Do you have any ideas for the R4Pro?
Some people think that the casing of the R4Pro is too large and they would prefer a smaller one.Tell us the ideal size you have in mind.
For example: We don’t want to use WiFi. Originally, the two slots of mPCIe were empty, so a conversion board could be added to accommodate an NVME SSD. Then you can add four NVME SSDs.
Please share your thoughts. We will evaluate the feasibility of these proposals based on the comments. Thank you for your suggestion.
Ideally a good one is the same as the BPI-R4 case but a little bit taller to have the possibility to mount a slim 90 fan on the top cover… this would cover the no wi-fi/router only use case.
And four holes to hold that fan on the top cover.
The manufacturer had already mentioned working on two different cases (WiFi and non-WiFi versions). However, it is disappointing that the WiFi model misses fitting into a 10inch rack by just a few centimeters. It feels like this could have been considered during the design phase
BE14 matches board dimensions as far as i see,only be19 will be larger. But as there is no new be19 yet and so its dimensions.
The main flaw I notice in the design of this board, as a BPI-R4 user, is the failure to expose all possible ports/connectors for the user. In the BPI-R4 PRO, this issue is less pronounced, and there are even spots on the board for an M.2 Key E socket.
For example, a major oversight is not exposing the last 2.5GB RJ45 port from the switch (which supports up to five ports, even as pin headers). Second issue is lack of support of tacho/RPM in fans, and common PWM line.
There are a total of 6 PCIe lanes: 2 lanes per PCIe slot, one for the M.2 Key M connector, and one for the Key B connector (in BPI-R4, close to similar situation in PRO). The PCIe slot also has USB 2.0 routed from the hub (just like the M.2 Key B port).
In my opinion, it would be ideal to have an expansion board that converts the dual PCIe connector into 4 M.2 Key M slots plus exposed USB 2.0 ports (2x). The question of power supply sufficiency would need to be considered—perhaps switching to 12V and using step-down converters would be necessary.
I’m not an electronics specialist, but if it’s possible to combine 4 PCIe lanes into a single M.2 Key M slot, the board should have 4 M.2 Key M slots. If only one NVMe drive (or any other device) is inserted, it would use all 4 lanes. If a second drive is inserted, each would get 2 lanes. If three drives are inserted, one would get 2 lanes and the other two would get 1 lane each. If four drives are inserted, each would get 1 PCIe lane.
If PCIe lanes can only be grouped per PCIe slot, the board would have two M.2 Key M slots. What stands out most to me is the closed-minded vision that everyone will use this board only as GSM modems, when it could be used in so many other ways. It’s a shame that these boards aren’t designed with more versatility in mind.
I’m planning to order the design of such a board somewhere—hopefully, it will be financially reasonable (I’ll probably do it in China).
I absolutelly agree that this board should be designed more open-minded! As I am using it as 20-bay sfp nas already, more versability will be much appreciated.
I have a lot to say, but the first thing I’d like is something similar to the below:
PCIe interface for WiFi card
I want to try this, Wi-Fi 7 AP M.2 Card with AE key interface, reach BE5000 (5000Mbps) speed with MediaTek MT7991 Chipset, out but obviously I cannot because Banana Pi uses mPCIe. I think the Banana Pi NIC should just use a regular PCIe interface. I suspect there is a reason why they didn’t do this in the beginning but going forward they really should, if there are no technical reasons as to why not.
One reason that this would be a good idea is that I can use a mini PC with the Banana Pi WiFi NIC to re-purpose it as a router.
More antennae
Built-in 12 antennas + 12 amplifiers
Questions
Does anyone have a Qualcomm equipped router, if so, how does it compare to Mediatek?
Link was wrong:
Someone has used an adapter for this:
