GPIO Library for BPI-R3
Hello,
as I want to read from a DHT21 sensor, I would like to know if there is a working gpio library for the Banana Pi BPI-R3 like wiringpi or gpio zero for the raspberry pi.
Thanks a lot, best regards David
Sorry, BPI-R3 have no gpio library, But you may directly access the gpio from script or code. the path: /sys/class/gpio/
  1. export GPIO, echo xxx > export
  2. setup the direction output or input: echo out > gpioxxx/direction, echo in > gpioxxx/direction
  3. write or read value : echo xxx > gpioxxx/value, cat gpioxxx/value
Thanks, yes, I already control some device with this method, but now I would like to read a DHT21 sensor and this requires exact timing, which is not possible with the sysfs (shell) method.
Why not use a i2c temperature sensor, for example " MCP9808 High Accuracy I2C Temperature Sensor"
https://www.adafruit.com/product/1782
Or: “AHT20 I2C Industrial Grade Temperature & Humidity Sensor”
https://www.aliexpress.com/i/1005007798524783.html
Already ordered one yesterday, question was because I already had a DHT21 laying around here. But I will go the I2C-route, thanks!
I am working bananapi r3, want to use the 26-pin header to connect a proximity sensor and OLED, but my I2C address is not detected. I tried all the pins no positive outcome. please is there something I am doing wrong
This is the python code I used to get the temperature and humidity from the sensor:
Other than this, I can’t help you unfortunately.
