Control fan RPM with multiple thermal zones, advice needed
I’m building a cooling solution for the BPI-R4 that will have a fan moving air through the entire enclosure, and I’d like the fan RPM to follow several thermal zones–the SoC, WiFi PHYs, SFP modules, and the NVMe SSD. I know mt7988a.dtsi is the place to look in. But, it’s an unfamiliar territory for me, so, rather than trying to figure it out on my own, I’d appreciate an advice.
I also suspect that mt7988a-bananapi-bpi-r4.dtsi would be a better place for the new code, as it is device-specific.
This is what I start with in mt7988a.dtsi.
thermal-zones {
		cpu_thermal: cpu-thermal {
			polling-delay-passive = <1000>;
			polling-delay = <1000>;
			thermal-sensors = <&lvts 0>;
			trips {
				cpu_trip_crit: crit {
					temperature = <125000>;
					hysteresis = <2000>;
					type = "critical";
				cpu_trip_hot: hot {
					temperature = <120000>;
					type = "hot";
				cpu_trip_active_high: active-high {
					temperature = <115000>;
					type = "active";
				cpu_trip_active_med: active-med {
					temperature = <85000>;
					type = "active";
				cpu_trip_active_low: active-low {
					temperature = <40000>;
					type = "active";
			cooling-maps {
				cpu-active-high {
				/* active: set fan to cooling level 2 */
					cooling-device = <&fan 3 3>;
					trip = <&cpu_trip_active_high>;
				cpu-active-low {
				/* active: set fan to cooling level 1 */
					cooling-device = <&fan 2 2>;
					trip = <&cpu_trip_active_med>;
				cpu-passive {
				/* passive: set fan to cooling level 0 */
					cooling-device = <&fan 1 1>;
					trip = <&cpu_trip_active_low>;
I’d also like to connect the fan tachometer to GPIO to be able to read the RPM, but all of the pins on the 26-pin GPIO header seem to have a specific function. What am I missing here?
	fan: pwm-fan {
		compatible = "pwm-fan";
		/* cooling level (0, 1, 2, 3) : (0% duty, 30% duty, 50% duty, 100% duty) */
		cooling-levels = <0 80 128 255>;
		#cooling-cells = <2>;
		#thermal-sensor-cells = <1>;
		status = "disabled";
I figured a better solution would be to use the GPIO header to both power and control the fan with a simple userspace script. It polls every temp sensor found in /sys/class/hwmon and sets the fan speed according to the highest reading. Works fell so far.
#!/bin/sh
# PWM configuration
PWM_PIN="/sys/kernel/debug/pinctrl/1001f000.pinctrl-pinctrl_moore/pinmux-select"
PWM_CHIP="/sys/class/pwm/pwmchip0"
PWM_GROUP="$PWM_CHIP/pwm6"
# Initialize PWM
echo "pwm6_0 pwm" > "$PWM_PIN"
if [ ! -d "$PWM_GROUP" ]; then
        echo 6 > "$PWM_CHIP/export"
fi
# Set frequency to 10 kHz (100000 ns period) and enable PWM
echo 100000 > "$PWM_GROUP/period"
echo 1 > "$PWM_GROUP/enable"
# Set duty cycle
set_duty_cycle() {
	echo "$1" > "$PWM_GROUP/duty_cycle"
# Choose duty cicle based on temperature
choose_duty_cycle() {
	temp=$1
	# Full speed if temp >= 60°C
		if [ "$temp" -ge 60000 ]; then
		set_duty_cycle 100000
	# Mid speed if temp >= 45°C
	elif [ "$temp" -ge 45000 ]; then
		set_duty_cycle 50000
	# Low speed if temp < 45°C
	else
		set_duty_cycle 30000
	fi
# Loop through all hwmon directories for highest temperature
get_temperature() {
	max_temp=0
	for hwmon in /sys/class/hwmon/hwmon*/temp*_input; do
		if [ -f "$hwmon" ]; then
			temp=$(cat "$hwmon")
			if [ "$temp" -gt "$max_temp" ]; then
				max_temp=$temp
			fi
		fi
	done
	choose_duty_cycle $max_temp
# Run continuously
while true; do
	get_temperature
	sleep 5  # Check every 5 seconds
done
Edit: error fixed.
