how to install openwrt .bin file to r64?
OpenWRT 21.02.0 don’t work on Banan PI R64 because it use kernel 5.4 witch don’t work with R64 memory you need development snapshot from there https://downloads.openwrt.org/snapshots/targets/mediatek/mt7622/ flash bananapi_bpi-r64-sdcard.img.gz (don’t forget unpack) on sd caard and boot from it (if R64 don’t boot from sd turn boot switch to another position). And you need USB->ttl converter for connect to debug console, otherwise you cann’t see anythink.
got it. thank you:+1:
got it. its good! thank you:+1:
