How to use Wifi, as client, from BPI-R2 to shared internet to Ethernet interfaces?
Thank you for your answers! It is very unfortunate that I cannot use the MT6625. I got this board because of the integrated wifi chip.
I have couple of wifi card at home, they were meant for other devices, but I’ll try with them, otherwise I’ll get the one you recommend.
I have upported the messy driver for mt6625l long time but changes in linux 6.0 were too much to change it.
But you can my 5.15 lts kernel which has support for it some years as it is a LTS
Sry
I’d like to try that :slight_smile: Where shall I start? Do you have an image somewhere? or do I need to build my own (if so, do you have a doc)? Thanks!
I have some images (debian/ubuntu) posted here in forum but afaik not with 5.15,but you can replace kernel with precompiled from my github-repo (releases page)
Here what I did.
From https://drive.google.com/drive/folders/1oP7jy1KrrIOifvImo2nQ59wx3_9hHkgk I got the image bpi-r2-buster_5.4.58.img. I copied it on the SD Card
sudo dd status=progress if=bpi-r2-buster_5.4.58.img of=/dev/sdb
Then I cloned this repo
git clone https://github.com/frank-w/BPI-Router-Linux
And follow the instructions
sudo apt install gcc-arm-linux-gnueabihf libc6-armhf-cross u-boot-tools bc make ccache gcc libc6-dev libncurses5-dev libssl-dev bison flex
cd BPI-Router-Linux
./build.sh importconfig
./build.sh
Then I extracted the archive
cd
gunzip SD/bpi-r2_5.15.103-main.tar.gz
tar -xf SD/bpi-r2_5.15.103-main.tar
I update the boot partition
mkdir boot
sudo mount /dev/sdb1 boot
sudo rm -r boot/bananapi/bpi-r2/linux
sudo cp -r BPI-BOOT/bananapi/bpi-r2/linux boot/bananapi/bpi-r2
sudo umount boot
Then I add the files for the root partition
mkdir root
sudo mount /dev/sdb2 root
sudo rsync -a BPI-ROOT/ root
sudo umount root
After I boot, I can see the kernel is right one
root@bpi-r2:~# uname -r
5.15.103-bpi-r2-main
root@bpi-r2:~#
But I cannot see the wifi card (I’d expect something like wlan)
root@bpi-r2:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether fa:b2:e0:a1:98:26 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether de:3b:0e:ae:a1:58 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
5: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
    link/ether 08:00:00:00:00:01 brd ff:ff:ff:ff:ff:ff
7: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
8: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
9: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
10: aux@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
root@bpi-r2:~#
Which step did I miss?
I also tried
root@bpi-r2:~# wmt_loader
init combo devic[  881.746261] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 801)
e
[  881.754767] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[  881.762354] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[  881.770865] set current consys chipid (0x7623)
[  881.776676] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [  881.785376] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[  881.800224] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  881.807718] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  881.815137] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[  881.825543] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[  881.832494] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[  881.841448] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [  881.849716] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 801)
30243
failed to init module
root@bpi-r2:~#
But it seems to have an issue and ip link confirms that no new interface appears.
there are 2 commands needed to make it work…look in the wifi.sh i have on my lts-main-branches (5.4-main,5.10-main,5.15-main).
have you loaded the wifi-modules?
I’m sorry, I probably miss something obvious, but I cannot find the wifi.sh in the repo :confused:
Here the list of loaded modules
root@bpi-r2:~# lsmod
Module                  Size  Used by
spidev                 20480  0
lima                   61440  0
gpu_sched              40960  1 lima
spi_mt65xx             20480  0
pwm_mediatek           16384  0
mtk_pmic_keys          16384  0
ip_tables              24576  0
x_tables               36864  1 ip_tables
root@bpi-r2:~#
Ok, this script is not present in 5.15 branch, that’s why I could find it. Thanks.
root@bpi-r2:~# modprobe wlan_gen2
[   37.285353] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   37.317984] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   37.327683] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   37.336386] cfg80211: failed to load regulatory.db
[   37.356189] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[   38.277974] vusb: disabling
[   38.280818] vmc: disabling
[   38.283533] vmch: disabling
[   38.286334] vgp1: disabling
[   38.289241] vcamaf: disabling
[   38.866464] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
Module                  Size  Used by
wlan_gen2            1548288  0
wmt_chrdev_wifi        20480  1 wlan_gen2
cfg80211              753664  1 wlan_gen2
spidev                 20480  0
lima                   61440  0
spi_mt65xx             20480  0
ip_tables              24576  0
init combo devic[   64.976447] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 398)
e
[   64.984973] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[   64.992541] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[   65.001058] set current consys chipid (0x7623)
[   65.006862] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [   65.015539] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[   65.034180] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[   65.041655] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[   65.049119] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[   65.059377] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[   65.066216] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[   65.075243] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [   65.083573] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 398)
30243
root@bpi-r2:~#
It seems there is still an issue.
