.284990] dwmac-spacemit-ethqos cac82000.ethernet: RX Checksum Offload Engine supported
[    2.284993] dwmac-spacemit-ethqos cac82000.ethernet: TX Checksum insertion supported
[    2.284996] dwmac-spacemit-ethqos cac82000.ethernet: Wake-Up On Lan supported
[    2.285030] dwmac-spacemit-ethqos cac82000.ethernet: TSO supported
[    2.285033] dwmac-spacemit-ethqos cac82000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.285040] dwmac-spacemit-ethqos cac82000.ethernet: Enabled L3L4 Flow TC (entries=4)
[    2.285045] dwmac-spacemit-ethqos cac82000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.285051] dwmac-spacemit-ethqos cac82000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.285054] dwmac-spacemit-ethqos cac82000.ethernet: TSO feature enabled
[    2.285057] dwmac-spacemit-ethqos cac82000.ethernet: SPH feature enabled
[    2.285060] dwmac-spacemit-ethqos cac82000.ethernet: Using 40/40 bits DMA host/device width
[    2.287550] pci 0004:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.287556] pci 0004:00:00.0:   bridge window [mem 0x12c0200000-0x12c02fffff]
[    2.293451] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.299355] pci_bus 0004:00: resource 4 [io  0x0000-0xfffff]
[    2.304560] usb 1-1: Product: Bluetooth Radio
[    2.310636] pci_bus 0004:00: resource 5 [mem 0x12c0110000-0x12ffffffff]
[    2.317411] usb 1-1: Manufacturer: Realtek
[    2.325134] pci_bus 0004:00: resource 6 [mem 0x1300000000-0x13ffffffff pref]
[    2.329126] usb 1-1: SerialNumber: 00e04c000001
[    2.335465] pci_bus 0004:01: resource 0 [io  0x1000-0x1fff]
[    2.427464] phy phy-cad30000.phy.7: PUPHY Rx Reg Configured
[    2.429387] pci_bus 0004:01: resource 1 [mem 0x12c0200000-0x12c02fffff]
[    2.437185] phy phy-cad30000.phy.7: PHY version: 0x302 init as USB3 mode
[    2.442129] spacemit-k1-pcie 81000000.pcie: spacemit-pcie: link is up after host_init
[    2.447974] phy phy-cad30000.phy.7: PUPHY Rx Reg Configured
[    2.552285] pci_bus 0004:01: busn_res: [bus 01] end is updated to 01
[    2.556282] phy phy-cad30000.phy.7: PHY version: 0x302 init as USB3 mode
[    2.563946] pci 0004:00:00.0: PCI bridge to [bus 01]
[    2.567855] gadget (null): enable vbus monitoring
[    2.569370] spacemit,k3-usb3-phy 81f00000.phy: Update Combo Mode 20 to USB Mode
[    2.569384] phy phy-81f00000.phy.8: PUPHY Rx Reg Configured
[    2.569891] phy phy-81f00000.phy.8: PHY version: 0x302 init as USB3 mode
[    2.570137] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.570150] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    2.570357] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000808000000090
[    2.570378] xhci-hcd xhci-hcd.1.auto: irq 52, io mem 0x81400000
[    2.570480] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.570487] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    2.570494] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.570616] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    2.570621] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.570625] usb usb2: Product: xHCI Host Controller
[    2.570627] usb usb2: Manufacturer: Linux 6.18.3 xhci-hcd
[    2.570630] usb usb2: SerialNumber: xhci-hcd.1.auto
[    2.570884] hub 2-0:1.0: USB hub found
[    2.570906] hub 2-0:1.0: 1 port detected
[    2.571345] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.571392] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    2.571396] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.571400] usb usb3: Product: xHCI Host Controller
[    2.571403] usb usb3: Manufacturer: Linux 6.18.3 xhci-hcd
[    2.571405] usb usb3: SerialNumber: xhci-hcd.1.auto
[    2.571623] hub 3-0:1.0: USB hub found
[    2.571636] hub 3-0:1.0: 1 port detected
[    2.572618] pci 0004:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.572623] pci 0004:00:00.0:   bridge window [mem 0x12c0200000-0x12c02fffff]
[    2.591367] riscv-rpmi-rtc soc:rpmi_rtc@0: registered as rtc0
[    3.029319] riscv-rpmi-rtc soc:rpmi_rtc@0: setting system clock to 2000-01-01T00:00:53 UTC (946684853)
[    3.037720] at24 1-0050: supply vcc not found, using dummy regulator
[    3.042561] at24 1-0050: 256 byte 24c02 EEPROM, read-only
[    3.048924] [drm] rpi_touchscreen_probe
[    3.251481] [drm:rpi_touchscreen_probe] *ERROR* rpi_touchscreen_probe: I2C read failed: -6
[    3.257153] raspits-ft5426: raspits_ft5426_probe: address = 0x38
[    3.263093] input: fts_ts as /devices/platform/soc/f0614000.i2c/i2c-3/3-0038/input/input1
[    3.271919] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    3.276950] imx219-simple 5-0010: imx219-test: probe enter, client addr=0x10
[    3.280019] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 8
[    3.287041] imx219-simple 5-0010: imx219-test: get PWDN gpio
[    3.287070] imx219-simple 5-0010: imx219-test: power_on enter
[    3.305785] imx219-simple 5-0010: imx219-test: get vdd regulator
[    3.313952] imx219-simple 5-0010: imx219-test: enable vdd
[    3.322185] imx219-simple 5-0010: imx219-test: vdd set to 3.3V
[    3.325263] imx219-simple 5-0010: imx219-test: drive PWDN low
[    3.343003] imx219-simple 5-0010: imx219-test: drive PWDN high
[    3.368860] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.377102] imx219-simple 5-0010: imx219-test: power_on done
[    3.380009] imx219-simple 5-0010: imx219-test: detect start
[    3.385622] imx219-simple 5-0010: imx219-test: I2C read failed, reg=0x0, ret=-6
[    3.392870] imx219-simple 5-0010: imx219-test: sensor detect failed: -6
[    3.399456] imx219-simple 5-0010: imx219-test: power_off enter
[    3.405272] imx219-simple 5-0010: imx219-test: drive PWDN low
[    3.411002] imx219-simple 5-0010: imx219-test: disable vdd
[    3.412824] usb 3-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 7.00
[    3.417483] imx219-simple 5-0010: imx219-test: power_off done
[    3.424634] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.430661] ov5647-simple 5-0036: ov5647-test: probe enter, client addr=0x36
[    3.437476] usb 3-1: Product: USB3.0 Hub
[    3.437480] usb 3-1: Manufacturer: VIA Labs, Inc.
[    3.455036] ov5647-simple 5-0036: ov5647-test: get PWDN gpio
[    3.460689] ov5647-simple 5-0036: ov5647-test: power_on enter
[    3.466388] ov5647-simple 5-0036: ov5647-test: set i2c-mux high
[    3.466765] hub 3-1:1.0: USB hub found
[    3.472287] ov5647-simple 5-0036: ov5647-test: get vdd regulator
[    3.474387] ov5647-simple 5-0036: ov5647-test: enable vdd
[    3.476143] hub 3-1:1.0: 4 ports detected
[    3.487039] ov5647-simple 5-0036: ov5647-test: vdd set to 3.3V
[    3.497202] ov5647-simple 5-0036: ov5647-test: drive PWDN low
[    3.523939] ov5647-simple 5-0036: ov5647-test: drive PWDN high
[    3.528748] usb 2-1: new high-speed USB device number 2 using xhci-hcd
[    3.548040] ov5647-simple 5-0036: ov5647-test: power_on done
[    3.550953] ov5647-simple 5-0036: ov5647-test: detect start
[    3.556552] ov5647-simple 5-0036: ov5647-test: I2C read failed, reg=0x300a, ret=-6
[    3.564071] ov5647-simple 5-0036: ov5647-test: sensor detect failed: -6
[    3.570662] ov5647-simple 5-0036: ov5647-test: power_off enter
[    3.576472] ov5647-simple 5-0036: ov5647-test: drive PWDN low
[    3.582221] ov5647-simple 5-0036: ov5647-test: disable vdd
[    3.588681] ov5647-simple 5-0036: ov5647-test: set i2c-mux low
[    3.593488] ov5647-simple 5-0036: ov5647-test: power_off done
[    3.599711] ov5640-max96724-max9295 5-003c: ov5640-gmsl: i2c read failed slave=0x27 reg=0x0000 ret=-6
[    3.623993] MVX dev: Linlon v5276 identified. cores=4, nlsid=4, id=0, fuse=00000000, hw_id=00005276, hw_rev=00000050
[    3.633501] sdhci-spacemit d4280000.mmc: Got CD GPIO
[    3.633736] rfkill_gpio rfkill-pcie-wlan: rfkill-pcie-wlan device registered.
[    3.644131] rfkill_gpio rfkill-m2-bt: rfkill-m2-bt device registered.
[    3.654614] pvrsrvkm cac00000.imggpu: Using default thermal zone: thermal_gpu with default power model parameters
[    3.662186] PVR_K:  96: Read BVNC 36.56.104.183 from HW device registers
[    3.668826] PVR_K:  96: RGX Device registered BVNC 36.56.104.183 with 1 core in the system
[    3.678528] pvrsrvkm cac00000.imggpu: Found 6 OPP points.
[    3.681566] mmc0: SDHCI controller on d4280000.mmc [d4280000.mmc] using ADMA 64-bit
[    3.682453] pvrsrvkm cac00000.imggpu: opp[1/6]: (409000000 Hz, 800000 uV)
[    3.696855] pvrsrvkm cac00000.imggpu: opp[2/6]: (491000000 Hz, 800000 uV)
[    3.703624] pvrsrvkm cac00000.imggpu: opp[3/6]: (614000000 Hz, 900000 uV)
[    3.710397] pvrsrvkm cac00000.imggpu: opp[4/6]: (819000000 Hz, 900000 uV)
[    3.717166] pvrsrvkm cac00000.imggpu: opp[5/6]: (1000000000 Hz, 950000 uV)
[    3.722195] usb 2-1: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 7.00
[    3.724022] pvrsrvkm cac00000.imggpu: opp[6/6]: (1228000000 Hz, 950000 uV)
[    3.732191] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.742398] sdhci-spacemit d4280000.mmc: mmc0: set tx_delaycode: 31
[    3.746160] usb 2-1: Product: USB2.0 Hub
[    3.750842] [drm] Initialized pvr 24.2.6603887 for cac00000.imggpu on minor 0
[    3.751036] [drm] inno_dp_probe()
[    3.751087] [drm] spacemit_dpu_bind()
[    3.751090] [drm] spacemit_dpu_irqs_init()
[    3.751257] spacemit-dpu-drv soc:dpu1_crtc0: assigned reserved memory node dpu_reserved1@101d80000
[    3.751590] [drm] dpu plane init ok
[    3.751610] [drm] spacemit_crtc_bind_init() ok
[    3.751617] [drm] create device file enable_dump_reg
[    3.751620] [drm] create device file enable_dump_fps
[    3.751623] [drm] create device file enable_auto_fc
[    3.751626] [drm] create device file dpu_set_lpm_period
[    3.751628] [drm] dpu driver probe success
[    3.751631] spacemit-drm-drv c0440000.display-subsystem-dp1: bound soc:dpu1_crtc0 (ops dpu_component_ops)
[    3.751640] [drm] soc_dp_bind()
[    3.751674] [drm] soc_dp_aux_init()
[    3.757166] sdhci-spacemit d4280000.mmc: mmc0: pass window [20 166)
[    3.757449] usb 2-1: Manufacturer: VIA Labs, Inc.
