I use openwrt 19.07.x (kernel 4.19.108) with R64, sometimes kernel stall on usbnet_change_mtu [usbnet] at kernel booting time. Any ideas? Thanks.
[   93.989154] rcu: INFO: rcu_sched self-detected stall on CPU
[   93.994915] rcu: 	0-....: (5999 ticks this GP) idle=2fa/1/0x4000000000000004 softirq=3692/3693 fqs=2989
[   94.004687] rcu: 	 (t=6001 jiffies g=1425 q=43764)
[   94.009623] Task dump for CPU 0:
[   94.012945] kworker/0:2     R  running task        0   633      2 0x0000002a
[   94.020259] Workqueue: events usbnet_change_mtu [usbnet]
[   94.025732] Call trace:
[   94.028253]  dump_backtrace+0x0/0x128
[   94.032024]  show_stack+0x14/0x20
[   94.035438]  sched_show_task+0x10c/0x138
[   94.039478]  dump_cpu_task+0x40/0x4c
[   94.043162]  rcu_dump_cpu_stacks+0xa8/0xfc
[   94.047380]  rcu_check_callbacks+0x328/0x6f8
[   94.051780]  update_process_times+0x2c/0x58
[   94.056090]  tick_sched_handle.isra.5+0x3c/0x48
[   94.060757]  tick_sched_timer+0x48/0x88
[   94.064707]  __hrtimer_run_queues+0xb4/0x1a8
[   94.069104]  hrtimer_interrupt+0x110/0x278
[   94.073326]  arch_timer_handler_phys+0x2c/0x40
[   94.077905]  handle_percpu_devid_irq+0x80/0x150
[   94.082571]  generic_handle_irq+0x24/0x38
[   94.086700]  __handle_domain_irq+0x88/0xb0
[   94.090917]  gic_handle_irq+0x60/0xa0
[   94.094687]  el1_irq+0xb0/0x140
[   94.097932]  usbnet_disconnect+0x300/0x838 [usbnet]
[   94.102960]  usbnet_disconnect+0x380/0x838 [usbnet]
[   94.107988]  usbnet_disconnect+0x7bc/0x838 [usbnet]
[   94.113015]  tasklet_action_common.isra.3+0x94/0x100
[   94.118129]  tasklet_action+0x24/0x30
[   94.121898]  __do_softirq+0xe4/0x1e8
[   94.125579]  irq_exit+0x70/0xd0
[   94.128811]  __handle_domain_irq+0x8c/0xb0
[   94.133029]  gic_handle_irq+0x60/0xa0
[   94.136799]  el1_irq+0xb0/0x140
[   94.140034]  xhci_urb_dequeue+0x3d4/0x430
[   94.144166]  unlink1+0x124/0x140
[   94.147489]  usb_hcd_unlink_urb+0xb0/0xe0
[   94.151618]  usb_unlink_urb+0x24/0x48
[   94.155392]  usbnet_status_stop+0xc0/0x158 [usbnet]
[   94.160420]  usbnet_change_mtu+0xc8/0x4f0 [usbnet]
[   94.165358]  usbnet_change_mtu+0x4a0/0x4f0 [usbnet]
[   94.170385]  process_one_work+0x200/0x350
[   94.174513]  worker_thread+0x260/0x468
[   94.178375]  kthread+0x118/0x128
[   94.181697]  ret_from_fork+0x10/0x1c
[  100.329165] rcu: INFO: rcu_sched detected expedited stalls on CPUs/tasks: { 0-... } 6498 jiffies s: 9 root: 0x1/.
[  100.339771] rcu: blocking rcu_node structures:
[  100.344349] Task dump for CPU 0:
[  100.347671] kworker/0:2     R  running task        0   633      2 0x0000002a
[  100.354996] Workqueue: events usbnet_change_mtu [usbnet]
[  100.360477] Call trace:
[  100.362998]  __switch_to+0xfc/0x108
[  100.366592]  process_one_work+0x200/0x350
[  100.370726]  worker_thread+0x260/0x468
[  100.374589]  kthread+0x118/0x128
[  100.377912]  ret_from_fork+0x10/0x1c
[  274.019168] rcu: INFO: rcu_sched self-detected stall on CPU
[  274.024928] rcu: 	0-....: (23984 ticks this GP) idle=2fa/1/0x4000000000000004 softirq=3692/3693 fqs=11981
[  274.034880] rcu: 	 (t=24004 jiffies g=1425 q=45746)
[  274.039908] Task dump for CPU 0:
[  274.043230] kworker/0:2     R  running task        0   633      2 0x0000002a
[  274.050539] Workqueue: events usbnet_change_mtu [usbnet]
[  274.056011] Call trace:
[  274.058532]  dump_backtrace+0x0/0x128
[  274.062303]  show_stack+0x14/0x20
[  274.065718]  sched_show_task+0x10c/0x138
[  274.069758]  dump_cpu_task+0x40/0x4c
[  274.073441]  rcu_dump_cpu_stacks+0xa8/0xfc
[  274.077659]  rcu_check_callbacks+0x328/0x6f8
[  274.082058]  update_process_times+0x2c/0x58
[  274.086370]  tick_sched_handle.isra.5+0x3c/0x48
[  274.091037]  tick_sched_timer+0x48/0x88
[  274.094986]  __hrtimer_run_queues+0xb4/0x1a8
[  274.099384]  hrtimer_interrupt+0x110/0x278
[  274.103604]  arch_timer_handler_phys+0x2c/0x40
[  274.108184]  handle_percpu_devid_irq+0x80/0x150
[  274.112851]  generic_handle_irq+0x24/0x38
[  274.116980]  __handle_domain_irq+0x88/0xb0
[  274.121197]  gic_handle_irq+0x60/0xa0
[  274.124968]  el1_irq+0xb0/0x140
[  274.128201]  __do_softirq+0x9c/0x1e8
[  274.131883]  irq_exit+0x70/0xd0
[  274.135115]  __handle_domain_irq+0x8c/0xb0
[  274.139333]  gic_handle_irq+0x60/0xa0
[  274.143103]  el1_irq+0xb0/0x140
[  274.146339]  xhci_urb_dequeue+0x3d4/0x430
[  274.150471]  unlink1+0x124/0x140
[  274.153793]  usb_hcd_unlink_urb+0xb0/0xe0
[  274.157922]  usb_unlink_urb+0x24/0x48
[  274.161708]  usbnet_status_stop+0xc0/0x158 [usbnet]
[  274.166736]  usbnet_change_mtu+0xc8/0x4f0 [usbnet]
[  274.171675]  usbnet_change_mtu+0x4a0/0x4f0 [usbnet]
[  274.176702]  process_one_work+0x200/0x350
[  274.180830]  worker_thread+0x260/0x468
[  274.184692]  kthread+0x118/0x128
[  274.188014]  ret_from_fork+0x10/0x1c
[  284.649167] rcu: INFO: rcu_sched detected expedited stalls on CPUs/tasks: { 0-... } 24930 jiffies s: 9 root: 0x1/.
[  284.659860] rcu: blocking rcu_node structures:
[  284.664437] Task dump for CPU 0:
[  284.667758] kworker/0:2     R  running task        0   633      2 0x0000002a
[  284.675083] Workqueue: events usbnet_change_mtu [usbnet]
[  284.680564] Call trace:
[  284.683084]  __switch_to+0xfc/0x108
[  284.686677]  process_one_work+0x200/0x350
[  284.690815]  worker_thread+0x260/0x468
[  284.694678]  kthread+0x118/0x128
[  284.698000]  ret_from_fork+0x10/0x1c
