I am totally new, any similar project has been done? any guide would be graceful.
Maybe you can download a proxmox aarch64 rootfs and replace the one from my image (backup kernel modules first and copy back after rootfs changed). As far as i read it is debian based so it should work…or maybe you can install proxmox in debian itself?
and then run openwrt from a vm? ohhh really… hmmm would save me from needing a sbc in the same case as my r3… but thinking this through, I dont think id want the r3 losing wifi/lan/netwrok performance with more than openwrt running… at least I dont think I wouldnt…
he asked to install proxmox…
anyway you can also install both when using 2 rootfs-partitions and then you can set the right one in uboot by setting root-var.
imho openwrt cannot use virtualisation like lxc…this would be a way to run both
I think here would be a nice place to start:
pimox/pimox7: Proxmox V7 for Raspberry Pi (github.com)
And follow the manual installation.
They need a bullseye as base for install…so he can start with my bullseye image…good catch
Would that allow you to run both simultanously? I think the usecase is to use the BananaPi as both Router/Network device and small Homeserver with somethibng like Yunohost - Which is what i would love to do.
Not sure how these are installed and start services. But basicly you can install lxc/lxd or docker to run multiple containers simultanously.
I just wonder if anyone tried install pimox7 on any of banana-pi devices?