[    3.764824] spacemit-inno-dp-drv cac88000.dp1: Setting PLL to Rate 2700000 kHz, Pclk 148500 kHz
[    3.765573] sdhci-spacemit d4280000.mmc: mmc0: pass window [170 190)
[    3.767290] sdhci-spacemit d4280000.mmc: mmc0: pass window [238 255]
[    3.767294] sdhci-spacemit d4280000.mmc: mmc0: tuning done, use delay_code:93
[    3.767840] mmc0: new UHS-I speed SDR104 SDXC card at address 5048
[    3.768208] mmcblk0: mmc0:5048 SD64G 58.0 GiB
[    3.818747] hub 2-1:1.0: USB hub found
[    3.887282] hub 2-1:1.0: 5 ports detected
[    3.891144] spacemit-inno-dp-drv cac88000.dp1: init audio
[    3.894640]  mmcblk0: p1 p2 p3
[    3.908539] spacemit-inno-dp-drv cac88000.dp1: Starting HPD Polling Thread...
[    3.912926] spacemit-drm-drv c0440000.display-subsystem-dp1: bound cac88000.dp1 (ops soc_dp_ops)
[    3.921934] [drm] Initialized spacemit 1.0.0 for c0440000.display-subsystem-dp1 on minor 1
[    3.930012] spacemit-drm-drv c0440000.display-subsystem-dp1: [drm] Cannot find any crtc or sizes
[    3.938779] spacemit-drm-drv c0440000.display-subsystem-dp1: [drm] Cannot find any crtc or sizes
[    4.023146] hub 3-1:1.0: USB hub found
[    4.053394] hub 3-1:1.0: 4 ports detected
[    4.296808] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    4.298661] hub 3-1:1.0: USB hub found
[    4.302949] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 7
[    4.303024] hub 2-1:1.0: USB hub found
[    4.303167] hub 2-1:1.0: 5 ports detected
[    4.306833] hub 3-1:1.0: 4 ports detected
[    4.601088] clk: Not disabling unused clocks
[    4.602613] PM: genpd: Disabling unused power domains
[    4.607686] ALSA device list:
[    4.61[    4.614436] Freeing unused kernel image (initmem) memory: 2412K
[    4.619565] Checked W+X mappings: passed, no W+X pages found
[    4.623347] Run /init as init process
[    4.626983]   with arguments:
[    4.629935]     /init
[    4.632188]     earlyprintk
[    4.634969]     splash
[    4.637312]   with environment:
[    4.640434]     HOME=/
[    4.642780]     TERM=linux
[    4.645478]     bootfs=PARTUUID=8298ffc6-c268-438a-a562-68ad3f761501
[    4.651809]     boot_mode=sdcard
[    4.664058] udevd[270]: starting version 3.2.14
[    4.669722] udevd[271]: starting eudev-3.2.14
[    4.729987] cam clk[csi_func]: 491520000
[    4.730866] cam clk[csi_func]: 491520000
[    4.731272] cam clk[ccic_func]: 491520000
[    4.733514] cam clk[csi_func]: 491520000
[    4.733522] cam clk[ccic_func]: 491520000
[    4.733532] cam clk[ahb_func]: 307200000
[    4.733537] cam clk[axi_func]: 409600000
[    4.733544] spacemit_ccic d420a800.cam_ccic: power on
[    4.733609] spacemit_ccic d420a800.cam_ccic: power off
[    4.735173] cam clk[ccic_func]: 491520000
[    4.739161] cam clk[ahb_func]: 307200000
[    4.740413] cam clk[csi_func]: 491520000
[    4.740420] cam clk[ccic_func]: 491520000
[    4.740423] cam clk[ahb_func]: 307200000
[    4.740426] cam clk[axi_func]: 409600000
[    4.740429] spacemit_ccic d420a800.cam_ccic: power on
[    4.740481] spacemit_ccic d420a800.cam_ccic: power off
[    4.743085] cam clk[ahb_func]: 307200000
[    4.747065] cam clk[axi_func]: 409600000
[    4.748517] cam clk[csi_func]: 491520000
[    4.748524] cam clk[ccic_func]: 491520000
[    4.748527] cam clk[ahb_func]: 307200000
[    4.748531] cam clk[axi_func]: 409600000
[    4.748534] spacemit_ccic d420a800.cam_ccic: power on
[    4.748587] spacemit_ccic d420a800.cam_ccic: power off
[    4.750962] cam clk[axi_func]: 409600000
[    4.750968] spacemit_ccic d420a000.cam_ccic: power on
[    4.751043] spacemit_ccic d420a000.cam_ccic: power off
[    4.752225] cam clk[csi_func]: 491520000
[    4.752231] cam clk[ccic_func]: 491520000
[    4.752234] cam clk[ahb_func]: 307200000
[    4.752237] cam clk[axi_func]: 409600000
[    4.752241] spacemit_ccic d420a800.cam_ccic: power on
[    4.752301] spacemit_ccic d420a800.cam_ccic: power off
[    4.754872] spacemit_ccic d4206000.cam_ccic: power on
[    4.759911] cam clk[csi_func]: 491520000
[    4.765390] spacemit_ccic d4206000.cam_ccic: power off
[    4.769025] cam clk[ccic_func]: 491520000
[    4.769031] cam clk[ahb_func]: 307200000
[    4.772936] cam clk[csi_func]: 491520000
[    4.776847] cam clk[axi_func]: 409600000
[    4.776854] spacemit_ccic d420a000.cam_ccic: power on
[    4.776979] spacemit_ccic d420a000.cam_ccic: power off
[    4.780826] cam clk[ccic_func]: 491520000
[    4.784732] cam clk[csi_func]: 491520000
[    4.788638] cam clk[ahb_func]: 307200000
[    4.788643] cam clk[axi_func]: 409600000
[    4.793674] cam clk[ccic_func]: 491520000
[    4.798792] spacemit_ccic d4206000.cam_ccic: power on
[    4.802697] cam clk[ahb_func]: 307200000
[    4.806708] spacemit_ccic d4206000.cam_ccic: power off
[    4.810509] cam clk[axi_func]: 409600000
[    4.810514] spacemit_ccic d420a000.cam_ccic: power on
[    4.955135] spacemit_ccic d420a000.cam_ccic: power off
[    5.020758] usb 2-1.5: new high-speed USB device number 3 using xhci-hcd
[    5.038313] EXT4-fs (mmcblk0p3): mounted filesystem 32539e08-a5c0-4084-9f32-0932043d95e3 ro without journal. Quota mode: none.