There is no file regulatory.db on the system. Is such file expected?
root@bpi-r2:~# find / -name "regulatory*"
/sys/devices/platform/regulatory.0
/sys/bus/platform/devices/regulatory.0
root@bpi-r2:~#
I have some wmt entries in dev
root@bpi-r2:~# ls /dev/wmt*
/dev/wmtWifi  /dev/wmtdetect
root@bpi-r2:~#
but it seems not fully working
root@bpi-r2:~# echo 0 >/dev/wmtWifi
root@bpi-r2:~# echo A >/dev/wmtWifi
-bash: echo: write error: Input/output error
root@bpi-r2:~#
Have you started the stp command and is it running?
Look in wifi.sh for more
Regulatory.db is not needed for wifi driver. It is maybe needed for 5g if there is no other way to load regulatory (afair crda works around this and uses builtin regdb from linux kernel).
I use 5.15 (afaik .80) on my router with the internal wifi and debian.
This is what I did
[  219.227826] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  219.266336] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  219.276124] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  219.284950] cfg80211: failed to load regulatory.db
[  219.304175] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[  220.816372] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
init combo devic[  243.928446] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 481)
e
[  243.936815] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[  243.944428] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[  243.953067] set current consys chipid (0x7623)
[  243.958905] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [  243.967550] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[  243.984982] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  243.992513] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  243.999982] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[  244.010457] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[  244.017353] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[  244.026269] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [  244.034492] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 481)
30243
root@bpi-r2:~# /usr/bin/stp_uart_launcher -p /etc/firmware &
[1] 500
open device node[  269.549738] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
 succeed.(Node:/[  269.557929] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623, setting to property(D?)
chiId:0x7623
run SOC chip flow
create pwr on thread ok
root@bpi-r2:~# [  269.565295] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[  269.667753] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  269.683691] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  269.691161] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
enter power on connsys flowpatch name pre-fix:ROMv2_lm_patch
fwVersion:0x8a00
/etc/firmware/ROMv2_lm_patch_1_0_hdr.bin
fw Ver in patch: 0x8a00
read patch info:0x22,0x00,0x06,0x00
gpatchnum = [2]
gdwonseq = [2]
/etc/firmware/ROMv2_lm_patch_1_1_hdr.bin
read patch info:0x21,0x00,0x0e,0xf0
gdwonseq = [1]
cmd(srh_patch) resp(ok)
[  270.254157] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 6e:7f:c2:2b:84:d7 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::6c7f:c2ff:fe2b:84d7/64 scope link
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 16:e3:c9:da:46:30 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
5: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
    inet 192.168.0.11/24 brd 192.168.0.255 scope global lan0
7: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
9: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
10: aux@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
root@bpi-r2:~#
Now that I found your release page, I will try with one from your CI
Steps I followed
Clean old folders
rm -rf BPI-BOOT
rm -rf BPI-ROOT
Get the build
wget https://github.com/frank-w/BPI-Router-Linux/releases/download/CI-BUILD-5.15-main-5.15.103-2023-03-18_2023/bpi-r2_5.15.103-main.tar.gz
gunzip bpi-r2_5.15.103-main.tar.gz
tar -xf bpi-r2_5.15.103-main.tar
Boot partition
mkdir -p boot
sudo umount boot
Root partition
mkdir -p root
sudo umount root
Still no luck
root@bpi-r2:~# uname -a
Linux bpi-r2 5.15.103-bpi-r2-main #1 SMP Sat Mar 18 20:23:21 UTC 2023 armv7l GNU/Linux
root@bpi-r2:~# ip a
    link/ether 56:4e:25:d7:d7:af brd ff:ff:ff:ff:ff:ff
    inet6 fe80::544e:25ff:fed7:d7af/64 scope link
    link/ether c2:6a:d1:00:27:97 brd ff:ff:ff:ff:ff:ff
Module                  Size  Used by
spidev                 20480  0
lima                   61440  0
spi_mt65xx             20480  0
ip_tables              24576  0
[  384.043894] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  384.078283] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  384.085224] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  384.093926] cfg80211: failed to load regulatory.db
[  384.113332] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[  385.444029] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
init combo devic[  442.935929] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 592)
e
[  442.944354] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[  442.951827] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[  442.960522] set current consys chipid (0x7623)
[  442.966322] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [  442.975011] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[  442.989877] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  442.997426] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  443.004856] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[  443.015111] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[  443.022073] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[  443.031039] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [  443.039317] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 592)
30243
[1] 609
open device node[  455.307732] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
 succeed.(Node:/[  455.315921] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623
run SOC chip flow
root@bpi-r2:~# [  455.323922] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[  455.417182] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  455.433112] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  455.440592] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
fwVersion:0x8a00
gpatchnum = [2]
gdwonseq = [2]
gdwonseq = [1]
[  456.002596] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
root@bpi-r2:~#
Since you mention the .80, I try this one.
