is there any documentation somewhere on how to run the PCIE2 slot instead of the USB3? I have tried this here:
I get the dmesg message
mtk-pcie 1a140000.pcie: Port2 link down
on r2 the pcie slot and usb3-ports working together…or which pci-slot do you mean?
I mean the one that is led out as a pin header. According to this description it can be used as PCIE via “PIN DEFINE”
Edit: I would like to use the connector similar to this: https://bananapi.gitbook.io/banana-pi-bpi-r2-open-source-smart-router/chapter1/bpi-r2-usb-30-interface
