Good afternoon to all colleagues, I leave you the link to a great work by the colleague @woziwrt,.
in which he uses the latest Kernel Version: 6.6.71, working the 3 bands in be mode with all antennas at maximum power in all bands, you can use any country that will work perfectly for you.
optimal speeds, along with mlo in beta phase that also works very well.
banana-bpi-r4-all-related-to-mtk-sdk
I put a link to his last image, but it is better to go through the thread and see his work and all help is always welcome.
BPI-R4_MLO_beta1_17012025.zip
I hope I have helped and any help from you is welcome
Hello, anyone who wants to see a good job @woziwrt on banana pi r4 should visit this thread, no one from the banana team is going to do a similar job for our router.
In this beta 2 release for BPI-R4 and BPI-R4 poe with Ethernet RSS and @rmandrad :elephant: frames and with the user wishes regarding packages extensions mentioned in this thread and received via PM are taken into account
In the next releases I expect finalize of Ethernet LRO, addition of thermal zone and additional WiFi 7 improvement. The road to the final version of WiFi 7 will probably be long because
already implemented in beta 2:
  • Single Wiphy Architecture
  • 320 MHz bandwidth
  • 4096-QAM MCS12, MCS13, MCS14, MCS15
  • WPA3 key management (AKM24)
  • MLO Basic Functionality (Advertisement/Discovery/Setup)
  • Hardware Peak Performance (partially implemented)
and the final release should have the following MLO Post-Setup features:
  • Preamble puncturing (WiFi6E with FCC regularity restriction)
  • WiFi6E Automated Frequency Coordination (AFC)
  • WiFi6E Mgmt Power Enhancement
  • Multi-Link Operation (Advertisement/Discovery/Setup)
  • Multi-Link + Phy Features
  • Multi-Link + Security o With RSNO o Without RSNO (transition mode can be used here) 6GHz (WPA3 only) 6GHz (WPA3/WPA2)
  • Multi-Link + 4-address WDS
  • Multi-Link + Hardware Peak
  • Multi-Link channel access o AP Support: MLSR/EMLSR and MLMR/STR o Support: MLMR/STR
  • Multi-Link + Multiple Legay BSSID
  • Multi-Link Reconfiguration (Add/Remove Link)
  • Multi-Link Statistics (Per-MLD, Per-Link)
  • Multi-Link Channel switching (including ACS/DFS)
  • Link management (Adv-T2LM only)
  • BSS parameter critical update
  • Link management (Neg-T2LM)
  • Multi-Link + 11v MBSS
  • Multi-Link + 11FT
  • Multi-Link + WPS
  • Multi-Link + TWT
  • QoS Management R3
  • EPCS
Please keep in mind that this is still a beta release, which means that it is a release with limited functionality intended for testing
Regards
