Hello! Thank you for offering to help and sorry for the delay in replying.
I was able to successfully install bianbu-23.10-desktop-k1-v1.0-release-20240530222811
using the flashserver.exe
file that you provided. I have no clue what the issue was and why titanflasher didn’t work. I had started using the board by booting using the SD card, but I’m glad I can finally use the on-board eMMC.
It would be good to know what the issue with titanflasher is, though, because that doesn’t work and is listed as the only way to interact with the eMMC on the official web site. (It would be good to have a link to flashserver.exe
and its usage instructions on the main page for emergencies and as an alternative!)
Even using the flashserver.exe
file you provided caused some errors (which is why I have attached the log below), but the flashing succeeded nonetheless and it hasn’t causes any issues so far. I have been able to connect to the network, update Bianbu OS, use SSH, and have been able to install and use Git as well.
C:\Users\redacted\Downloads\bianbu-23.10-desktop-k1-v1.0-release-20240530222811>.\flashserver.exe --debug
_____ _ _ _____ _ _
|_ _|(_)| |_ __ _ _ __ | ___|| | __ _ ___ | |__ ___ _ __
| | | || __| / _` || '_ \ | |_ | | / _` |/ __|| '_ \ / _ \| '__|
| | | || |_ | (_| || | | || _| | || (_| |\__ \| | | || __/| |
|_| |_| \__| \__,_||_| |_||_| |_| \__,_||___/|_| |_| \___||_|
__ __ _ ____ _ _ _
\ \ / / / | |___ \ / || |__ ___ | |_ __ _
\ \ / / | | __) || || '_ \ / _ \| __| / _` |
\ V / | | _ / __/ | || |_) || __/| |_ | (_| |
\_/ |_|(_)|_____||_||_.__/ \___| \__| \__,_|
--- Available ports:
--- 1: 1-2 'fastboot VID:PID=0x361c:0x1001 SER=dfu-device'
--- Enter port index or full name: 1
---》开始刷机
执行 fastboot getvar version-brom
1.0
刷机总进度: 2%: ▓
执行 fastboot stage factory/FSBL.bin
刷机总进度: 4%: ▓▓
002cb20
执行 fastboot continue
刷机总进度: 6%: ▓▓▓Traceback (most recent call last):
File "flashboot\source\common.py", line 186, in BulkWrite
File "usb1\__init__.py", line 1389, in bulkWrite
File "usb1\__init__.py", line 1358, in _bulkTransfer
File "usb1\__init__.py", line 127, in mayRaiseUSBError
File "usb1\__init__.py", line 119, in raiseUSBError
usb1.USBErrorPipe: LIBUSB_ERROR_PIPE [-9]
During handling of the above exception, another exception occurred:
File "flashboot\source\exceptionhandler.py", line 28, in warp_func
File "flashboot\source\fastbootaction.py", line 124, in fastboot_stage
File "flashboot\source\fastboot.py", line 469, in Download
File "flashboot\source\fastboot.py", line 98, in SendCommand
File "flashboot\source\fastboot.py", line 203, in _Write
File "flashboot\source\common.py", line 189, in BulkWrite
adb.usb_exceptions.WriteFailedError: Could not send data to [1, 2] (timeout 100000ms): LIBUSB_ERROR_PIPE [-9]
执行 fastboot stage u-boot.itb
debug info:
reconnect fastboot device...
刷机总进度: 8%: ▓▓▓▓
刷机总进度: 9%: ▓▓▓▓
刷机总进度: 11%: ▓▓▓▓▓
执行 fastboot getvar mtd-size
NULL
刷机总进度: 13%: ▓▓▓▓▓▓
执行 fastboot getvar blk-size
universal
刷机总进度: 15%: ▓▓▓▓▓▓▓
开始匹配分区表: ['partition_{size0}.json', 'partition_{size1}.json']
匹配原始分区表: partition_universal.json
分区表匹配结果为: partition_universal.json
执行 fastboot flash gpt partition_universal.json
max-download-size: 134217728
parse gpt/mtd table okay
执行 fastboot flash bootinfo bootinfo_sd.bin
执行 fastboot flash fsbl FSBL.bin
执行 fastboot flash env env.bin
执行 fastboot flash opensbi fw_dynamic.itb
执行 fastboot flash uboot u-boot.itb
执行 fastboot flash bootfs bootfs.ext4
start split gzip file in 2024-06-21 00:42:11
使用gzip压缩等级为: 5
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:42:14
切片缓存的数量: 1
刷机总进度: 16%: ▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:18
split gzip file over, begin download in 2024-06-21 00:42:18
刷机总进度: 18%: ▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:22
执行 fastboot flash rootfs rootfs.ext4
start split gzip file in 2024-06-21 00:42:22
使用gzip压缩等级为: 5
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:42:27
刷机总进度: 19%: ▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:32
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:42:36
刷机总进度: 20%: ▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:44
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:42:44
切片缓存的数量: 1
刷机总进度: 21%: ▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:50
split gzip file over, begin download in 2024-06-21 00:42:50
切片缓存的数量: 1
刷机总进度: 23%: ▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:42:58
split gzip file over, begin download in 2024-06-21 00:42:58
刷机总进度: 1%: 切片缓存的数量: 1
刷机总进度: 24%: ▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:06
split gzip file over, begin download in 2024-06-21 00:43:06
切片缓存的数量: 1
刷机总进度: 25%: ▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:12
split gzip file over, begin download in 2024-06-21 00:43:12
刷机总进度: 27%: ▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:18
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:43:22
刷机总进度: 28%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:29
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:43:31
刷机总进度: 29%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:37
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:43:38
刷机总进度: 31%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:44
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:43:46
刷机总进度: 32%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:52
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:43:53
刷机总进度: 33%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:43:59
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:00
刷机总进度: 34%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:05
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:06
刷机总进度: 36%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:11
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:12
刷机总进度: 37%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:18
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:21
切片缓存的数量: 1
刷机总进度: 38%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:27
split gzip file over, begin download in 2024-06-21 00:44:27
刷机总进度: 40%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:33
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:34
切片缓存的数量: 1
刷机总进度: 41%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:40
