How to use Banana Pi BPI-R4 Wifi7 Router SBC to design a Product with Case
If you want to develop your own products and customize all kinds of casings, including metal and plastic, we can fully match
Now need to buy a radiator for the M2 SSD. Again, there are no holes on top of the case. In the previous case, heat from the Wi-Fi and SSD was dissipated through thermal pads on the case. This case with a radiator inside is useless for Wi-Fi, it will overheat without a FAN.
  1. Make holes in the top of the case
  2. More space is needed for the fans at the bottom of the case under the SSD and WiFi
  3. You can also consider adding space on the sides for fans.
imo, they should do a duc like they were/are doing on graphic cards… so you have in/out and that allow fresh air to go on the dissipator directly and push heat directly on opposite side.
