Documentation:
- 2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi NIC
Where real lane is one minipci slot?
Documentation:
There are 2 lanes in total. The standard minipcie socket only has 1 lane pcie. BPI-R4 uses 4 additional PINs as the second line, which is not standard.
You mean per mpcie socket 2 lanes,right? One per standard and then the 4 additional pins for second…so total of 4 (both slots).
In real-world usage, roughly equivalent to PCIe 3.0 x0.6.
Thanks for the answers. I was interested in this question in connection with the choice of a minipci - pcie adapter.
Where can I find a pinout diagram for mini pci BPI-R4 with extra 4 pin lanes?
There may be recommendations for a common PCIE adapter that does not require modification.
https://wiki.banana-pi.org/Banana_Pi_BPI-R4#Documents
“BPI-R4 Schematic diagram” should be a good place to start
Continuing on the topic:
Do you need to edit .dts/.dtsi files if you want to route 4 lanes from two minipci slots to one PCIEx4 port (adapter)?
Or correct the values in pinctrl-mt7988.c accordingly = mt7988_pcie_*_n3_0_pins,mt7988_pcie_*_n3_0_funcs should be moved to
mt7988_pcie_*_n0_0_* or mt7988_pcie_*_n0_1_*, am I right?
Dts describe hardware,i think you cannot change it here…but information should be in shematic.
Schematically, it is necessary to remove one minipci slot from the system, and transfer the resources - 2 lanes to the neighboring minipci slot. Since the “unnecessary” minipci slot is initialized at startup, and this will always cause errors.
I do not understand the .dts format well, especially the origin of variable names - where they are initially described. This needs to be sorted out.
