Hinder nmap OS Fingerprinting
[ EDIT 1 - updated /etc/nftables.d/99-obfuscate.nft… the prior version messed with IPv6 NDP and ICMP6, which caused IPv6 to drop to link-local only. ]
You can disable TCP Timestamps to make it harder to fingerprint the router’s OS, but that comes with tradeoffs that are unacceptable on faster connections.
But, we can ‘mangle’ all packets to make them generic-looking.
Let’s make all packets exiting the wan interface appear to have the TTL and hop_limit of a Windows computer.
If you issue:
sysctl net.ipv4.ip_default_ttl
… and:
sysctl net.ipv6.conf.all.hop_limit
… you’ll see the ttl and hop_limit are set to the Linux default of 64.
Now, we could try just changing those settings in the configuration files… but the IPv4 settings only apply to packets originating from the router. They completely ignore forwarded traffic (which will have its own TTL or hop_limit based upon the device originating those packets). If a laptop or smartphone sends a packet through the router to the internet, OpenWRT simply decrements that packet’s original TTL by 1. Attackers scanning your WAN can still map out every device behind your router by reading those unaltered, passed-through TTLs.
So let’s set the TTL to 128 (the Windows default). Subtract 1 to account for the router itself, to make it appear as though all packets come from a Windows machine.
First, create the file we’re going to use:
touch /etc/nftables.d/99-obfuscate.nft
Then edit the file:
vi /etc/nftables.d/99-obfuscate.nft
Press i to enter editing mode, the input the following:
chain mangle_out {
        type filter hook postrouting priority mangle; policy accept;
        # 1. Obfuscate wan-oubound IPv4 traffic
        ip ttl set 127
        # 2. Obfuscate wan-outbound IPv6 traffic
        #  while protecting RFC 4861 local protocols
        # (NDP, ICMPv6), which must have hoplimit=255
        ip6 nexthdr != icmpv6 ip6 hoplimit set 127
… press Esc to exit editing mode, then press :wq to save and exit.
Reload the firewall:
fw4 reload
To make sure it works, go to:
https://browserleaks.com/tcp
… you should see:
Initial TTL	128
You can also issue:
sysctl -w net.ipv4.tcp_wmem=4096 65536 4194304
Then:
vi /etc/sysctl.conf
… press i to enter editing mode, then input:
… then press Esc to exit editing mode, then :wq to save and exit.
That sets the default TCP send buffer to mimic Windows behavior.
Note that at:
… I now have a Zardaxt OS fingerprinting scoring of:
Zardaxt OS Scoring	Android (47%), Linux (42%), Windows (27%), macOS (8%), iOS (7%)
… IOW, the OS fingerprinter is completely confused.