Clean old folders
rm -rf BPI-BOOT
rm -rf BPI-ROOT
Get the build
wget https://github.com/frank-w/BPI-Router-Linux/releases/download/CI-BUILD-5.15-main-5.15.80-2022-11-28_1508/bpi-r2_5.15.80-main.tar.gz
gunzip bpi-r2_5.15.80-main.tar.gz
tar -xf bpi-r2_5.15.80-main.tar
Boot partition
mkdir -p boot
sudo umount boot
Root partition
mkdir -p root
sudo umount root
It still doesn’t work.
Linux bpi-r2 5.15.80-bpi-r2-main #1 SMP Mon Nov 28 15:08:19 UTC 2022 armv7l GNU/Linux
[  135.731277] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  135.763721] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  135.770683] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  135.779383] cfg80211: failed to load regulatory.db
[  135.799421] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[  137.129955] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
init combo devic[  157.375853] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 452)
e
[  157.384348] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[  157.391759] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[  157.400432] set current consys chipid (0x7623)
[  157.406252] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [  157.414926] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[  157.429727] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  157.437260] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  157.444686] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[  157.454973] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[  157.461939] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[  157.470918] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [  157.479275] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 452)
30243
[1] 473
open device node[  186.257747] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
 succeed.(Node:/[  186.266192] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623
run SOC chip flow
root@bpi-r2:~# [  186.273907] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[  186.367209] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  186.383158] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  186.390631] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
fwVersion:0x8a00
gpatchnum = [2]
gdwonseq = [2]
gdwonseq = [1]
[  186.951212] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
    link/ether de:87:5b:45:b4:40 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::dc87:5bff:fe45:b440/64 scope link
    link/ether 36:fe:97:44:1d:11 brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~#
I don’t know what am I missing :frowning:
Ok, I have a clue on which steps I’m missing. I tried the kernel 5.10 and I managed to get the AP mode. From wifi.sh, I understood that I need to write something the device wmtWifi. So 0 is to reset the device, A for AP mode. What am I suppose to write to get the wifi working as client? I stupidly write 1 and I think I’m into something :slight_smile:
root@bpi-r2:~# echo 1 >/dev/wmtWifi
[  455.810358] [MTK-WIFI] WIFI_open: WIFI_open: major 155 minor 0 (pid 395)
[  455.817143] [MTK-WIFI] WIFI_write: WIFI_write 1
[  455.817143]
[  455.862938] kalFirmwareImageMapping firmware size 225840
[  456.901646] DEBUG: Passed wlanNetRegister 2264 devname:mt6625_%d
[  456.908748] DEBUG: Passed wlanNetRegister 2273 devname:mt6625_0 (need to be used everywhere "wlan0" is used)
[  456.918804] [MTK-WIFI] register_set_p2p_mode_handler: (pid 437) register set p2p mode handler 99402b16
[  456.928326] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
[  456.934160] [MTK-WIFI] WIFI_close: WIFI_close: major 155 minor 0 (pid 395)
root@bpi-r2:~# ip a
    link/ether b6:e9:7c:8b:21:27 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::b4e9:7cff:fe8b:2127/64 scope link
3: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
6: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
11: mt6625_0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:08:22:b2:64:02 brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~#
I rebooted and configured the interface
auto mt6625_0
iface mt6625_0 inet static
   address 192.168.1.19
   netmask 255.255.255.0
   gateway 192.168.1.1
   wpa-ssid XXXX
   wpa-psk XXXX
   wpa-key-mgmt WPA-PSK
   wpa-group CCMP
   wpa-auth-alg OPEN
   wpa-proto WPA RSN
   wpa-scan-ssid 1
But still doesn’t work
init combo devic[   60.809529] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 414)
e
[   60.817997] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[   60.825412] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[   60.834123] set current consys chipid (0x7623)
