Hello all, Recently seeking alternatives to Raspberry Pi.
Followed “Install Image with SDcard” section of https://wiki.banana-pi.org/Getting_Started_with_R2PRO to mirror the image in the Ubuntu-SDBoot-update-MT7531SW-20220228.zip to the SD card with RockChip Create Upgrade Disk Tool then inserted it to the Banana Pi.
The instruction says the BananaPi should first boot to prompt to remove the SD disk, then it will install to eMMC and directly boot into the system, but neither did I get the prompt to remove the SD disk, nor did it boot into the Ubuntu OS.
I only get a partial Builtroot OS with cat /etc/os-release is buildroot.
All inputs and outputs need to be done via the CH340 USB port, I only has a laptop with no external monitor for connecting to HDMI or external keyboards.
Thanks for helping.
