I have flashed openwrt to emmc of my BPI-R64. It worked initially. Due to some setting errors, somehow the board could not boot up. This is the error messages:
MT7622>
F0: 102B 0000
F6: 3800 00A0
F3: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0000 0041 [0000]
G0: 0190 0000
T0: 0000 0333 [000F]
Jump to BL
UNIVPLL_CON0 = 0xFE000000!!!
mt_pll_init: Set pll frequency for 25M crystal
RAM_CONSOLE preloader last status: 0x0 0x0 0x0 0x0 0x0 0x0
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic_init] Preloader Start..................
[pmic_init] MT6380 CHIP Code, reg_val = 0, 1:E2 0:E3
[pmic_init] Done...................
Chip part number:7622A
MT7622 Version: 1.2.7, (iPA)
SSC OFF
mt_pll_post_init: mt_get_cpu_freq = 1350000Khz
mt_pll_post_init: mt_get_mem_freq = 1600000Khz
mt_pll_post_init: mt_get_bus_freq = 1119920Khz
[PLFM] Init I2C: OK(0)
[BLDR] Build Time: 20180622-162441
==== Dump RGU Reg ========
RGU MODE: 4D
RGU LENGTH: FFE0
RGU STA: 0
RGU INTERVAL: FFF
RGU SWSYSRST: 8000
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
mtk_wdt_mode_config mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
WDT NONRST=0x20000000
WDT IRQ_EN=0x340003
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
[EMI] MDL number = 2
[EMI] DRAMC calibration start
[EMI] DRAMC calibration end
[EMI]rank0 size: 0x40000000
[MEM] complex R/W mem test pass
RAM_CONSOLE wdt status (0x0)=0x0
[mmc_init]: msdc0 start mmc_init_host() in PL...
[msdc_init]: msdc0 Host controller intialization start
[SD0] Pins mode(1), none(0), down(1), up(2), keep(3)
[SD0] Pins mode(2), none(0), down(1), up(2), keep(3)
[info][msdc_set_startbit 1127] read data start bit at rising edge
[info][msdc_config_clksrc] input clock is 400000kHz
[SD0] Bus Width: 1
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(385) DS(0) RS(0)
[msdc_init]: msdc0 Host controller intialization done
[mmc_init]: msdc0 start mmc_init_card() in PL...
[mmc_init_card]: start
[SD0] Bus Width: 8
[SD0] Switch to High-Speed mode!
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(192) DS(0) RS(0)
[SD0] Bus Width: 8
[SD0] Size: 7456 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15269888), ro(0)
[mmc_init_mem_card 3140][SD0] Initialized, eMMC50
before host->cur_bus_clk(259740)
[SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(1) DS(0) RS(0)
host->cur_bus_clk(50000000)
[mmc_init_card]: finish successfully
[PLFM] Init Boot Device: OK(0)
[GPT_PL]Parsing Primary GPT now...
[GPT_PL][0]name=tee1, part_id=8, start_sect=0x400, nr_sects=0x200
[GPT_PL][1]name=lk, part_id=8, start_sect=0x600, nr_sects=0x400
[GPT_PL][2]name=nvram, part_id=8, start_sect=0xA00, nr_sects=0x400
[GPT_PL][3]name=rf, part_id=8, start_sect=0xE00, nr_sects=0x200
[GPT_PL][4]name=boot, part_id=8, start_sect=0x1000, nr_sects=0xA000
[GPT_PL][5]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][6]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][7]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][8]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][9]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][10]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][11]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][12]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][13]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][14]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][15]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][16]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][17]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][18]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][19]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][20]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][21]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][22]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][23]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][24]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][25]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][26]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][27]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][28]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][29]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][30]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][31]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][32]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][33]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][34]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][35]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][36]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][37]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][38]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][39]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][40]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][41]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][42]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][43]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][44]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][45]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][46]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][47]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][48]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][49]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][50]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][51]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][52]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][53]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][54]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][55]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][56]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][57]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][58]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][59]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][60]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][61]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][62]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][63]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][64]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][65]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][66]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][67]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][68]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][69]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][70]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][71]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][72]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][73]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][74]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][75]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][76]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][77]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][78]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][79]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][80]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][81]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][82]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][83]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][84]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][85]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][86]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][87]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][88]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][89]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][90]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][91]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][92]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][93]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][94]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][95]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][96]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][97]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][98]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][99]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][100]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][101]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][102]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][103]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][104]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][105]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][106]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][107]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][108]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][109]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][110]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][111]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][112]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][113]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][114]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][115]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][116]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][117]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][118]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][119]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][120]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][121]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][122]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][123]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][124]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][125]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][126]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][127]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL]Success to find valid GPT.