[   60.839973] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [   60.848622] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[   60.869537] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[   60.877021] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[   60.884482] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[   60.894932] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[   60.901902] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[   60.910879] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [   60.919055] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 414)
30243
[1] 427
open device node[   68.402263] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
 succeed.(Node:/[   68.410482] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623
run SOC chip flow
root@bpi-r2:~# [   68.417816] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[   68.510588] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[   68.526512] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[   68.533992] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
fwVersion:0x8a00
gpatchnum = [2]
gdwonseq = [2]
gdwonseq = [1]
[   69.120181] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
[   91.058031] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   91.089966] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   91.099716] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   91.108442] cfg80211: failed to load regulatory.db
[   91.124199] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
    link/ether 16:36:82:d3:f5:4f brd ff:ff:ff:ff:ff:ff
3: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
6: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
7: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
[  110.280502] [MTK-WIFI] WIFI_open: WIFI_open: major 155 minor 0 (pid 392)
[  110.287400] [MTK-WIFI] WIFI_write: WIFI_write 1
[  110.287400]
[  110.337372] kalFirmwareImageMapping firmware size 225840
[  111.391925] DEBUG: Passed wlanNetRegister 2264 devname:mt6625_%d
[  111.399036] DEBUG: Passed wlanNetRegister 2273 devname:mt6625_0 (need to be used everywhere "wlan0" is used)
[  111.409146] [MTK-WIFI] register_set_p2p_mode_handler: (pid 419) register set p2p mode handler 20491810
[  111.418718] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
[  111.424564] [MTK-WIFI] WIFI_close: WIFI_close: major 155 minor 0 (pid 392)
root@bpi-r2:~# ip a
    inet6 fe80::1436:82ff:fed3:f54f/64 scope link
9: mt6625_0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:08:22:0c:1f:fd brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~# ifup mt6625_0
RTNETLINK answers: File exists
ifup: failed to bring up mt6625_0
root@bpi-r2:~# ip a
9: mt6625_0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    inet 192.168.1.19/24 brd 192.168.1.255 scope global mt6625_0
root@bpi-r2:~#
I never used client mode with the internal wifi,so it is possible that driver is broken here. I renamed the original wlan0 (was hardcoded in driver) to mt6625_0 to avoid clashes with pcie wifi-cards because for ap-mode this is only a control interface as step between to get ap0 interface…maybe for client-mode it does more.
Nah, client mode works fine. But he faces the same regdomain issue I described in the other thread.
Note this:
That is why the interface stays down. The kernel will refuse to use the interface in both AP and client mode in case it thinks there is DFS rule to enforce, regardless whether scan or EEPROM read fails.
As a result, hostapd will fail to start in master/AP mode and interface will stay down in client mode.
I made a patch for this, fixing this issue for both master and client mode.
internal wifi only can do 2.4GHz and imho this does not need regdomain (only 5GHz and up).
Incorrect
                Frequencies:
                        * 2412.0 MHz [1] (20.0 dBm)
                        * 2417.0 MHz [2] (20.0 dBm)
                        * 2422.0 MHz [3] (20.0 dBm)
                        * 2427.0 MHz [4] (20.0 dBm)
                        * 2432.0 MHz [5] (20.0 dBm)
                        * 2437.0 MHz [6] (20.0 dBm)
                        * 2442.0 MHz [7] (20.0 dBm)
                        * 2447.0 MHz [8] (20.0 dBm)
                        * 2452.0 MHz [9] (20.0 dBm)
                        * 2457.0 MHz [10] (20.0 dBm)
                        * 2462.0 MHz [11] (20.0 dBm)
                        * 2467.0 MHz [12] (20.0 dBm)
                        * 2472.0 MHz [13] (20.0 dBm)
                        * 2484.0 MHz [14] (disabled)
                Frequencies:
                        * 5170.0 MHz [34] (disabled)
                        * 5180.0 MHz [36] (23.0 dBm)
                        * 5190.0 MHz [38] (disabled)
                        * 5200.0 MHz [40] (23.0 dBm)
                        * 5210.0 MHz [42] (disabled)
                        * 5220.0 MHz [44] (23.0 dBm)