split gzip file over, begin download in 2024-06-21 00:44:40
刷机总进度: 42%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:46
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:47
刷机总进度: 43%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:44:54
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:44:56
刷机总进度: 45%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:03
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:05
刷机总进度: 46%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:12
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:13
切片缓存的数量: 1
刷机总进度: 47%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:19
split gzip file over, begin download in 2024-06-21 00:45:19
刷机总进度: 49%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:24
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:25
刷机总进度: 50%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:30
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:32
刷机总进度: 51%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:38
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:41
刷机总进度: 52%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:48
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:49
刷机总进度: 54%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:45:56
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:45:58
刷机总进度: 55%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:04
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:05
刷机总进度: 56%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:11
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:12
刷机总进度: 58%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:18
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:19
刷机总进度: 59%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:24
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:26
切片缓存的数量: 1
刷机总进度: 60%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:32
split gzip file over, begin download in 2024-06-21 00:46:32
刷机总进度: 61%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:37
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:41
刷机总进度: 63%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:48
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:50
刷机总进度: 64%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:46:56
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:46:58
刷机总进度: 65%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:05
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:47:07
切片缓存的数量: 1
刷机总进度: 67%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:15
split gzip file over, begin download in 2024-06-21 00:47:15
切片缓存的数量: 1
刷机总进度: 68%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:21
split gzip file over, begin download in 2024-06-21 00:47:21
刷机总进度: 69%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:28
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:47:30
刷机总进度: 70%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:39
切片缓存的数量: 1
split gzip file over, begin download in 2024-06-21 00:47:39
切片缓存的数量: 1
刷机总进度: 72%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:48
split gzip file over, begin download in 2024-06-21 00:47:48
切片缓存的数量: 1
刷机总进度: 73%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:47:55
split gzip file over, begin download in 2024-06-21 00:47:55
切片缓存的数量: 1
切片缓存的数量: 2
刷机总进度: 74%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:00
split gzip file over, begin download in 2024-06-21 00:48:00
切片缓存的数量: 2
刷机总进度: 76%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:05
split gzip file over, begin download in 2024-06-21 00:48:05
切片缓存的数量: 2
刷机总进度: 77%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:10
split gzip file over, begin download in 2024-06-21 00:48:10
切片缓存的数量: 2
切片缓存的数量: 3
刷机总进度: 78%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:16
split gzip file over, begin download in 2024-06-21 00:48:16
刷机总进度: 79%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:20
split gzip file over, begin download in 2024-06-21 00:48:20
切片缓存的数量: 2
刷机总进度: 81%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:25
split gzip file over, begin download in 2024-06-21 00:48:25
切片缓存的数量: 2
刷机总进度: 82%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:30
split gzip file over, begin download in 2024-06-21 00:48:30
切片缓存的数量: 2
刷机总进度: 83%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:37
split gzip file over, begin download in 2024-06-21 00:48:37
刷机总进度: 85%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:43
split gzip file over, begin download in 2024-06-21 00:48:43
切片缓存的数量: 1
刷机总进度: 86%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:49
split gzip file over, begin download in 2024-06-21 00:48:49
切片缓存的数量: 1
刷机总进度: 87%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:48:55
split gzip file over, begin download in 2024-06-21 00:48:55
切片缓存的数量: 1
刷机总进度: 88%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:01
split gzip file over, begin download in 2024-06-21 00:49:01
切片缓存的数量: 1
刷机总进度: 90%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:08
split gzip file over, begin download in 2024-06-21 00:49:08
切片缓存的数量: 1
刷机总进度: 91%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:13
split gzip file over, begin download in 2024-06-21 00:49:13
切片缓存的数量: 1
切片缓存的数量: 2
切片缓存的数量: 3
刷机总进度: 92%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:19
split gzip file over, begin download in 2024-06-21 00:49:19
切片缓存的数量: 3
刷机总进度: 94%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:25
split gzip file over, begin download in 2024-06-21 00:49:25
切片缓存的数量: 3
刷机总进度: 95%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:29
split gzip file over, begin download in 2024-06-21 00:49:29
切片缓存的数量: 3
刷机总进度: 96%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:32
split gzip file over, begin download in 2024-06-21 00:49:32
刷机总进度: 97%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:36
split gzip file over, begin download in 2024-06-21 00:49:36
刷机总进度: 99%: ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
download over in 2024-06-21 00:49:39
split gzip file over, begin download in 2024-06-21 00:49:39
download over in 2024-06-21 00:49:42
---》刷机成功!
<-------------flash over ---------------->
Let me know if you need any more information. Happy to help.
Thank you so much for your time and effort!
