How to get BPI-F3 booting Bainbu 25.04 rev 3.0.1 from nvme drive
Update, those extra 4 partitions on the sd card that don’t register as formatted are part of the boot process. If you copy an sd card, it won’t boot unless you copy the partition labels as well as the contents. Also, I didn’t realize that partition GUIDs are different than the UUID inside a partition. However I found that while copying the partlabels allows a copied sd card to boot, you can’t put those first 4 boot partitions on an NVME drive and expect the machine to boot without a bootloader on SSD or emmc, even if you set the partlabels. I didn’t try copying the partition GUIDs because the partition labels don’t allow booting from NVME - it didn’t seem like a good idea. So, once again, the root drive can be on the NVME, but the bootloader still can’t.
The BPI F3 has a lot of hardware features like that nvme spot on the bottom but it’s not trivial to get it booting from it, and is probably different for every distro.
Some people have gone a very hard road like compiling their own uboot kernel on a different machine.
I’m sticking with the Bianbu distro because it’s supposedly a bit specialized for this processor. I could nerd out about what that means but I’ll spare you. It also means that it recognizes the nvme drive right out of the gate.
Anyway I started booting from the sd image, which is the easiest thing to install.
Then I copied the whole sd card to the nvme drive.
I could have just copied the root partition since I’m not using the boot partition on the nvme. But that does effect things later on like what partition I say to load. The sd has 4 tiny bootloader partitions (that register as unformatted even though they have SOMETHING on them), then a 256 mb boot partition then then root partition, so I’ll be referring to the root partition on the nvme drive as /dev/nvme0n1p6 Note that in order to avoid UUID clashes I changed the UUID of the unused boot partition on the nvme drive. It would have made more sense to delete it.
The unavoidable thing is that I changed the UUID of the root partition on the sd card hoping it loaded root by uuid. That didn’t work but it’s still important that you don’t have two partitions in the system with the same UUID, so it’s unavoidable.
It DOES try load the root partition by UUID, but it can’t seem to get the UUID of an nvme partition that early in the process and I got the message “no uuid available providing old nguid” and it loaded the root partition off of the sd card anyway.
Long story short, you want a line like this:
args=setenv bootargs console=tty1 console=${console} rootwait rootdelay=20 rw earlycon=${earlycon} earlyprintk nosplash rootfstype=ext4 loglevel=8 swiotlb=65536 rdinit=/init root=/dev/nvme0n1p6
in /boot/env_k1-x.txt
But during that boot process the root is passed as a uuid on a command line to init script which is compressed into /boot/initrd.img-6.6.63. Your bootargs go in that command line, but you set the root and it’s set right back root=UUID=… coming right after your own root=. And then it ignores what you wrote, tries by UUID, fails and then reverts back with that nguid.
So I had ALSO to unpack /boot/initrd.img-6.6.63, change init, pack it back up and replace /boot/initrd.img-6.6.63
Also I have to say that google’s gemini AI built into their search was super helpful in telling things to try. You can be working on a version of Linux where you can’t find people who have done what you need to do (at least in English) and has a good grasp of the ways the boot process can go.
Here’s how to unpack that file:
mkdir ~/work && cd ~/work
cp /boot/initrd.img-6.6.63 .
mkdir initrd-tree && cd initrd-tree
zcat ../initrd.img-6.6.63 | cpio -idm
So right up at the root of the directory you just made is a script file called init
Instead of figuring out what sends it commands I changed it so that it only cares about the FIRST time it sees “root=”
So I changed some lines from:
# Parse command line options
# shellcheck disable=SC2013
for x in $(cat /proc/cmdline); do
case $x in init=*) init=${x#init=} ;; root=*) ROOT=${x#root=} if [ -z "${BOOT}" ] && [ "$ROOT" = "/dev/nfs" ]; then BOOT=nfs ;;
to:
ROOT_SET=0
case $x in init=*) init=${x#init=} ;; root=*) if [ $ROOT_SET -eq 0 ]; then ROOT=${x#root=} if [ -z "${BOOT}" ] && [ "$ROOT" = "/dev/nfs" ]; then
BOOT=nfs
fi ROOT_SET=1 fi ;;
Then you have to pack it all back up:
find . | cpio -H newc -o | gzip -9 > ../initrd.img-6.6.63-new
sudo cp ../initrd.img-6.6.63-new /boot/initrd.img-6.6.63
And that seems to do it!
I know there’s some unnecessary things in the bootargs line and I’ve already taken some things I tried and didn’t need out, but when I was playing with do I need THIS do I need THAT, I managed to corrupt the sd card once and had to fix the partition table with gdisk so I decided I’d had enough experimenting.
Gemini gave me this warning:
A Final Warning for the Future:
If you ever run a system update that includes a new Kernel or Initramfs package (e.g., linux-image-spacemit):
  • The update process will likely generate a new initrd.img file.
  • That new file will not have your custom script modifications.
  • Recommendation: Keep a backup of your modified initrd.img-6.6.63 or a copy of your custom init script. If the board suddenly stops booting from NVMe after an update, you will need to repeat the “Unpack → Edit → Repack” process on the new initrd file.
So there’s that.
I tried a bunch of other options that might not have had this drawback, but none of them worked.
One nice thing about running off an nvme is that I made a nice swap file!
  • Update: a note on the step of changing the UUID of directories. Due to a change in tune2fs, trying to change a UUID in gparted is likely to fail. That’s because it refuses to change the UUID on an ext4 partition unless it has been fixed with e2fsck right before.
So (if your device is /dev/sda1) then changing the UUID is:
sudo e2fsck -f /dev/sda1
sudo tune2fs /dev/sda1 -U random