Successfully mounted device UUID=32539e08-a5c0-4084-9f32-0932043d95e3
Loading kernel modules from initramfs image:
insmod /lib/modules/6.18.3/kernel/lib/raid6/raid6_pq.ko
[    5.120737] raid6: rvvx1    gen() 19091 MB/s
[    5.188736] raid6: rvvx2    gen() 20433 MB/s
[    5.256736] raid6: rvvx4    gen() 20184 MB/s
[    5.320795] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    5.324736] raid6: rvvx8    gen() 19890 MB/s
[    5.327013] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 6
[    5.396736] raid6: int64x8  gen()  3067 MB/s
[    5.464736] raid6: int64x4  gen()  4420 MB/s
[    5.532738] raid6: int64x2  gen()  4173 MB/s
[    5.600741] raid6: int64x1  gen()  2907 MB/s
[    5.602344] raid6: using algorithm rvvx2 gen() 20433 MB/s
[    5.672736] raid6: .... xor() 12993 MB/s, rmw enabled
[    5.675121] raid6: using rvv recovery algorithm
insmod /lib/modules/6.18.3/kernel/crypto/xor.ko [    5.683362] xor: measuring software checksum speed
[    5.688953]    8regs           :  9363 MB/sec
[    5.693425]    32regs          : 10051 MB/sec
[    5.697666] usb 2-1.5: New USB device found, idVendor=2109, idProduct=8817, bcdDevice= 0.01
[    5.697745]    rvv             : 11070 MB/sec
[    5.705773] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.705778] usb 2-1.5: Product: USB Billboard Device
[    5.705781] usb 2-1.5: Manufacturer: VIA Labs, Inc.
insmod /lib/modules/6.18.3/kernel/crypto/blake2b_generic.ko
[    5.710108] xor: using function: rvv (11070 MB/sec)
[    5.717399] usb 2-1.5: SerialNumber: 0000000000000001
insmod /lib/modules/6.18.3/kernel/fs/btrfs/btrfs.ko
[    5.878144] Btrfs loaded, zoned=yes, fsverity=yes
insmod /lib/modules/6.18.3/kernel/fs/xfs/xfs.ko
[    6.229369] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[    6.344816] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    6.351041] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 5
[    7.368793] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    7.375012] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 4
[    8.392801] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    8.399024] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 3
[    9.416795] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[    9.423011] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 2
INIT: version 3.18 booting
The system is coming up. Please wait.
[   10.440805] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[   10.447033] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 1
[   10.501344] udevd[362]: starting version 3.2.14
[   10.549452] udevd[363]: starting eudev-3.2.14
[   10.637375] cam clk[csi_func]: 491520000
[   10.637882] cam clk[csi_func]: 491520000
[   10.638653] cam clk[ccic_func]: 491520000
[   10.638658] cam clk[ahb_func]: 307200000
[   10.641728] cam clk[csi_func]: 491520000
[   10.641736] cam clk[ccic_func]: 491520000
[   10.641740] cam clk[ahb_func]: 307200000
[   10.641745] cam clk[axi_func]: 409600000
[   10.641750] spacemit_ccic d420a800.cam_ccic: power on
[   10.641816] spacemit_ccic d420a800.cam_ccic: power off
[   10.642574] cam clk[ccic_func]: 491520000
[   10.642579] cam clk[ahb_func]: 307200000
[   10.642583] cam clk[axi_func]: 409600000
[   10.642592] spacemit_ccic d420a000.cam_ccic: power on
[   10.642739] cam clk[csi_func]: 491520000
[   10.642746] cam clk[ccic_func]: 491520000
[   10.642749] cam clk[ahb_func]: 307200000
[   10.642752] cam clk[axi_func]: 409600000
[   10.642755] spacemit_ccic d420a800.cam_ccic: power on
[   10.642806] spacemit_ccic d420a800.cam_ccic: power off
[   10.643747] cam clk[csi_func]: 491520000
[   10.643752] cam clk[ccic_func]: 491520000
[   10.643756] cam clk[ahb_func]: 307200000
[   10.643760] cam clk[axi_func]: 409600000
[   10.643764] spacemit_ccic d420a800.cam_ccic: power on
[   10.643824] spacemit_ccic d420a800.cam_ccic: power off
[   10.646556] cam clk[axi_func]: 409600000
[   10.650609] spacemit_ccic d420a000.cam_ccic: power off
[   10.654373] spacemit_ccic d4206000.cam_ccic: power on
[   10.654501] spacemit_ccic d4206000.cam_ccic: power off
[   10.656334] cam clk[csi_func]: 491520000
[   10.656342] cam clk[ccic_func]: 491520000
[   10.656346] cam clk[ahb_func]: 307200000
[   10.656351] cam clk[axi_func]: 409600000
[   10.656355] spacemit_ccic d420a800.cam_ccic: power on
[   10.656425] spacemit_ccic d420a800.cam_ccic: power off
[   10.764893] sa1100-rtc d4010000.rtc: registered as rtc1
[   10.795800] fusb301 0-0025: Device ID = 0x12