                        * 5230.0 MHz [46] (disabled)
                        * 5240.0 MHz [48] (23.0 dBm)
                        * 5260.0 MHz [52] (20.0 dBm)
                        * 5280.0 MHz [56] (20.0 dBm)
                        * 5300.0 MHz [60] (20.0 dBm)
                        * 5320.0 MHz [64] (20.0 dBm)
                        * 5500.0 MHz [100] (26.0 dBm)
                        * 5520.0 MHz [104] (26.0 dBm)
                        * 5540.0 MHz [108] (26.0 dBm)
                        * 5560.0 MHz [112] (26.0 dBm)
                        * 5580.0 MHz [116] (26.0 dBm)
                        * 5600.0 MHz [120] (26.0 dBm)
                        * 5620.0 MHz [124] (26.0 dBm)
                        * 5640.0 MHz [128] (26.0 dBm)
                        * 5660.0 MHz [132] (26.0 dBm)
                        * 5680.0 MHz [136] (26.0 dBm)
                        * 5700.0 MHz [140] (26.0 dBm)
                        * 5745.0 MHz [149] (13.0 dBm)
                        * 5765.0 MHz [153] (13.0 dBm)
                        * 5785.0 MHz [157] (13.0 dBm)
                        * 5805.0 MHz [161] (13.0 dBm)
                        * 5825.0 MHz [165] (13.0 dBm)
                        * 5845.0 MHz [169] (disabled)
                        * 5865.0 MHz [173] (disabled)
                        * 5920.0 MHz [184] (disabled)
                        * 5940.0 MHz [188] (disabled)
                        * 5960.0 MHz [2] (disabled)
                        * 5980.0 MHz [6] (disabled)
                        * 6000.0 MHz [10] (disabled)
                        * 6020.0 MHz [14] (disabled)
                        * 6040.0 MHz [18] (disabled)
                        * 6060.0 MHz [22] (disabled)
                        * 6080.0 MHz [26] (disabled)
virnik@ap-unimatrix:~$ readlink /sys/class/net/wlan0/device/driver
../../../../../../bus/pci/drivers/ath9k
virnik@ap-unimatrix:~$ readlink /sys/class/net/mt6625_0/device/driver
../../../bus/platform/drivers/mt-wifi
virnik@ap-unimatrix:~$ sudo lshw -class network | grep ath9k
       configuration: broadcast=yes driver=ath9k driverversion=5.15.173-bpi-r2-main firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
       configuration: broadcast=yes driver=ath9k driverversion=5.15.173-bpi-r2-main firmware=N/A ip=10.43.18.98 link=no multicast=yes wireless=IEEE 802.11
virnik@ap-unimatrix:~$ sudo lshw -class network | grep mt-wifi
       configuration: broadcast=yes driver=mt-wifi driverversion=5.15.173-bpi-r2-main multicast=yes
       configuration: broadcast=yes driver=mt-wifi driverversion=5.15.173-bpi-r2-main ip=10.43.17.65 multicast=yes wireless=IEEE 802.11
Tested in AP mode and in client mode. Internal wireless on BananaPi R2 is hybrid, two-interface MAC wireless device. While ath9k loads first and registers wlan0 under its phy0 (which has two layers, one for 2.4GHz, and another for 5GHz), BPi-R2 internal wireless spawns two physical interfaces, both using either wlan0 (if alone with no other wireless card inserted), or as mt6625_0 if wlan0 is already taken. Either way, phy1 and phy2 do represent separate MACs, one for 2.4GHz, and another for 5GHz. The driver switches over to either one depending on configuration and channel requested.
ok, then i remembered wrong…then problem was ac mode missing, only a…but wonder about frequencies go up to 6GHz.
the mt6625_0 is from my changes as the driver created wlanX depending of existing interfaces, but ap-mode always targeted wlan0 and did not startup when another wifi-card was recognized earlier.
not sure why these 2 interfaces are created, but wlan0 should not be created, at least for ap-mode…maybe it is created for client-mode i have not tested in latest versions.
but if you are able to port the driver to 6.1/6.6 maybe some users are happy to keep r2 with internal wifi running…i replaced my r2 with r3 some months ago to have latest lts kernel running.
wlan0 in my case is created by ath9k driver, as I do use Atheros AR958x card for peer link.
Your changes works fine. Haven’t tested AC on internal card, as this will serve guest users from the street, so 802.11n will do fine.
As for 6GHz, it is a matter of modulator in the card and the driver. As I unlocked regdomain limits, all channels the card reports to support are visible. As I am no idiot, I made sure to disable those I won’t ever need. While I do not use DFS and disable it on any router I own, I am picky on frequencies I do use, and occupy. I know local meteo radar frequencies and their directions, as well as military frequencies from nearby military base, so I stay clear from them. Plus, I use tge same channels with the same width and same directions for past 25 years.
But it is ok for within-the-wall testing I was doing.
