jbwyatt4
(John Wyatt)
Hello everyone, I purchased this kit from Amazon. OpenWRT is already installed and functional. https://www.amazon.com/gp/product/B0BLVF9697
I can not get any output. I read that I may need to enable uart from within the OpenWRT first.
If so, how do I enable UART? The documentation from the wiki is a little lacking.
Interacting with uart is new to me so any advice is appreciated. I have access to the terminal console in OpenWRT.
I used sudo screen /dev/ttyUSB0 115280 to read off the usb connection after using modprobe to set it up.
frank-w
(Frank W.)
2
Have you connected rx to tx and tx to rx of the 3pin connector?
https://wiki.fw-web.de/doku.php?id=en:bpi-r2:debug-uart
jbwyatt4
(John Wyatt)
3
I have not. I will try that. Thank you frank-w. Remember reading about that.
jbwyatt4
(John Wyatt)
4
@frank-w thank you for pointing that out.
The issue seemed to be I used a longer 3rd party one that reported garbled output.
I used the included one and it work perfectly. I was able to flash the eMMC from the sd card.
