Hi, where can I find information on how to check the cpu temp of the riscv64 K1 cpu using the terminal? Thanks.
banana-pi-f3 login: root
Password:
Last login: Sun Jul 14 04:52:08 UTC 2024 on tty2
_ _ _
|_| ___ ___ ___ _| ||_| _ _ _____
| || _|| _|| .'|| . || || | || |
|_||_| |_| |__,||___||_||___||_|_|_|
_ _ ___ ___
| |_ ___ ___ ___ ___ ___ ___ |_| | _||_ |
| . || .'|| || .'|| || .'| | . || | | _||_ |
|___||__,||_|_||__,||_|_||__,| | _||_| |_| |___|
|_|
# cputemp
46 Β°C
link to script cputemp
Perfect, just what I was looking for ![]()
Thank you.
I use lm-sensors and bottom. You need this patch Add minimal hwmon support Β· lu-zero/pi-linux@c280d92 Β· GitHub though.
cluster1_thermal-virtual-0
Adapter: Virtual device
temp1: +32.0Β°C (crit = +115.0Β°C)
gpu_thermal-virtual-0
temp1: +33.0Β°C
nvme-pci-10100
Adapter: PCI adapter
Composite: +27.9Β°C (low = -0.1Β°C, high = +82.8Β°C)
(crit = +84.8Β°C)
Sensor 1: +27.9Β°C (low = -273.1Β°C, high = +65261.8Β°C)
cluster0_thermal-virtual-0
top_thermal-virtual-0
temp1: +33.0Β°C
β Memory ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ Temperatures βββββββββββββββββββββββββββββββββββββββββββββ
β100%β ββββββββββββββββββββββββββββSensor(s)β² Temp(t) β
β β βRAM: 5% 0.2GiB/3.7GiBβββ β
β β ββββββββββββββββββββββββββββnvme0 (nvme): Composite 28Β°C β
β β ββnvme0 (nvme): Sensor 1 28Β°C β
β β ββthermal_zone0 (top_thermal) 33Β°C β
β β ββthermal_zone1 (gpu_thermal) 33Β°C β
β β ββthermal_zone2 (cluster0_thermal) 33Β°C β
β β ββthermal_zone3 (cluster1_thermal) 33Β°C β
β β ββ β
β β ββ β
β β ββ β
β β ββ β
β β βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β β ββ Disks ββββββββββββββββββββββββββββββββββββββββββββββββββββ
β β ββDisk(d)β² Mount(m) Used(u) Free(n) Total(t) β
β β ββ β
β β ββ/dev/mmcblk2p5 /boot 187MB 29MB 235MB β
β β ββ/dev/nvme0n1p6 / 73GB 381GB 480GB β
β β ββ β
β β ββ β
β β ββ β
β β ββ β
β β β β €β €β €β €β €β €β €β €β €β €β €β €β €β €β €β €β €ββ β
β 0%β ββ β
β ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ β
β 60s 0sββ β
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