[   10.817003] fusb301 0-0025: fusb301 set pwr_mode: 1.5A
[   10.819723] fusb301 0-0025: fusb301 set toggle time: Toggle_35ms
[   10.825745] fusb301 0-0025: fusb301 set mode: Drp_Acc
[   10.830753] fusb301 0-0025: fusb301 set state: Error_Recovery
[   10.836271] fusb301 0-0025: fusb301_detach: Error_Recovery
[   10.842250] fusb301 0-0025: mode[0x20]=Drp_Acc, host_cur[0x02], dttime[0x00]
[   10.849323] CAN device driver interface
[   11.464752] raspits-ft5426: raspits_ft5426_work: checking touch ic timeout, -6
[   11.979940] Bluetooth: Core ver 2.22
[   11.980949] NET: Registered PF_BLUETOOTH protocol family
[   11.986162] Bluetooth: HCI device and connection manager initialized
[   11.992517] Bluetooth: HCI socket layer initialized
[   11.997374] Bluetooth: L2CAP socket layer initialized
[   12.002400] Bluetooth: SCO socket layer initialized
[   12.091975] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.160506] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.163775] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   12.175622] faux_driver regulatory: Direct firmware load for regulatory.db failed with error -2
[   12.176034] usbcore: registered new interface driver btusb
[   12.179441] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000b lmp_ver=0b lmp_subver=8852
[   12.181431] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   12.181679] cfg80211: failed to load regulatory.db
[   12.183432] Bluetooth: hci0: RTL: btrtl_initialize: key id 0
[   12.183437] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852bu_fw.bin
[   12.191187] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852bu_config.bin
[   12.234974] Bluetooth: hci0: RTL: cfg_sz 6, total sz 58003
[   12.761436] Bluetooth: hci0: RTL: fw version 0xdbc6b20f
[   14.102675] pci 0004:00:00.0: of_irq_parse_pci: failed with rc=-22
[   14.133552] rtw89_8852be 0004:01:00.0: loaded firmware rtw89/rtw8852b_fw-1.bin
[   14.138241] rtw89_8852be 0004:01:00.0: enabling device (0000 -> 0003)
[   14.156200] rtw89_8852be 0004:01:00.0: Firmware version 0.29.29.15 (6fb3ec41), cmd version 0, type 5
[   14.162683] rtw89_8852be 0004:01:00.0: Firmware version 0.29.29.15 (6fb3ec41), cmd version 0, type 3
[   14.444799] rtw89_8852be 0004:01:00.0: chip rfe_type is 1
[   14.476181] rtw89_8852be 0004:01:00.0: rfkill hardware state changed to enable
[   14.487933] rtw89_8852be 0004:01:00.0 wlP4p1s0: renamed from wlan0
linuxroot: clean, 59278/3743744 files, 2052458/14969600 blocks
boot: clean, 95/38400 files, 55356/153600 blocks
[   14.532971] EXT4-fs: Remounting file system with no journal so ignoring journalled data option
[   14.561573] EXT4-fs (mmcblk0p3): re-mounted 32539e08-a5c0-4084-9f32-0932043d95e3 r/w.
[   14.603912] EXT4-fs (mmcblk0p2): mounted filesystem 5c205338-1b02-4bc9-a396-dc0fe556357f r/w with ordered data mode. Quota mode: none.
setfont: ERROR kdfontop.c:242 put_font_kdfontop: Unable to load such font with such kernel version
/usr/bin/loadkeys: error while loading shared libraries: libxkbcommon.so.0: cannot open shared object file: No such file or directory
INIT: Entering runlevel: 2
Entering multi-user mode...
INIT: version 3.18 reloadinglo net sshd crond firstrun
irradium  (banana-pi-sm10) (ttyS0)
banana-pi-sm10 login:
installation README.TXT
kernel 6.18.3
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260531.img.zst
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260531.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260531.img.zst
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260531.img.zst.sha256
kernel 6.18.3
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260603.img.zst
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260603.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260603.img.zst
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260603.img.zst.sha256
Flash SPI
# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00800000 00001000 "d420c000.spi"
mtd1: 00020000 00001000 "bootinfo"
mtd2: 00080000 00001000 "fsbl"
mtd3: 00010000 00001000 "env"
mtd4: 00100000 00001000 "esos"
mtd5: 00060000 00001000 "opensbi"
mtd6: 005f0000 00001000 "uboot"
# dd if=/boot/bootinfo_spinor.bin of=/dev/mtdblock1
# dd if=/boot/FSBL.bin of=/dev/mtdblock2
# dd if=/boot/boot.scr of=/dev/mtdblock3
# dd if=/boot/esos.itb of=/dev/mtdblock4
# dd if=/boot/fw_dynamic.itb of=/dev/mtdblock5
# dd if=/boot/u-boot.itb of=/dev/mtdblock6
Added usage of boot.src and uEnv.txt. When booting from nor, NVMe and SCSI drives are searched.
