I have been running successfully several python scripts to drive the uart and some GPIO pins on the above setup. This required no special configuration.
I now need to drive an OLED display using the I2C pins 2 and 5. On the RPI one enables this configuration using raspi-config but there seems to be no equivalent on MATE. How are such options enabled on the M5 unless of course they are always enabled from the start?
I am disappointed that Bananapi personnel do not offer replies to such simple and basic problems. I thought the idea of having a forum is precisely that of a meeting place where such issues get discussed.
The main idea of producing SBC’s sporting a 40 pin connector to compete with the raspberry pi is to actually allow users to configure these pins…just like on the raspberry pi.
From further experimentation it results that pins 3 and 5 are setup by default as i2c pins not as indicated in the wiki as gpiox_17 and gpiox_18!
What if one needs a further set of i2c pin such as pins 27 and 28?
you should apply the i2c device tree overlay to enable i2c function, phy pin3 and phy pin5 is GPIOX_17 and GPIOX_18, apply i2c0.dtbo to enable this i2c, phy pin 27 and pin 28 is GPIOA_14 and GPOA_15, apply i2c1.dtbo to enable this i2c.
Thank you for your reply. However I am afraid the info in the wiki is very limited. In my system 12c0 is enabled by default. Is this because the file /boot/boot.ini contains the line:
setenv overlays “i2c0 spio0 uart1” ?
If I want to reuse pin 3 an 5 as standard I/O pins do I simply replace that line with:
setenv overlays “spio0 uart1”
and reboot?
Finally the directory /boot/overlays/ contains many .dtbo files i.e.:
root@bananapi:~# ls /boot/overlays/
custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo
ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo
hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo
hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo
i2c0.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo
i2c1.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo
pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
I am assuming these are all the possible variations. Some of them are simple to understand. But what about options like hifi_pcm5122.dtbo? How does one learn how to use that?
