Hello and good Morning.
I have a BPI-R4 Pro with the Image BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251229.
I’m not sure if should flash the BPIRouter OS v1.5.0 or OpenWRT Snapshot over the firmwareselector now?
Can you pleased help me?
You can just try both with sdcards and choose the right for your needs.
Official openwrt is more recent but may lack some functionality compared with vendor system which is mostly stale at some point. If you look in recent security issues imho a more recent OS should be preferred.
Before committing, boot each image from an SD card and leave the current firmware untouched. Test the things that matter for this board: WAN/LAN port mapping, both 10G/2.5G links, the BE14 Wi-Fi radios, LEDs/fan control, and whether you need vendor extras. If the snapshot covers those, its newer security base is the better long-term choice; otherwise use BPIRouter for convenience.
