Cannot create a docker container
“bpf_prog_query(BPF_CGROUP_DEVICE) failed” Please suggest me a solution. I found an error when trying to run docker on my eMMC
sudo docker run hello-world docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: bpf_prog_query(BPF_CGROUP_DEVICE) failed: invalid argument: unknown. ERRO[0000] error waiting for container: context canceled
My system is: uname -a Linux raspberrypi 4.9.241-BPI-M5 #2 SMP PREEMPT Mon Jun 21 16:29:40 HKT 2021 aarch64 GNU/Linux
pi@raspberrypi:~ $ sudo docker version Client: Docker Engine - Community Version: 20.10.21 API version: 1.41 Go version: go1.18.7 Git commit: baeda1f Built: Tue Oct 25 18:01:19 2022 OS/Arch: linux/arm64 Context: default Experimental: true
Server: Docker Engine - Community Engine: Version: 20.10.21 API version: 1.41 (minimum version 1.12) Go version: go1.18.7 Git commit: 3056208 Built: Tue Oct 25 17:59:41 2022 OS/Arch: linux/arm64 Experimental: false containerd: Version: 1.6.9 GitCommit: 1c90a442489720eec95342e1789ee8a5e1b9536f runc: Version: 1.1.4 GitCommit: v1.1.4-0-g5fd4c4d docker-init: Version: 0.19.0 GitCommit: de40ad0
pi@raspberrypi:~ $ sudo docker info Client: Context: default Debug Mode: false Plugins: app: Docker App (Docker Inc., v0.9.1-beta3) buildx: Docker Buildx (Docker Inc., v0.9.1-docker) compose: Docker Compose (Docker Inc., v2.12.2)
Server: Containers: 10 Running: 0 Paused: 0 Stopped: 10 Images: 2 Server Version: 20.10.21 Storage Driver: overlay2 Backing Filesystem: extfs Supports d_type: true Native Overlay Diff: true userxattr: false Logging Driver: json-file Cgroup Driver: systemd Cgroup Version: 2 Plugins: Volume: local Network: bridge host ipvlan macvlan null overlay Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog Swarm: inactive Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux runc Default Runtime: runc Init Binary: docker-init containerd version: 1c90a442489720eec95342e1789ee8a5e1b9536f runc version: v1.1.4-0-g5fd4c4d init version: de40ad0 Security Options: apparmor seccomp Profile: default cgroupns Kernel Version: 4.9.241-BPI-M5 Operating System: Debian GNU/Linux 11 (bullseye) OSType: linux Architecture: aarch64 CPUs: 4 Total Memory: 3.625GiB Name: raspberrypi ID: GQOR:MOMF:5VX4:XIVB:4NVM:JHOE:HS2Y:KI3R:YXOM:X77I:LG7T:GPD4 Docker Root Dir: /var/lib/docker Debug Mode: false Registry: https://index.docker.io/v1/ Labels: Experimental: false Insecure Registries: 127.0.0.0/8 Live Restore Enabled: false
WARNING: No swap limit support WARNING: No cpu cfs quota support WARNING: No cpu cfs period support WARNING: No cpu shares support WARNING: No cpuset support WARNING: No io.weight support WARNING: No io.weight (per device) support WARNING: No io.max (rbps) support WARNING: No io.max (wbps) support WARNING: No io.max (riops) support WARNING: No io.max (wiops) support pi@raspberrypi:
lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
cat /etc/os-release PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)” NAME=“Debian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
Go here https://www.armbian.com/bananapi-m5/ and when system is up, install docker.
Thank, in fact I prefer Raspbian Desktop. Wait for BPI to fix the bug. I will try Armbian soon. May be I will like Armbian.
If you like wallpaper from Raspbian so much, you can also install it on Armbian. Armbian is incomparable better then “Raspbian” you are evaluating. This is not Raspberry Pi.
https://docs.armbian.com/User-Guide_FAQ/
Thank Igor, Armbian are working OK for me now. Docker container is running OK on both my SDcard and eMMC. What I mean Raspbian desktop is not GNOME, Cinnamon or XFCE desktop. I don’t know what Raspbian desktop is called.
Its some variant of LXDE IIRC, but I would not argue about visual preferences - its subjective. If everything else would be the same, then desktop environment would have some relevance.