U-Boot SPL 2022.10-k3 (Jun 06 2026 - 11:48:14 +0000)
DDR quick boot consume 9ms
[   1.054]
U-Boot 2022.10-k3 (Jun 06 2026 - 11:48:14 +0000)
[   1.057] CPU:   rv64imafdcvh
[   1.059] Model: spacemit k3 com260 ifx board
[   1.064] DRAM:  32 GiB
[   1.099] reset driver probe finish
[   1.289] eSPI not ready, skipping EC probe
[   1.293] Core:  634 devices, 38 uclasses, devicetree: board
[   1.297] WDT:   Started watchdog@d4014000 with servicing (60s timeout)
[   1.302] MMC:   spacemit_sdhci sdh@d4280000: probe done.
[   1.309] sdh@d4280000: 0
[   1.312] Loading Environment from mtdENV... k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26000000Hz
[   1.325] k1x_qspi spi@d420c000: rx buf size:128, tx buf size:256, ahb buf size=512
[   1.333] k1x_qspi spi@d420c000: AHB read enabled
[   1.338] k1x_qspi spi@d420c000: AHB buf size: 512
[   1.342] k1x_qspi spi@d420c000: Speed Change: 26000000 Hz -> 26500000 Hz
[   1.349] SF: Detected gd25lq64c with page size 256 Bytes, erase size 4 KiB, total 8 MiB
[   1.362] OK
[   1.362] In:    serial
[   1.365] Out:   serial
[   1.367] Err:   serial
[   1.370] CTF2301: Start probing ctf2301@4c
[   1.377] Found device 'mipi@d421a800', disp_uc_priv=00000003fbe98520
[   1.380] spacemit_panel_of_to_plat panel lcd_tc358762xbg_dpi_800x480
[   1.401] pll_ctrl_reg0 = 0x3A155555
[   1.402] pll_ctrl_reg1 = 0x4582820B
[   1.405] Panel is lcd_tc358762xbg_dpi
[   1.410] fb=3fe000000, size=800x480
[   1.414] dpi_panel_probe: Warning: cannot get enable GPIO: ret=-2
[   1.529] dpi_panel_probe: Atmel I2C read failed: 0
[   1.530] panel device error -1
[   1.536] Found device 'dp1@cac88000', disp_uc_priv=00000003fbe98460
[   1.697] dp cannot get HPD signal
[   1.697] spacemit_display_init: device 'dpu@c0340000' display won't probe (ret=-1)
[   1.861] dp cannot get HPD signal
[   1.861] display devices not found or not probed yet: -1
[   1.927] Found 4 valid MAC addresses.
[   1.927] TLV item: product_name = k3_com260_ifx
[   1.932] TLV item: serial# = COM3K3321280022
[   1.936] TLV item: ddr_partnumber = MT62F4G32D8DV
[   1.942] spacemit reboot: read PMIC reg 0xab value 0xf0
[   1.947] SRAM cleared: addr=0xc0800000 size=0x80000
[   2.091] ufs: bRefClkFreq current=0 expected=0
[   2.146] ufs-spacemit_k3 ufs@c0e00000: [RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[   2.177] pcie_dw_spacemit pcie@80000000: Port0 has no device detect gpio
[   2.191] Now int init_x2_puphy...
[   2.191] waiting pll lock...
[   2.194] PHY PLL Locked.
[   2.206] Now int init_x2_puphy...
[   2.206] waiting pll lock...
[   2.209] PHY PLL Locked.
[   2.211] pcie_dw_spacemit pcie@80000000: pcie config device cmd in rc mode: 0x3bf
[   3.320] PCIE-0: Link down
[   3.335] Now int init_x1_puphy...
[   3.335] waiting pll lock...
[   3.338] PHY PLL Locked.
[   3.341] pcie_dw_spacemit pcie@80c00000: pcie config device cmd in rc mode: 0x33f
[   4.449] PCIE-1: Link down
[   4.449] MMC Device 2 not found
[   4.451] Bus dwc3@81400000: No USB maximum speed specified. Using super speed
[   4.460] k3-usb3-phy phy@81f00000: k3 usb3 phy enter...
[   4.469] mv_usb_phy phy@81500000: k1x-ci-usb-phy-probe: Enter...
[   4.472] k3-usb3-phy phy@81f00000: Update Combo Mode 20 to USB Mode
[   4.478] k3-usb3-phy phy@81f00000: PUPHY Rx Reg Configured
[   4.484] k3-usb3-phy phy@81f00000: PHY version: 0x302 init as USB3 mode
[   4.490] dwc3-generic-host dwc3@81400000: this is a DesignWare USB3 DRD Core
[   4.497] Register 2000140 NbrPorts 2
Starting the controller
[   4.503] USB XHCI 1.10
[   4.505] scanning bus dwc3@81400000 for devices... devnum=1 poweron: query_delay=100 connect_timeout=1100
[   4.532] start port scan
[   5.019] devnum=2 poweron: query_delay=350 connect_timeout=1350
[   5.191] devnum=3 poweron: query_delay=350 connect_timeout=1350
[   6.541] 4 USB Device(s) found
[   6.541]        scanning usb for storage devices... 0 Storage Device(s) found
[   6.548] MMC Device 2 not found
[   6.553] Autoboot in 0 seconds
[   6.564] Loading K3 Environment device: nor
[   6.565] Scan device: nvme
[   6.575] pcie_dw_spacemit pcie@80000000: Port0 has no device detect gpio
[   6.578] pcie_dw_spacemit pcie@80000000: pcie config device cmd in rc mode: 0x3bf
[   7.687] PCIE-0: Link down
[   7.691] pcie_dw_spacemit pcie@80c00000: pcie config device cmd in rc mode: 0x33f
[   8.797] PCIE-1: Link down
[   8.797] Check device: nvme
[   8.799] Looking bootloader for device: nvme
[   8.803] Couldn't find partition nvme 0:0
[   8.807] Couldn't find partition nvme 0:0
[   8.811] Couldn't find partition nvme 0:1
[   8.815] Couldn't find partition nvme 0:1
[   8.819] Couldn't find partition nvme 0:2
[   8.823] Couldn't find partition nvme 0:2
[   8.826] Scan device: scsi
[   8.829] scanning bus for devices...
