Hi folks.
I feel like its time for a positive post, so here goes;
I’ve finally had time to assemble my bpi-r4 into its case for a trial fit.
The case looks really smart.
The fit and finish are very high quality, with everything lining up beautifully. All the ports and slots sit dead centre in their cutouts, and not one thing needed to be forced into position. Very impressive indeed.
The heatsink/fan however is junk. There is a slight design issue at play here - the two mounting holes are not centered over the MCU, and this is obviously why it is shown in the instructions with two thermal pads on the bottom of the SDRAM chips, as this enables it to sit flat (ish) over the MCU.
This is, at best, a poor workaround, so i’d recommend finding an alternative arrangement.
If the heatsink supplied actually covered the RAM properly it would maybe be ok, but it doesnt.
Ive left it off (for now) as under light-medium loads, it runs cold anyway.
If future board revs had 4 mount points for the heatsink, rather than 2 off-centre ones, this would be a huge plus, and allow far greater flexibility.
The case has nice crisp markings, including footprints for the 3M branded rubber feet, which is a lovely touch.
A small rubber bung to cover the boot switch hole would be nice, but not required, as the switches are recessed a sensible amount.
Personally, i’d have preferred the sim trays to be black alloy finish too, but thats nothing a light dusting with a bit of paint can’t fix.
Lastly, I really like that they give you plenty of screws. Mine came with 2 spare case screws, and two spare mounting screws for the board, AFAICT. It also came with 6 screws for the pcie slots.
Oh, and it’d make getting the lid on easier if it had a slight chamfer on the corners, but that hardly matters
All in all, a really nice bit of kit. I will be getting it for my other r4 units, assuming the WiFi 7 boards are as good as promised (I don’t have one yet)
