Do you want the BPI-R4 Pro FPC network adapter board?
I don’t understand where to put this file? Cannot test, the source code I am currently using is GitHub - immortalwrt/immortalwrt: An opensource OpenWrt variant for mainland China users. · GitHub
You can compare changes made in the overlay with the state in your dts and apply directly to it to avoid the overlay stuff. For quick test enable port3 of internal switch if not done already.
Just replace disabled by okay for port3 and phy3 and rebuild.
You can check the state in sysfs (/sys/firmware/devicetree/base/…go to the internal switch and its ports and show status with cat command
Leds part has to be added to the pinctrl/pio node