Maybe this could help you for reading the rpm. got the same problems last week and made a package to return the RPM by GPIO. It also can return the value for collectd. But this is not for setting the speed :slight_smile:
Thank you, I’ll check it out. Although, now that I’m using the only PWM pin on the GPIO header to set the speed I wonder if any of the other pins can be repurposed for reading.
Yes, i do the same :slight_smile: reading the rpm from both fans at different GPIO pins (splitted ground from the cpu pwm fan and put rpm and second ground to gpio header, second is “simpler”, just connect rpm (i took 17-fan1 and 18-fan2) and others to GPIOs)
For example with my tool you than can read out the rpm by calling gpio-fan-rpm --gpio=17 or both to get (multi threaded) results from both at the same time gpio-fan-rpm --gpio=17 --gpio=18
But the tool is in an very very very early stage :wink:
By 17 and 8 you mean GPI017 12C-1 SCL and GPI018_I2C_1_SDA on the GPIO header pinout diagram? I’m surprised those can be removed from their I2C function and repurposed (if they were indeed hardwired to begin with).
Yes, i have them on those both. The SCL and SDA is not used if you don’t configure it for. You can take a nice look which gpios are possible with gpioctl from OpenWRT. There you can list all lines from the gpiochip0 :slight_smile:
Is it possible to build this on OpenWrt? I have gcc, make and libgpiod (via gpiod-tools) preinstalled. Now the build stops with the following error:
root@home-rt-edge-1:/tmp/gpio-fan-rpm# make
Makefile:1: /rules.mk: No such file or directory
make: *** No rule to make target '/rules.mk'. Stop.
Not sure if it works on a running system to compile. I made it inside the openwrt build environment. There it should work. Just have to figure out how i can create mutli arch packages then i can give an ipk as download. I think Sunday is a good day for this :sweat_smile:
The file which is missing is from the openwrt build environment. A good starting point for building yourself would be to get a docker image with a build environment for openwrt (there are many out there) or make a build env at your host. Copy source to /package/, make menuconfig, Check Utilities for gpio fan package and set to m or *. After this make package/gpio-fan-rpm/compile
Yep, I’m already building OpenWrt from source every time. I’ll try it that way.
Omg, i am a bit stupid today, forgot we are in the BPI R4 Forum :rofl: I am switching often between OpenWRT and this forum, sorry :smiley: You can get my ipk - just have to force install cause of hash mismatch if you dont want build yourself :slight_smile:
(hope lib versions are compatible)
https://www.mediafire.com/file/s6w30wus3vc7qim/gpio-fan-rpm_1.0.0-r1_aarch64_cortex-a53.ipk/file
Finally i have a working github workflow which is creating the packages for me at release time :smiley: i still started with v1.0.0.
Releases can be found there: GitHub - Zerogiven-OpenWRT-Packages/gpio-fan-rpm: Modular and well-commented fan RPM measurement utility for OpenWRT (libgpiod v2)
Some time i will make an OpenWRT package feed for it too to easier update/install.
Hello,
thanks for this thread, it helped me to create pwm controlling of my silent 12cm fans. I was unable to find pinout of gpio pins on bpi-r4, do you have anyone link or image? I think, it could be helpfull to others. I had to set the pwm on pin and than use multimeter with osciloscope to find the right pin and the ground. :smiley:
https://docs.banana-pi.org/en/BPI-R4/GettingStarted_BPI-R4#_26_pin_gpio_define
And, at these moments I feel really stupid. :smiley: I know this page, I was at this page, I do not know why ******* I was so blind…
I find that I had bookmarked " Getting Started with BPI-R4" : https://wiki.banana-pi.org/Getting_Started_with_BPI-R4
instead of https://docs.banana-pi.org/en/BPI-R4/GettingStarted_BPI-R4 you provided.
Does anyone knows why are there “BPI wiki” and “BananaPI Docs” and both of them under banana-pi.org domain?
I think the wiki is old and docs is new. They should remove the old and make it redirect…
