How to read NAND on uboot?
Hi. I want to read NAND memory from the uboot prompt.
In the past, when working on other platforms, I used the nand read command to read data from SDRAM, but it doesn’t work well on R64.
I ran the command below.
BPI-R64> nand info
Device 0: nand0, sector size 1806848 KiB Page size 7 b OOB size 64 b Erase size 1850212352 b BPI-R64> nand read 0x4007FF28 0x00 0x1000
NAND read: device 0 offset 0x0, size 0x1000 undefined instructions pc: [<00200004>] lr: [<7ef43c08>] sp:7cf1bc90 ip:00000000 fp:00000000 r10: 00000000 r9: 7cf1bf40 r8: 00000000 r7:7cf1bce0 r6: 00000000 r5:7ef7a090 r4:00000000 r3:00000000 r2:00000020 r1:00000000 r0:00000000 Flags: nZcv IRQs off FIQs off Mode SVC_32 Resetting CPU…
Please advise to me. Thank you.
It would help if you can tell where your U-Boot version comes from and which version it is.
Use code block when you paste some log…
Some log output
Thanks your advice.
log is below
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.11.13 08:53:38 =~=~=~=~=~=~=~=~=~=~=~=
F0: 102B 0000
F6: 3800 00A0
F3: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0000 0041 [0000]
G0: 0190 0000
T0: 0000 032E [000F]
Jump to BL
UNIVPLL_CON0 = 0xFE000000!!!
mt_pll_init: Set pll frequency for 25M crystal
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic_init] Preloader Start..................
[pmic_init] MT6380 CHIP Code, reg_val = 0, 1:E2  0:E3
[pmic_init] Done...................
Chip part number:7622A
MT7622 Version: 1.2.7, (iPA)
SSC OFF
mt_pll_post_init: mt_get_cpu_freq = 1350000Khz
mt_pll_post_init: mt_get_mem_freq = 1600000Khz
mt_pll_post_init: mt_get_bus_freq = 1119920Khz
[PLFM] Init I2C: OK(0)
[BLDR] Build Time: 20190905-150300
==== Dump RGU Reg ========
RGU MODE:     4D
RGU LENGTH:   FFE0
RGU STA:      0
RGU INTERVAL: FFF
RGU SWSYSRST: 8000
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
 mtk_wdt_mode_config  mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
WDT NONRST=0x20000000
WDT IRQ_EN=0x340003
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
[EMI] MDL number = 2
[EMI] DRAMC calibration start
[EMI] DRAMC calibration end
[EMI]rank0 size: 0x40000000
[MEM] complex R/W mem test pass
RAM_CONSOLE wdt status (0x0)=0x0
[mmc_init]: msdc0 start mmc_init_host() in PL...
[msdc_init]: msdc0 Host controller intialization start
[SD0] Pins mode(1), none(0), down(1), up(2), keep(3)
[SD0] Pins mode(2), none(0), down(1), up(2), keep(3)
[info][msdc_set_startbit 1127] read data start bit at rising edge
[info][msdc_config_clksrc] input clock is 400000kHz
[SD0] Bus Width: 1
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(385) DS(0) RS(0)
[msdc_init]: msdc0 Host controller intialization done
[mmc_init]: msdc0 start mmc_init_card() in PL...
[mmc_init_card]: start
[SD0] Bus Width: 8
[SD0] Switch to High-Speed mode!
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(192) DS(0) RS(0)
[SD0] Bus Width: 8
[SD0] Size: 7456 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15269888), ro(0)
[mmc_init_mem_card 3140][SD0] Initialized, eMMC50
before host->cur_bus_clk(259740)
[SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(1) DS(0) RS(0)
host->cur_bus_clk(50000000)
[mmc_init_card]: finish successfully
[PLFM] Init Boot Device: OK(0)
[GPT_PL](BPI)Parsing Primary GPT now...
