Irradium (based on crux linux) SpacemiT Banana Pi BPI-CM6 K1 riscv64
irradium - source based Linux distribution CRUX adhering to ideology keep it simple, has its own package system, also supports the port system.
irradium development
packages aarch64
packages riscv64
installation README.TXT
kernel 6.14.2
for overclocking 1.8ghz you need to enable boost:
echo 1 > /sys/devices/system/cpu/cpufreq/boost
echo userspace > /sys/devices/system/cpu/cpufreq/policy0/scaling_governor
echo 1800000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed
mirror 1, mirror 2, mirror 3
not tested on board
irradium-3.7-riscv64-core-banana_pi_cm6-6.14.2-build-20250413.img.zst
irradium-3.7-riscv64-core-banana_pi_cm6-6.14.2-build-20250413.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_cm6-6.14.2-build-20250413.img.zst
irradium-3.7-riscv64-xfce-banana_pi_cm6-6.14.2-build-20250413.img.zst.sha256
kernel 6.14.6
irradium-3.8-riscv64-core-banana_pi_cm6-6.14.6-build-20250511.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.14.6-build-20250511.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.14.6-build-20250511.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.14.6-build-20250511.img.zst.sha256
kernel 6.15.0
irradium-3.8-riscv64-core-banana_pi_cm6-6.15.0-build-20250601.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.15.0-build-20250601.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.15.0-build-20250601.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.15.0-build-20250601.img.zst.sha256
kernel 6.15.2
irradium-3.8-riscv64-core-banana_pi_cm6-6.15.2-build-20250611.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.15.2-build-20250611.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.15.2-build-20250611.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.15.2-build-20250611.img.zst.sha256
kernel 6.16.0
mirror 1, mirror 2, mirror 3, mirror 4
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.0-build-20250801.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.0-build-20250801.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.0-build-20250801.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.0-build-20250801.img.zst.sha256
kernel 6.16.4
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.4-build-20250830.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.16.4-build-20250830.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.4-build-20250830.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.16.4-build-20250830.img.zst.sha256
kernel 6.17.0
irradium-3.8-riscv64-core-banana_pi_cm6-6.17.0-build-20250930.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.17.0-build-20250930.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.17.0-build-20250930.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.17.0-build-20250930.img.zst.sha256
kernel 6.17.9
irradium-3.8-riscv64-core-banana_pi_cm6-6.17.9-build-20251127.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.17.9-build-20251127.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.17.9-build-20251127.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.17.9-build-20251127.img.zst.sha256
kernel 6.18.4
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.4-build-20260110.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.4-build-20260110.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.4-build-20260110.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.4-build-20260110.img.zst.sha256
kernel 6.18.16
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.16-build-20260305.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.16-build-20260305.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.16-build-20260305.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.16-build-20260305.img.zst.sha256
kernel 6.18.33
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.33-build-20260524.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.33-build-20260524.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.33-build-20260524.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.33-build-20260524.img.zst.sha256
kernel 6.18.43
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.43-build-20260809.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.43-build-20260809.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.43-build-20260809.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.43-build-20260809.img.zst.sha256
kernel 6.18.52
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.52-build-20260918.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.52-build-20260918.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.52-build-20260918.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.52-build-20260918.img.zst.sha256
kernel 6.18.59
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.59-build-20261027.img.zst
irradium-3.8-riscv64-core-banana_pi_cm6-6.18.59-build-20261027.img.zst.sha256
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.59-build-20261027.img.zst
irradium-3.8-riscv64-xfce-banana_pi_cm6-6.18.59-build-20261027.img.zst.sha256