[PART] blksz: 512B
[PART] [0x0000000000080000-0x00000000000BFFFF] "tee1" (512 blocks)
[PART] [0x00000000000C0000-0x000000000013FFFF] "lk" (1024 blocks)
[PART] [0x0000000000140000-0x00000000001BFFFF] "nvram" (1024 blocks)
[PART] [0x00000000001C0000-0x00000000001FFFFF] "rf" (512 blocks)
[PART] [0x0000000000200000-0x00000000015FFFFF] "boot" (40960 blocks)
[PART] [0x0000000000000000-0x00000000000001FF] "" (1 blocks)
Device APC domain init setup:
Domain Setup (0x0)
Domain Setup (0x0)
Device APC domain after setup:
Domain Setup (0x0)
Domain Setup (0x0)
[get_part] part->nr_sects=512, part->info->name=tee1
[get_part] part->nr_sects=1024, part->info->name=lk
[PART] Image with part header
[PART] name : U-Boot
[PART] addr : 41E00000h mode : -1
[PART] size : 246424
[PART] magic: 58881688h
[PART] load "lk" from 0x00000000000C0200 (dev) to 0x41E00000 (mem) [SUCCESS]
[PART] load speed: 10938KB/s, 246424 bytes, 22ms
load lk (ret=0)
[PART] name : atf
[PART] addr : FFFFFFFFh mode : -1
[PART] size : 62032
[PART] load "tee1" from 0x0000000000080200 (dev) to 0x43000DC0 (mem) [SUCCESS]
[PART] load speed: 6730KB/s, 62032 bytes, 9ms
load tee1 (ret=0)
[BLDR] bldr load tee part ret=0x0, addr=0x43001000
[get_part] part->nr_sects=1024, part->info->name=nvram
[get_part] part->nr_sects=512, part->info->name=rf
[get_part] part->nr_sects=40960, part->info->name=boot
[BLDR] part_load_raw_part ret=0x0
[BLDR] part_load_images ret=0x0
[BLDR] Others, jump to ATF
[BLDR] jump to 0x41E00000
[BLDR] <0x41E00000>=0xEA00000F
[BLDR] <0x41E00004>=0xE59FF014
U-Boot 2014.04-rc1 (May 09 2019 - 19:22:09)
auto detection g_total_rank_size = 0x3F000000
DRAM: 1008 MiB
dev_num = 0
***size=4096, offset=1310720, blk_start=2560, blk_cnt=8
In: serial
Out: serial
Err: serial
dev_num = 0
Net: mtk_eth
Uip activated
*** U-Boot EMMC ***
1. System Load Linux to SDRAM via TFTP.
2. System Load Linux Kernel then write to Flash via TFTP.
3. Boot system code via Flash.
4. System Load U-Boot then write to Flash via TFTP.
5. System Load U-Boot then write to Flash via Serial.
6. System Load ATF then write to Flash via TFTP.
7. System Load Preloader then write to Flash via TFTP.
8. System Load ROM header then write to Flash via TFTP.
9. System Load CTP then write to Flash via TFTP.
a. System Load CTP then Boot to CTP (via Flash).
b. System Load flashimage then write to Flash via TFTP.
c. System Load partition table then write to Flash via TFTP.
U-Boot console
Press UP/DOWN to move or Press 1~9,a~c to choose, ENTER to select
mmc0 is current device mmc0 operation dev_num = 0
MMC read: dev # 0, block # 4096, count 1 … 1 blocks read: OK [do_read_image_blks] Image format error,neither FIT image nor old image. Bad Magic Number. mmc0 operation dev_num = 0
MMC read: dev # 0, block # 4096, count 0 … 0 blocks read: OK bootm flag=0, states=70f Wrong Image Format for bootm command ERROR: can’t get kernel image! MT7622>
I have tried the following steps with no success:
Flashed a bootable SD card and changed the boot switch to 1. But the board just loaded the emmc uboot and stuck at the errors message above.
In the emmc uboot, I can not control or select any options in the uboot menu via minicom. My UART usb is working on the other R64 board. Hence, the UART USB should be functioning.
The emmc seems corrupted. I can’t boot or uboot to SD card and I can’t control via UART USB with minicom in emmc uboot.
What else I can do? Or the board is bricked?
Hope someone can help.
Thanks.