[GPT_PL][0]name=tee1, part_id=8, start_sect=0x400, nr_sects=0x200
[GPT_PL][1]name=lk, part_id=8, start_sect=0x600, nr_sects=0x400
[GPT_PL][2]name=nvram, part_id=8, start_sect=0xA00, nr_sects=0x400
[GPT_PL][3]name=rf, part_id=8, start_sect=0xE00, nr_sects=0x200
[GPT_PL][4]name=boot, part_id=8, start_sect=0x1000, nr_sects=0xA000
[GPT_PL][5]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][6]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][7]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][8]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][9]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][10]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][11]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][12]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][13]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][14]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][15]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][16]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][17]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][18]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][19]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][20]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][21]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][22]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][23]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][24]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][25]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][26]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][27]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][28]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][29]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][30]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][31]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][32]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][33]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][34]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][35]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][36]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][37]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][38]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][39]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][40]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][41]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][42]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][43]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][44]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][45]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][46]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][47]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][48]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][49]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][50]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][51]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][52]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][53]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][54]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][55]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][56]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][57]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][58]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][59]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][60]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][61]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][62]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][63]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][64]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][65]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][66]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][67]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][68]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][69]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][70]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][71]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][72]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][73]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][74]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][75]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][76]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][77]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][78]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][79]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][80]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][81]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][82]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][83]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][84]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][85]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][86]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][87]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][88]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][89]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][90]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][91]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][92]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][93]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][94]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][95]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][96]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][97]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][98]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][99]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][100]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][101]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][102]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][103]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][104]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][105]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][106]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][107]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][108]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][109]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][110]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][111]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][112]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][113]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][114]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][115]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][116]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][117]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][118]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][119]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][120]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][121]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][122]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][123]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][124]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][125]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][126]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][127]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL]Success to find valid GPT.
[PART] blksz: 512B
[PART] [0x0000000000080000-0x00000000000BFFFF] "tee1" (512 blocks)
[PART] [0x00000000000C0000-0x000000000013FFFF] "lk" (1024 blocks)
[PART] [0x0000000000140000-0x00000000001BFFFF] "nvram" (1024 blocks)
[PART] [0x00000000001C0000-0x00000000001FFFFF] "rf" (512 blocks)
[PART] [0x0000000000200000-0x00000000015FFFFF] "boot" (40960 blocks)
[PART] [0x0000000000000000-0x00000000000001FF] "" (1 blocks)
[PART] [0x00000062CACAE800-0x0000012D938CE7FF] "unknown" (1701077248 blocks)
Device APC domain init setup:
Domain Setup (0x0)
Domain Setup (0x0)
Device APC domain after setup:
Domain Setup (0x0)
Domain Setup (0x0)
[get_part] part->nr_sects=512, part->info->name=tee1
[get_part] part->nr_sects=1024, part->info->name=lk
[PART] Image with part header
[PART] name : LK
[PART] addr : FFFFFFFFh mode : -1
[PART] size : 364756
[PART] magic: 58881688h
[PART] load "lk" from 0x00000000000C0200 (dev) to 0x41E00000 (mem) [SUCCESS]
[PART] load speed: 11130KB/s, 364756 bytes, 32ms
load lk (ret=0)
[PART] name : atf
[PART] size : 62032
[PART] load "tee1" from 0x0000000000080200 (dev) to 0x43000DC0 (mem) [SUCCESS]
[PART] load speed: 6730KB/s, 62032 bytes, 9ms
load tee1 (ret=0)
[BLDR] bldr load tee part ret=0x0, addr=0x43001000
[get_part] part->nr_sects=1024, part->info->name=nvram
[get_part] part->nr_sects=512, part->info->name=rf
[get_part] part->nr_sects=40960, part->info->name=boot
[BLDR] part_load_raw_part ret=0x0
[BLDR] part_load_images ret=0x0
[BLDR] Others, jump to ATF
[BLDR] jump to 0x41E00000
[BLDR] <0x41E00000>=0xEA00000F
[BLDR] <0x41E00004>=0xE59FF014
U-Boot  (Sep 05 2019 - 16:57:15)
DRAM:  1008 MiB
WARNING: Caches not enabled
NAND:  Recognize SNAND: ID [ef aa ], Device Name [Winbond 1Gb], Page Size [2048]B Spare Size [64]B Total Size [128]MB
[mtk_snand] probe successfully!
