take kernel-k1#236.6.72-1.pkg.tar.gz unpack move /lib to /lib rename the files in the unpacked /boot folder similarly to the existing /boot and move them there.
You are awesome! It works very nicely, thank you
Just a sidenote: There is no sound device present in the system. Would it be compliated to make it work? ![]()
need to add module loading:
modprobe spacemit_card
modprobe spacemit_i2s
modprobe spacemit_pcm
modprobe snd_soc_es8323
cat /proc/asound/cards
Yesss – sound works again
(Only jack output; no HDMI or BT headset output… but I think I can live with that…
Thank you yet again!
HDMI
modprobe spacemit-hdmiaudio
Yeah, I tried that; Unfortunalety that (in itself) does not add a hdmi sound device ![]()
[installation README.TXT
kernel 6.13.5
for overclocking 1.8ghz you need to enable boost:
echo 1 > /sys/devices/system/cpu/cpufreq/boost
echo userspace > /sys/devices/system/cpu/cpufreq/policy0/scaling_governor
echo 1800000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed
irradium-3.7-riscv64-core-banana_pi_f3-6.13.5-build-20250306.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.13.5-build-20250306.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.5-build-20250306.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.5-build-20250306.img.zst.sha256
kernel 6.6.84
irradium-3.7-riscv64-core-banana_pi_f3-6.6.84-build-20250324.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.84-build-20250324.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.84-build-20250324.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.84-build-20250324.img.zst.sha256
kernel 6.14.0
irradium-3.7-riscv64-core-banana_pi_f3-6.14.0-build-20250326.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.14.0-build-20250326.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.14.0-build-20250326.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.14.0-build-20250326.img.zst.sha256
visionfive 2 JH7110
prt-get: updated successfully
real 69m52.519s
user 248m33.483s
sys 11m3.013s
kernel 6.14.4
irradium-3.8-riscv64-core-banana_pi_f3-6.14.4-build-20250503.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.14.4-build-20250503.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.14.4-build-20250503.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.14.4-build-20250503.img.zst.sha256
kernel 6.14.6
irradium-3.8-riscv64-core-banana_pi_f3-6.14.6-build-20250511.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.14.6-build-20250511.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.14.6-build-20250511.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.14.6-build-20250511.img.zst.sha256
kernel 6.15.0
irradium-3.8-riscv64-core-banana_pi_f3-6.15.0-build-20250601.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.15.0-build-20250601.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.15.0-build-20250601.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.15.0-build-20250601.img.zst.sha256
kernel 6.15.1
irradium-3.8-riscv64-core-banana_pi_f3-6.15.2-build-20250610.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.15.2-build-20250610.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.15.2-build-20250610.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.15.2-build-20250610.img.zst.sha256
kernel 6.16.0
mirror 1, mirror 2, mirror 3, mirror 4
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.0-build-20250801.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.0-build-20250801.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.0-build-20250801.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.0-build-20250801.img.zst.sha256
StarPro64 EIC7700X
real 42m27.966s
user 154m0.664s
sys 8m11.515s
kernel 6.16.4
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-banana_pi_f3-6.16.4-build-20250830.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.16.4-build-20250830.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.16.4-build-20250830.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.16.4-build-20250830.img.zst.sha256
installation README.TXT kernel 6.16.6
irradium-3.8-riscv64-core-banana_pi_f3-6.16.6-build-20250910.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.16.6-build-20250910.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.16.6-build-20250910.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.16.6-build-20250910.img.zst.sha256
kernel 6.17.0
irradium-3.8-riscv64-core-banana_pi_f3-6.17.0-build-20250930.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.17.0-build-20250930.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.17.0-build-20250930.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.17.0-build-20250930.img.zst.sha256
kernel 6.6.110
irradium-3.8-riscv64-core-banana_pi_f3-6.6.110-build-20251008.img.zst
irradium-3.8-riscv64-core-banana_pi_f3-6.6.110-build-20251008.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_f3-6.6.110-build-20251008.img.zst
irradium-3.8-riscv64-xfce-banana_pi_f3-6.6.110-build-20251008.img.zst.sha256
