Creating persistent volume for Docker
I have OpenWRT installed on eMMC. How do I use the full 8GB to have more storage for e.g. docker images?
/dev/root                84.0M     84.0M         0 100% /rom
tmpfs                     1.9G      2.5M      1.9G   0% /tmp
/dev/fitrw              356.4M     53.2M    303.3M  15% /overlay
overlayfs:/overlay      356.4M     53.2M    303.3M  15% /
overlayfs:/overlay      356.4M     53.2M    303.3M  15% /opt/docker
I see there’s opt/docker but it has limited space. I see it says overlayfs. Is this persistent?
root@OpenWrt:~# ubinfo
UBI version:                    1
Count of UBI devices:           1
UBI control device major/minor: 10:127
Present UBI devices:            ubi0
root@OpenWrt:~# ubinfo -d 0
ubi0
Volumes count:                           7
Logical eraseblock size:                 126976 bytes, 124.0 KiB
Total amount of logical eraseblocks:     1008 (127991808 bytes, 122.0 MiB)
Amount of available logical eraseblocks: 0 (0 bytes)
Maximum count of volumes                 128
Count of bad physical eraseblocks:       0
Count of reserved physical eraseblocks:  20
Current maximum erase counter value:     2
Minimum input/output unit size:          2048 bytes
Character device major/minor:            250:0
Present volumes:                         0, 1, 2, 3, 4, 5, 6
root@OpenWrt:~# ubinfo -d 0 -N
ubinfo: option requires an argument: N
Use -h for help
root@OpenWrt:~# ubinfo -d 0 -N rootfs_data
Volume ID:   6 (on ubi0)
Type:        dynamic
Alignment:   1
Size:        634 LEBs (80502784 bytes, 76.7 MiB)
State:       OK
Character device major/minor: 250:7
root@OpenWrt:~# uvol free
File descriptor 5 (/usr/sbin/uvol) leaked on lvm invocation. Parent PID 5693: /usr/bin/ucode
File descriptor 6 (/usr/lib/uvol/uci.uc) leaked on lvm invocation. Parent PID 5693: /usr/bin/ucode
File descriptor 7 (/usr/lib/uvol/backends/lvm.uc) leaked on lvm invocation. Parent PID 5693: /usr/bin/ucode
File descriptor 8 (/usr/lib/uvol/blockdev_common.uc) leaked on lvm invocation. Parent PID 5693: /usr/bin/ucode
0
root@OpenWrt:~# uvol list
File descriptor 5 (/usr/sbin/uvol) leaked on lvm invocation. Parent PID 5695: /usr/bin/ucode
File descriptor 6 (/usr/lib/uvol/uci.uc) leaked on lvm invocation. Parent PID 5695: /usr/bin/ucode
File descriptor 7 (/usr/lib/uvol/backends/lvm.uc) leaked on lvm invocation. Parent PID 5695: /usr/bin/ucode
File descriptor 8 (/usr/lib/uvol/blockdev_common.uc) leaked on lvm invocation. Parent PID 5695: /usr/bin/ucode
root@OpenWrt:~# parted
GNU Parted 3.6
Using /dev/mmcblk0
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print
Error: The backup GPT table is corrupt, but the primary appears OK, so that will
be used.
OK/Cancel? Ok
Warning: Not all of the space available to /dev/mmcblk0 appears to be used, you
can fix the GPT to use all of the space (an extra 14221279 blocks) or continue
with the current setting?
Fix/Ignore? Ignore
Model: MMC 8GTF4R (sd/mmc)
Disk /dev/mmcblk0: 7818MB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name        Flags
128     17.4kB  4194kB  4177kB                           bios_grub
 1      4194kB  4719kB  524kB                ubootenv    hidden, legacy_boot
 2      4719kB  6816kB  2097kB               factory     hidden
 3      6816kB  11.0MB  4194kB               fip         boot, hidden, esp
 4      12.6MB  46.1MB  33.6MB               recovery    boot, hidden, esp
 5      67.1MB  537MB   470MB                production
maybe you should create a partition and then use it for docker volumes
