BpiRouter v1.6.1 targets BPI-R3, BPI-R3-Mini, BPI-R4, BPI-R4-Lite, BPI-R4-Pro 8X, BPI-R4-Pro 4E and OpenWrt One , based on OpenWrt 25.12.6. It is a maintenance release with security fixes; we recommend that all users of earlier versions upgrade. Download only the files for your exact model. R4-Pro 8X and 4E use different images.
Security fixes
- The built-in Tailscale client has no standalone updater. Update it through a BpiRouter firmware upgrade.
- First setup no longer opens a shared Wi-Fi network. Earlier versions started Wi-Fi with the same published factory password on every router after first start or a factory reset. Until the setup wizard was completed, anyone in range could join, complete the setup first, or sign in to SSH and LuCI as
rootwithout a password; if Wi-Fi was skipped in the wizard, the shared password stayed in use afterwards. From v1.6.1, a new or reset router keeps Wi-Fi off and stores no Wi-Fi password: first setup uses a network cable on a LAN port, and Wi-Fi can only be turned on with a password of your own. Until the wizard is completed, a computer connected by cable to a LAN port still has the same access as before, so complete setup promptly after installing or resetting the router. - Security updates from OpenWrt 25.12.6 and a Linux kernel fix. The firmware moves from OpenWrt 25.12.5 to 25.12.6, which fixes vulnerabilities in the Wi-Fi stack (hostapd and mac80211, reachable over the air), the LuCI web server and RPC service, OpenSSL and Mbed TLS, among others. It also includes the Linux fix for CVE-2026-98432, a flaw in IPv4 TCP connection handling that a device on the local network could use to crash the router or corrupt its memory. The management service is built with Go 1.27.4, which fixes several HTTP and TLS issues.
- IPsec traffic over IPv6 is no longer forwarded to local devices. OpenWrt’s default firewall rules that let IPsec (ESP and UDP port 500) from the Internet reach local devices also applied to IPv6. With a public IPv6 prefix, these ports on local devices could be reached from the Internet. v1.6.1 restricts the two rules to IPv4 when they are unchanged from the default; rules you have changed are left as they are. Only devices that run IPsec were affected.
Other changes
- Fixed Guest and IoT Wi-Fi client isolation across bands. Enable client isolation on both bands to prevent clients on one band from reaching clients on the other.
- Dynamic DNS fixes cover HTTPS certificate checks, Cloudflare subdomains, provider error reporting and forced updates when the address is unchanged. DuckDNS and Cloudflare were verified with live accounts. No-IP, Dynu and FreeDNS were verified against simulated provider responses.
- WAN MTU settings now apply to the underlying device for DHCP and static WANs. Clear the MTU field to restore the protocol default. If you previously entered a custom DHCP or static WAN MTU, enter it again after upgrading.
- Client names and notes now count the 128-character limit by character and reject control characters.
- The setup wizard fills in the country or region and the time zone from your browser for you to check, and records them even when you skip Wi-Fi. The time zone list now includes every time zone.
- Fixed: saving some time zones in System failed in v1.6.0, for example Singapore and Dubai.
- Fixed: on boards without a battery-backed clock, a user signed in shortly after start-up, for example right after an update or the setup wizard, was signed out once when the router set its clock.
- Fixed:
apk updateno longer reports an error for thebpirouterpackage feed (a v1.6.0 known issue). The v1.6.0 workaround is no longer needed. - Kernel support for software you install yourself: USB storage (including exFAT and NTFS), common USB Ethernet adapters, USB serial adapters used by Zigbee and Thread dongles, compressed memory swap (zram), and the firewall features used by transparent proxies. BpiRouter does not manage these devices; see the feature guide.
Source and help
The public source and build instructions are in this repository. See its README for the build procedure and the proprietary UI package’s licensing terms. Third-party software in the UI package and its licences are listed in THIRD_PARTY_NOTICES.md.
For product support, use the Banana Pi forum or contact Banana Pi. Include your exact model, product version and a description of the problem; never post passwords, tokens, private keys or SIM identifiers.
welcome download and test . any issue, please let us know.