128 MiB
dev_num = 1
***size=4096, offset=1310720, blk_start=2560, blk_cnt=8
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
dev_num = 1
Net:   mtk_eth
Uip activated
BPI-R64> nand info
Device 0: nand0, sector size 3801088 KiB
  Page size        14 b
  OOB size         64 b
  Erase size -402653184 b
BPI-R64> nand
nand - NAND sub-system
Usage:
nand info - show available NAND devices
nand device [dev] - show or set current device
nand read - addr off|partition size
nand write - addr off|partition size
    read/write 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
nand read.raw - addr off|partition [count]
nand write.raw - addr off|partition [count]
    Use read.raw/write.raw to avoid ECC and access the flash as-is.
nand erase[.spread] [clean] off size - erase 'size' bytes from offset 'off'
    With '.spread', erase enough for given file size, otherwise,
    'size' includes skipped bad blocks.
nand erase.part [clean] partition - erase entire mtd partition'
nand erase.chip [clean] - erase entire chip'
nand bad - show bad blocks
nand dump[.oob] off - dump page
nand scrub [-y] off size | scrub.part partition | scrub.chip
    really clean NAND erasing bad blocks (UNSAFE)
nand markbad off [...] - mark bad block(s) at offset (UNSAFE)
nand biterr off - make a bit error at offset (UNSAFE)
BPI-R64> nand read ${loadaddr} 0x0 0x1000
pc : [<00200004>]	   lr : [<7ef43c08>]
sp : 7cf1bbb0  ip : 00000000	 fp : 00000000
r10: 00000000  r9 : 7cf1bf40	 r8 : 00000000
r7 : 7cf1bc00  r6 : 00000000	 r5 : 7ef7a090  r4 : 00000000
r3 : 00000000  r2 : 00000020	 r1 : 00000000  r0 : 00000000
Resetting CPU ...
resetting ...
mtk_arch_reset at pre-loader!
F0: 102B 0000
F6: 3800 00A0
F3: 0000 0000
00: 0000 0000
G0: 0190 0000
T0: 0000 0335 [000F]
Jump to BL
RAM_CONSOLE preloader last status: 0x0 0x0 0x0 0x0 0x0 0x0
SSC OFF
RGU MODE:     14
RGU LENGTH:   FFE0
RGU STA:      40000000
RGU INTERVAL: FFF
RGU SWSYSRST: 8000
RGU: g_rgu_satus:2
PL RGU RST: ??
SW reset with bypass power key flag
Find bypass powerkey flag
WDT IRQ_EN=0x340003
RAM_CONSOLE wdt status (0x2)=0x2
[SD0] Bus Width: 1
[SD0] Bus Width: 8
[SD0] Bus Width: 8
type or paste code here
````Preformatted text`
I’ve noticed a strange behavior.
When I insert a MicroSD card into the slot and use the “nand info” command, the NAND information is displayed, but if the MicroSD card isn’t present, no information is displayed.
There’s no correlation between the NAND and the MicroSD card, so this behavior suggests a problem with uboot.
However, it appears that uboot is currently stored on nand, but since I have no way to access it, it seems like even if I rebuild uboot, it won’t update.
I don’t know what to do.
It might be, within these 6 years, someone encountered and fixed this bug by now…
Start with updating your system, or replacing the used image entirely.
OK. I will try it. But. How to update uboot to the emmc? Because this time uboot is on the emmc now. But i don’t know how to update uboot to the emmc.
https://openwrt.org/toh/sinovoip/bananapi_bpi-r64_v1.1
Start with a fresh openwrt on sd-card. From there Install the new openwrt on emmc.
Thanks. your reply. But. I’m already done boot from SD and write image to emmc. I’m want to just use “SPI NAND”. So I’m try to find “How to access SPI NAND”. Thank you.
Is ${loadaddr} a valid number?
Try using the mtd command instead.
Hi. ${loadaddr} is valid address.
@poplinux Any luck with that? You should use mtd instead of nand directly…
