Building a Minimal System with BPI-M2
Google Download Link: https://drive.google.com/a/edu.52miku.tk/file/d/0B4l1r4Ltm446MFBvUkwtVU9lcmM/view
Baidu Download Link: http://pan.baidu.com/s/1ntrHIh7
@BPI_Justin, script doesnāt work
Hereās console log:
chyduck@homie:~/bananapi/BPI-M2-bsp$ sudo ./build.sh
[sudo] password for chyduck:
BPI-M2 BSP Build Tool
This tool support following BPI board(s):
1. BPI_M2_720P
2. BPI_M2_1080P
3. BPI_M2_LCD7
4. BPI_M2_USB_720P
5. BPI_M2_USB_1080P
6. BPI_M2_USB_LCD7
Please choose a target(1-6): 1
Now configuring...
BPI_M2_720P configured. Now run `make`
Configure success!
This tool support following building mode(s):
1. Build all, uboot and kernel and pack to download images.
2. Build uboot only.
3. Build kernel only.
4. kernel configure.
5. Build rootfs for linux, and copy target files to output
ROOTFS=/xxx/rootfs.tar.gz
This is optinal, default using rootfs/linux/default_linux_rootfs.tar.gz.
6. Pack the builds to target download image, this step must execute after u-boot,
kernel and rootfs build out
7. Clean all build.
Please choose a mode(1-6): 1
Now building...
#mkdir -p /home/chyduck/bananapi/BPI-M2-bsp/build/BPI_M2_720P/sun6i-u-boot
#make -C u-boot-sunxi sun6i_config O=/home/chyduck/bananapi/BPI-M2-bsp/build/BPI_M2_720P/sun6i-u-boot CROSS_COMPILE=/home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi- -j6
make -C u-boot-sunxi sun6i_config CROSS_COMPILE=/home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi- -j6
make[1]: Entering directory '/home/chyduck/bananapi/BPI-M2-bsp/u-boot-sunxi'
/bin/bash: /home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi-gcc: No such file or directory
dirname: missing operand
Try 'dirname --help' for more information.
Configuring for sun6i board...
make[1]: Leaving directory '/home/chyduck/bananapi/BPI-M2-bsp/u-boot-sunxi'
#make -C u-boot-sunxi all O=/home/chyduck/bananapi/BPI-M2-bsp/build/BPI_M2_720P/sun6i-u-boot CROSS_COMPILE=/home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi- -j6
make -C u-boot-sunxi all CROSS_COMPILE=/home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi- -j6
Generating include/autoconf.mk
/bin/bash: line 3: /home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi-gcc: No such file or directory
Generating include/autoconf.mk.dep
/bin/bash: /home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi-ld: No such file or directory
/home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/arm-linux-gnueabi-gcc -DDO_DEPS_ONLY \
-g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -I/home/chyduck/bananapi/BPI-M2-bsp/u-boot-sunxi/include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -mcpu=cortex-a7 -Werror -Wall -Wstrict-prototypes \
-o lib/asm-offsets.s lib/asm-offsets.c -c -S
Makefile:556: recipe for target 'lib/asm-offsets.s' failed
make[1]: *** [lib/asm-offsets.s] Error 127
Makefile:41: recipe for target 'u-boot' failed
make: *** [u-boot] Error 2
Build success!
UPD: Iāve install all of tools what is needed to build.
HI: your build environment? 32bit? 64bit?
It matters? I try to build in on Ubuntu 15.10 x64
Hi Justin,
The script builds successfully, except that the kernel name is ā3.3.0-BPI-Kernel-V0.1ā instead of ā3.3.0-BPI-Kernelā as assumed in cp_download_files()
I followed all the steps in document too, except the last one, where I assume you mean:
sudo ln -s <download_directory>lib/modules/3.11.0-15-generic/ modules instead of sudo ln -s /lib/modules/3.11.0-15-generic/ modules
(and I am using the ubuntu rootfs instead of debian)
But, the image doesnāt boot, and thereās no boot log on the UART pins either so I am unable to debug.
ā
Has anybody else had any success in getting an working image?
Hi chyDuck,
Can you post of the output of ls -l /home/chyduck/bananapi/BPI-M2-bsp/allwinner-tools/toolchain/bin/
No. Only community provided efforts helped: For example this http://www.bananapi.com/index.php/forum/general-discussion-for-bpi-m2/995-working-wifi-on-modern-kernels-4-1-tested or now Armbian. I tried all tutorials here but not a single one works and itās not possible to build OS images.
Thanks, Iāll check out that post. I already use Armbian now, just thought Iāll try to build an image using this kernel to see if it had all the drivers.