[   8.844]   Device 0: (0:0) Vendor: KINGSTON Prod.: TY7B-128 Rev: 0004
[   8.847]             Type: Hard Disk
[   8.851]             Capacity: 122136.0 MB = 119.2 GB (31266816 x 4096)
[   8.857] Check device: scsi
[   8.860] Looking bootloader for device: scsi
[   8.865] Loading from device: scsi  disk: 0  part: 2
[   8.870] 3113 bytes read in 1 ms (3 MiB/s)
[   8.873] ## Executing script at 102000000
[   8.877] Boot script loaded from scsi 0:2
[   8.881] 134 bytes read in 0 ms
[   8.885] 143639 bytes read in 1 ms (137 MiB/s)
[   8.929] 33802752 bytes read in 40 ms (805.9 MiB/s)
[   8.931] dtb_bootargs=earlycon=sbi console=ttyS0,115200 random.trust_bootloader=1 unaligned_scalar_speed=fast unaligned_vector_speed=fast
[   8.943] Failed to load 'dtb/spacemit/overlay/spacemit-fixup.scr'
[   9.020] 59302619 bytes read in 71 ms (796.6 MiB/s)
[   9.022] Moving Image from 0x140000000 to 0x102200000, end=1042c7000
[   9.034] ## Flattened Device Tree blob at 138000000
[   9.035]    Booting using the fdt blob at 0x138000000
[   9.141]    Loading Ramdisk to 3f84db000, end 3fbd692db ... OK
[   9.237]    Loading Device Tree to 00000003f844f000, end 00000003f84dafff ... OK
Starting kernel ...
[   9.291] Removing MTD device #0 (nor0) with use count 1
[    0.222085] db_root: cannot open: /etc/target
[    0.707893] Timer 0: loop_delay_fastclk is 26
[    0.719614] ufshcd-spacemit c0e00000.ufshc: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    1.404392] dpu_parse_dt, read hclk failed from dts!
[    1.784925] [drm:rpi_touchscreen_probe] *ERROR* rpi_touchscreen_probe: I2C read failed: -6
[    1.841826] imx219-simple 5-0010: imx219-test: I2C read failed, reg=0x0, ret=-6
[    1.846396] imx219-simple 5-0010: imx219-test: sensor detect failed: -6
[    1.903572] ov5647-simple 5-0036: ov5647-test: I2C read failed, reg=0x300a, ret=-6
[    1.908400] ov5647-simple 5-0036: ov5647-test: sensor detect failed: -6
[    1.916431] ov5640-max96724-max9295 5-003c: ov5640-gmsl: i2c read failed slave=0x27 reg=0x0000 ret=-6
Successfully mounted device UUID=ab229502-a7f5-4242-8794-814c71a816ac
[    8.391263] pci 0004:00:00.0: of_irq_parse_pci: failed with rc=-22
/dev/sda3: clean, 266474/7643136 files, 7311892/30564096 blocks
[    9.980618] raspits-ft5426: raspits_ft5426_work: checking touch ic timeout, -6
Starting services: sysklogd lo net wlan sshd crond alsa dbus elogind lightdm
Added boot from USB
U-Boot 2022.10-k3 (Jun 06 2026 - 14:55:01 +0000)
[   1.056] CPU:   rv64imafdcvh
[   1.063] DRAM:  32 GiB
[   1.288] eSPI not ready, skipping EC probe
[   1.292] Core:  634 devices, 38 uclasses, devicetree: board
[   1.301] MMC:   spacemit_sdhci sdh@d4280000: probe done.
[   1.308] sdh@d4280000: 0
[   1.311] Loading Environment from mtdENV... k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26000000Hz
[   1.332] k1x_qspi spi@d420c000: AHB read enabled
[   1.337] k1x_qspi spi@d420c000: AHB buf size: 512
[   1.341] k1x_qspi spi@d420c000: Speed Change: 26000000 Hz -> 26500000 Hz
[   1.348] SF: Detected gd25lq64c with page size 256 Bytes, erase size 4 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
[   1.361] OK
[   1.362] In:    serial
[   1.364] Out:   serial
[   1.366] Err:   serial
[   1.376] Found device 'mipi@d421a800', disp_uc_priv=00000003fbe98520
[   1.401] pll_ctrl_reg1 = 0x4582820B
[   1.409] fb=3fe000000, size=800x480
[   1.413] dpi_panel_probe: Warning: cannot get enable GPIO: ret=-2
[   1.528] dpi_panel_probe: Atmel I2C read failed: 0
[   1.535] Found device 'dp1@cac88000', disp_uc_priv=00000003fbe98460
[   1.696] dp cannot get HPD signal
[   1.696] spacemit_display_init: device 'dpu@c0340000' display won't probe (ret=-1)
[   1.860] dp cannot get HPD signal
[   1.860] display devices not found or not probed yet: -1
[   1.926] Found 4 valid MAC addresses.
[   1.931] TLV item: serial# = COM3K3321280022
[   1.935] TLV item: ddr_partnumber = MT62F4G32D8DV
[   1.941] spacemit reboot: read PMIC reg 0xab value 0xf0
[   1.946] SRAM cleared: addr=0xc0800000 size=0x80000
[   2.088] ufs: bRefClkFreq current=0 expected=0
[   2.143] ufs-spacemit_k3 ufs@c0e00000: [RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[   2.174] pcie_dw_spacemit pcie@80000000: Port0 has no device detect gpio
[   2.188] Now int init_x2_puphy...
