I’m completing the instructions on how to build an image for the bpi-f3 in Gentoo from the ground up:
u-boot and opensbi right now do not have an ebuild, I’m using the latest bianbu forks for them
linux-6.1.15 linux-6.6.63 + vendor support is also externally built, with patches to enable sensors.
I leveraged crossdev directly to make building all faster.
Since gcc-15 might autovectorize RVV1.0 I’ll try again making a very experimental image enabling the vector extension and setting the vl to 256 since that’s what the CPU supports.
Cheers for your work. I got Gentoo working on mine a couple of days ago.
Thought id check your image out to see if I had missed anything obvious, but /etc/portage is empty? is this to be expected? I admit ive not booted it and just mounted it via kpartx to have a look but was curious.
The image is incomplete since I wanted to make sure it booted and didn’t populate it with the bits catalyst adds, it is missing the make.conf since it got created as a crossdev experiment.
Hopefully I’ll manage to complete it during this weekend.
If you have a working rootfs you may just update the kernel and if you want to risk a bit more try rebuilding with CFLAGS=-O3 -march=rv64gcv_zvl256b.
Quick question though, you had any luck getting X working? llvm 18 doesnt compile and 17 does but spits out a load of errors that I need to try and figure out.
I got to test a bit more and I suggest to stay clear of rv64gcv_zvl256b, it seems to produce code that assumes it is ok to unaligned vector loads when it is not.
For those curious here is the upstream bug for gcc-14.
I updated a bit the build scripts and I have a bit more complete image here, help in refining both the image and the scripts welcome, but it should work well enough to install Gentoo in the board.
here an up to date version based on bianbu-1.0.12, it should work on the 16GB-ram boards (if somebody can try please report back :)) Since the linux-6.6 version seems to have better performances I removed all the other images.
Since I produce also the binpackages here you can find those produced while assembling the image. It makes very quick to update an already running system.
