BpiR2 kernel 5.15 Debian
Hi sorry for my english , thanks Frank for Debian
System:
  Kernel: 5.10.64-bpi-r2-main armv7l bits: 32 compiler: gcc v: 10.2.1
  Console: tty 0 Distro: Debian GNU/Linux 11 (bullseye)
Machine:
  Type: ARM Device System: Bananapi BPI-R2 details: Mediatek Cortex-A7
Partition:
  ID-1: / size: 28.86 GiB used: 12.79 GiB (44.3%) fs: ext4
  dev: /dev/mmcblk0p2
  ID-2: /boot size: 255.7 MiB used: 31.5 MiB (12.3%) fs: vfat
  dev: /dev/mmcblk0p1
I built kernel 5.15
[email protected]:~/BPI-Router-Linux$ ./build.sh
Build Kernel
Cleanup Kernel Build
depency-check currently only on debian/ubuntu...
generate branch vars...
getting git branch:
* 5.15-main
kernbranch:5.15-main,gitbranch:-main
  CALL    scripts/atomic/check-atomics.sh
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  CHK     kernel/kheaders_data.tar.xz
  Kernel: arch/arm/boot/Image is ready
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
Image Name:   Linux Kernel 5.15.94-main
Created:      Sat Mar 18 11:06:40 2023
Data Size:    7855785 Bytes = 7671.67 KiB = 7.49 MiB
Load Address: 80008000
Entry Point:  80008000
build uImage without appended DTB...
Created:      Sat Mar 18 11:07:29 2023
Data Size:    7819776 Bytes = 7636.50 KiB = 7.46 MiB
1) pack
2) install to SD-Card
3) deb-package
4) upload
does not start
 8446344   uImage
            dtb/
  8411480   uImage_nodt
  8234828   uImage_5.10.64-main
       27   uEnv.txt
  7855849   uImage_5.15.94-main
5 file(s), 3 dir(s)
enter uImage-name: uImage_5.15.94-main
kernelinput=uImage_5.15.94-main
    44505   bpi-r2.dtb
    36009   bpi-r2_5.15.dtb
2 file(s), 2 dir(s)
enter dtb-name:  bpi-r2_5.15.dtb
dtbinput= bpi-r2_5.15.dtb
bootargs=board=bpi-r2 earlyprintk console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait vmalloc=496M debug=7 initcall_debug=0 video=1920x1080 console=tty1 fbcon=map:0 drm.debug=0x7
loading kernel uImage_5.15.94-main...
7855849 bytes read in 393 ms (19.1 MiB/s)
fdt=bpi-r2_5.15.dtb
36009 bytes read in 7 ms (4.9 MiB/s)
## Error: "dtolist" not defined
## Booting kernel from Legacy Image at 80200000 ...
   Data Size:    7855785 Bytes = 7.5 MiB
   Verifying Checksum ... OK
## Flattened Device Tree blob at 83f00000
   Booting using the fdt blob at 0x83f00000
   Loading Kernel Image
   Using Device Tree in place at 83f00000, end 83f0bca8
Starting kernel ...
still nothing reboot bootmenu ,
where is the problem ???
you have installed the uImage with dtb or without? the combined uImage has to be loaded without the extra dtb (leave question empty)
  1. pack
  2. install to SD-Card
  3. deb-package
  4. upload
I copied by hand option 1)
and option 2
  8446344   uImage
        dtb/
  8411480   uImage_nodt
   27   uEnv.txt
5 file(s), 3 dir(s)
    44505   bpi-r2.dtb
2 file(s), 2 dir(s)
enter dtb-name:
## Error: "dtbinput" not defined
## Error: "fdt" not defined
Starting kernel ...
install asks for installing uImage with dtb (default) or separate, pack has both kernel files and dtb (=3 files)
so either you use uImage_nodt and dtb or only uImage (leave dtb empty)
install also shows what to add to uEnv.txt (kernel=…) for automatic boot
please select your output and then press the </> button…this indents the output by 4 spaces and makes it better readable
tried booting the uImage (with dtb) by leaving dtb-question empty…same output as yours and boots
  7855849   uImage
    dtb/
  7819840   uImage_nodt
  8234828   uImage_5.10.64-main   >>>  OK
   27   uEnv.txt
  7855849   uImage_5.15.94-main   >>> does not start
  7855849   uImage
        dtb/
  7819840   uImage_nodt
   27   uEnv.txt
5 file(s), 3 dir(s)
enter uImage-name:  uImage_nodt
kernelinput= uImage_nodt
44505   bpi-r2.dtb
2 file(s), 2 dir(s)
enter dtb-name:
loading kernel uImage_nodt...
