Just received my first two BPI-R4 boards for testing a frr network lab setup and went with the “bpi-r4_bookworm_6.12.23-main.img” image.
I could install a few packages from apt, but it gives me when I do an “apt update”:
root@bpi-r4:~# apt update
Get:1 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Get:2 http://ftp.de.debian.org/debian bookworm InRelease [151 kB]
Get:3 http://ftp.de.debian.org/debian bookworm-updates InRelease [55.4 kB]
Reading package lists... Done
E: Release file for http://security.debian.org/debian-security/dists/bookworm-security/InRelease is not valid yet (invalid for another 119d 15h 13min 54s). Updates for this repository will not be applied.
E: Release file for http://ftp.de.debian.org/debian/dists/bookworm/InRelease is not valid yet (invalid for another 71d 17h 19min 32s). Updates for this repository will not be applied.
E: Release file for http://ftp.de.debian.org/debian/dists/bookworm-updates/InRelease is not valid yet (invalid for another 119d 16h 21min 24s). Updates for this repository will not be applied.
Or when I want to install “frr” package I get errors that packages couldn’t be found.
Oddly I didn’t find anything when searching for this errors on google.
This is odd…I already tried with “date” command before…and also with your "date snippet no change…
But…systemd-timesyncd wasn’t installed…at least I could install this package…and now apt update works
32 packages can be upgraded. Run 'apt list --upgradable' to see them.
N: Repository 'http://ftp.de.debian.org/debian bookworm InRelease' changed its 'Version' value from '12.10' to '12.11'
Don’t see any ntp daemon installed (or I did search wrong ;o):
root@bpi-r4:~# apt list --installed | grep "ntp\|time"
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libpam-runtime/stable,now 1.5.2-6+deb12u1 all [installed]
systemd-timesyncd/stable-security,now 252.38-1~deb12u1 arm64 [installed]
Ok,did not remember i installed manually on my testing devices,but possibly. If timesyncd works keep that way…only noted that because ntp and timesyncd may interfere each other