[   2.188] waiting pll lock...
[   2.191] PHY PLL Locked.
[   2.203] Now int init_x2_puphy...
[   2.204] waiting pll lock...
[   2.206] PHY PLL Locked.
[   2.209] pcie_dw_spacemit pcie@80000000: pcie config device cmd in rc mode: 0x3bf
[   3.317] PCIE-0: Link down
[   3.332] Now int init_x1_puphy...
[   3.332] waiting pll lock...
[   3.335] PHY PLL Locked.
[   3.338] pcie_dw_spacemit pcie@80c00000: pcie config device cmd in rc mode: 0x33f
[   4.446] PCIE-1: Link down
[   4.446] MMC Device 2 not found
[   4.448] Bus dwc3@81400000: No USB maximum speed specified. Using super speed
[   4.457] k3-usb3-phy phy@81f00000: k3 usb3 phy enter...
[   4.466] mv_usb_phy phy@81500000: k1x-ci-usb-phy-probe: Enter...
[   4.469] k3-usb3-phy phy@81f00000: Update Combo Mode 20 to USB Mode
[   4.475] k3-usb3-phy phy@81f00000: PUPHY Rx Reg Configured
[   4.481] k3-usb3-phy phy@81f00000: PHY version: 0x302 init as USB3 mode
[   4.487] dwc3-generic-host dwc3@81400000: this is a DesignWare USB3 DRD Core
[   4.494] Register 2000140 NbrPorts 2
[   4.500] USB XHCI 1.10
[   4.502] scanning bus dwc3@81400000 for devices... devnum=1 poweron: query_delay=100 connect_timeout=1100
[   4.529] start port scan
[   4.788] devnum=2 poweron: query_delay=350 connect_timeout=1350
[   5.176] devnum=3 poweron: query_delay=350 connect_timeout=1350
[   6.526] 5 USB Device(s) found
[   6.526]        scanning usb for storage devices... 1 Storage Device(s) found
[   6.874] MMC Device 2 not found
[   6.886] Autoboot in 0 seconds
[   6.896] Loading K3 Environment device: nor
[   6.897] Scan device: usb
[   6.899] Check device: usb
[   6.902] Looking bootloader for device: usb
[   6.918] Loading from device: usb  disk: 0  part: 2
[   6.937] 3113 bytes read in 2 ms (1.5 MiB/s)
[   6.938] ## Executing script at 102000000
[   6.942] Boot script loaded from usb 0:2
[   6.950] 175 bytes read in 1 ms (170.9 KiB/s)
[   6.982] 143639 bytes read in 27 ms (5.1 MiB/s)
[  10.040] 33802752 bytes read in 3042 ms (10.6 MiB/s)
[  10.043] dtb_bootargs=earlycon=sbi console=ttyS0,115200 random.trust_bootloader=1 unaligned_scalar_speed=fast unaligned_vector_speed=fast
[  10.057] Failed to load 'dtb/spacemit/overlay/spacemit-fixup.scr'
[  16.501] 59302619 bytes read in 6436 ms (8.8 MiB/s)
[  16.505] Moving Image from 0x140000000 to 0x102200000, end=1042c7000
[  16.515] ## Flattened Device Tree blob at 138000000
[  16.517]    Booting using the fdt blob at 0x138000000
[  16.622]    Loading Ramdisk to 3f84d7000, end 3fbd652db ... OK
[  16.717]    Loading Device Tree to 00000003f844b000, end 00000003f84d6fff ... OK
Starting kernel ...
[  16.772] Removing MTD device #0 (nor0) with use count 1
[    0.224545] db_root: cannot open: /etc/target
[    0.644761] Timer 0: loop_delay_fastclk is 26
[    0.656592] ufshcd-spacemit c0e00000.ufshc: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    1.404261] dpu_parse_dt, read hclk failed from dts!
[    1.781742] [drm:rpi_touchscreen_probe] *ERROR* rpi_touchscreen_probe: I2C read failed: -6
[    1.838773] imx219-simple 5-0010: imx219-test: I2C read failed, reg=0x0, ret=-6
[    1.843353] imx219-simple 5-0010: imx219-test: sensor detect failed: -6
[    1.900602] ov5647-simple 5-0036: ov5647-test: I2C read failed, reg=0x300a, ret=-6
[    1.905434] ov5647-simple 5-0036: ov5647-test: sensor detect failed: -6
[    1.913549] ov5640-max96724-max9295 5-003c: ov5640-gmsl: i2c read failed slave=0x27 reg=0x0000 ret=-6
[    4.173993] udevd[350]: failed to execute '/usr/sbin/nfsrahead' '/usr/sbin/nfsrahead 8:16': No such file or directory
Successfully mounted device /dev/sdb3
[   10.333199] raspits-ft5426: raspits_ft5426_work: checking touch ic timeout, -6
[   47.237678] pci 0004:00:00.0: of_irq_parse_pci: failed with rc=-22
linuxroot: clean, 58028/866656 files, 1885429/3466240 blocks
Starting services: sysklogd lo net sshd crond
kernel 6.18.3
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260606.img.zst
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.3-build-20260606.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260606.img.zst
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.3-build-20260606.img.zst.sha256
kernel 6.18.38
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.38-build-20260713.img.zst
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.38-build-20260713.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.38-build-20260713.img.zst
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.38-build-20260713.img.zst.sha256
Unfortunately, my board has died and will no longer turn on.
It really looks like a power-related issue.
kernel 6.18.58
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.58-build-20261023.img.zst
irradium-3.8-riscv64-core-banana_pi_sm10-6.18.58-build-20261023.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.58-build-20261023.img.zst
irradium-3.8-riscv64-xfce-banana_pi_sm10-6.18.58-build-20261023.img.zst.sha256