7819840 bytes read in 387 ms (19.3 MiB/s)
   Data Size:    7819776 Bytes = 7.5 MiB
Starting kernel ...
compilation requires special options ?
if you have it compiled with my build.sh (like it looks for me) it should work…if you do manual install you may miss any step
please use the </> button to format your output the right way (select the text and press the button)…you can use preview function to verify before sending
ok bpi-r2 5.10.64-bpi-r2-main problem USB octoprint
[email protected]:~$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/local/libexec/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: ../configure
Thread model: posix
Supported LTO compression algorithms: zlib
gcc version 11.1.0 (GCC)
version maybe a problem? Frank you are sharing the kernel 5.15
Possible that gcc version has problem,you could try use gcc 10 or files from github releases
make[1]: Leaving directory '/home/adam/build'
Image Name:   Linux Kernel 6.1.12-main
Created:      Sat Mar 18 17:02:36 2023
Data Size:    8624603 Bytes = 8422.46 KiB = 8.23 MiB
Created:      Sat Mar 18 17:02:47 2023
Data Size:    8590328 Bytes = 8388.99 KiB = 8.19 MiB
1) pack
3) deb-package
4) upload
now it is working
[email protected]:~#  neofetch
       _,met$$$$$gg.          [email protected]
    ,g$$$$$$$$$$$$$$$P.       -----------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 11 (bullseye) armv7l
 ,$$P'              `$$$.     Host: Bananapi BPI-R2
',$$P       ,ggs.     `$$b:   Kernel: 6.1.12-bpi-r2-main
`d$$'     ,$P"'   .    $$$    Uptime: 5 mins
 $$P      d$'     ,    $$P    Packages: 1220 (dpkg)
 $$:      $$.   -    ,d$$'    Shell: bash 5.1.4
 $$;      Y$b._   _,d$P'      Terminal: /dev/ttyS0
 Y$$.    `.`"Y$$$$P"'         CPU: Mediatek Cortex-A7 (Device Tree) (4) @ 1.300GHz
 `$$b      "-.__              Memory: 322MiB / 2010MiB
  `Y$$                        CPU Usage: 26%
   `Y$$.                      Disk (/): 13G / 29G (47%)
     `$$b.                    Local IP: 192.168.1.132
       `Y$$b.
          `"Y$b._
octoprint
[email protected]:~# [  242.991478] usb 3-1: new full-speed USB device number 2 using xhci-mtk
[  243.177866] mediatek-disp-rdma 14012000.rdma: deferred probe timeout, ignoring dependency
[  243.186519] mediatek-disp-rdma 14012000.rdma: Failed to add component: -517
[  243.220013] usbcore: registered new interface driver ch341
[  243.225786] usbserial: USB Serial support registered for ch341-uart
[  243.232325] ch341 3-1:1.0: ch341-uart converter detected
[  243.239171] usb 3-1: ch341-uart converter now attached to ttyUSB0
$ /home/pi/.local/bin/./octoprint
Starting the server via "octoprint" is deprecated, please use "octoprint serve" from now on.
2023-03-18 17:34:35,855 - octoprint.startup - INFO - ******************************************************************************
2023-03-18 17:34:35,861 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2023-03-18 17:34:35,861 - octoprint.startup - INFO - ******************************************************************************
2023-03-18 17:34:37,015 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2023-03-18 17:34:37,016 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2023-03-18 17:34:37,016 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2023-03-18 17:34:37,471 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2023-03-18 17:34:37,653 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/.local/lib/python3.9/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2023-03-18 17:34:45,605 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2022.6.13) did not pass check, not loading.
2023-03-18 17:34:46,001 - octoprint.plugin.core - INFO - Found 19 plugin(s) providing 19 mixin implementations, 38 hook handlers
2023-03-18 17:34:46,150 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2023-03-18 17:34:46,507 - octoprint.server - INFO - Intermediary server started
thank you Frank
Was gcc 11 the cause?
no 11 is ok , there are still a few problems but you did a great job
why was it not booting?
ah, i see you switched to 6.1…is 5.15 currently broken (maybe it can be fixed with updating point-release)?
6.1. does not support internal wifi from r2
i know i read your github
 Network:
      Device-1: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Network Adapter
      driver: ath10k_pci v: kernel bus ID: 01:00.0
tried 5.15.94 (current version from my github) and works for me
Linux bpi-r2 5.15.94-bpi-r2-main #2 SMP Sat Mar 18 18:41:10 CET 2023 armv7l
but currently i use this gcc (10):
$ arm-linux-gnueabihf-gcc -v
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/arm-linux-gnueabihf/10/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 10.4.0-4ubuntu1~22.04' --with-bugurl=file:///usr/share/doc/gcc-10/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-10 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --without-target-system-zlib --enable-multiarch --disable-sjlj-exceptions --with-arch=armv7-a+fp --with-float=hard --with-mode=thumb --disable-werror --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabihf --program-prefix=arm-linux-gnueabihf- --includedir=/usr/arm-linux-gnueabihf/include --with-build-config=bootstrap-lto-lean --enable-link-mutex
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 10.4.0 (Ubuntu 10.4.0-4ubuntu1~22.04)
I modified make menuconfig maybe I messed something up
Have updated all lts branches,maybe there is a backported fix for gcc11 in 5.15. just try again :slight_smile: as you got 6.1 working,you know the steps
Thanks, I’ll check that and the wifi :slightly_smiling_face:
