BPI-R64 Ubuntu 16.04 & AArch64 Linux Lite & Debian 10 Buster Lite Demo Images Release 2019-08-23
  1. About this release
  • This release is for banana pi R64 board, and it is based on Ubuntu 16.04 & AArch64 Linux Lite & Debian 10 Buster Lite Operation system with kernel 4.19.
  1. AArch64 Linux lite
  1. Debian 10 buster lite
  1. Ubuntu Server 16.04
  1. FAQ
  • username : root/pi
  • password : bananapi
which board-versions are supported?
I ask because there are 2 different switches (rtl8367 & mt7531)
Hello, this switch mt7531
Do you use my repo (currently untested mt7531-driver) or have you an own repo?
Hello frank, I have a own repo, after the wifi and bt driver work, and we will public the repo soon.
Images seems to support emmc, which additional steps are needed to get it running on emmc (e.g. preloader to boot0,changing hw-partitions)? Which preloader needs to be written (is this done by bpi-copy)?
I would also like to know how to write the image to eMMC as I’ve tried several wais to no avail…
i tried with new preloader from oct 2nd
echo 0 > /sys/block/mmcblk1boot0/force_ro
dd if=preloader_evb7622_64_foremmc.bin of=/dev/mmcblk1boot0
unzip -p 2019-08-23-debian-10-buster-lite-preview-bpi-r64-sd-emmc.img.zip | dd of=/dev/mmcblk1 bs=1M
still error in uboot (failing to access emmc)
full bootlog here: Bpi-r64 quick start (boot from eMMC)
are these images really emmc-ready, especially uboot? I see some changes here in config.in which maybe relevant and not yet in the image
|||if [ "$ON_BOARD_SPI_NAND_FLASH_COMPONENT" = "y" ]; then|
|||#BPI|
|||define_bool ON_BOARD_NO_FLASH_COMPONENT n|
|||#BPI|
|||#if [ "$ON_BOARD_SPI_NAND_FLASH_COMPONENT" = "y" ]; then|
|||define_bool CONFIG_MTK_MTD_NAND y|
|||define_bool CONFIG_MTK_SLC_NAND_SUPPORT y|
|||define_bool CONFIG_MTK_SPI_NAND_SUPPORT y|
|||fi|
|||#fi|
have now booted first time the debian buster image with new r64-board
power consumption is about 4.6w in default configuration (no pcie/wifi/bt active) while running apt upgrade (4.0w in idle)…after powerdown: 4.8w :frowning: something is strange here
first thing i’ve noticed was readonly rootfs because of wrong uuid in /etc/fstab
root@bpi-iot-ros-ai:~# blkid
/dev/mmcblk1p1: LABEL_FATBOOT="BPI-BOOT" LABEL="BPI-BOOT" UUID="1539-6609" TYPE=
"vfat" PARTUUID="e43da9c5-01"
/dev/mmcblk1p2: LABEL="BPI-ROOT" UUID="80463388-3170-483b-ac00-378b69a7a277" TYP
E="ext4" PARTUUID="e43da9c5-02"
fstab:
UUID=c1401c29-e4d8-4924-8799-8b0f3a77b79b / ext4 defaults,noatime,nodiratime,com
mit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
after i’ve fixed this (with vi because nano is currently unusable on serial, also tried with “resize” and changing $TERM) i got a rw-rootfs
on first apt update i got errors about not-yet-valid release file…this is because the system clock is wrong. this can be quick-fixed by
date -s '2019-10-11'
maybe anybody have an idea about nano (and some menus from apt/dpkg looking strange/no cursor/selection visible).
i expect there is any wrong console setting
root@bpi-iot-ros-ai:~# stty -a
speed 115200 baud; rows 24; columns 120; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>; eol2 = <undef>; swtch = <undef>; start = ^Q;
stop = ^S; susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V; discard = ^O; min = 1; time = 0;
-parenb -parodd -cmspar cs8 hupcl -cstopb cread -clocal -crtscts
-ignbrk brkint ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl ixon -ixoff -iuclc -ixany imaxbel -iutf8
opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
isig icanon iexten echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke -flusho -extproc
on ssh it works, tried setting same console settings, but this does not help…seems to be another problem…
it should be noted that debian buster is the armbian-version not the debian basic version…maybe nano is broken there
replaced rootfs with bootstrapped rootfs from original debian buster does not show this nano-issue
Old content
tried also with changes in config.in for emmc-support (commit above), but still unknown partition table/no mmc card found
other changes in mt7622_evb.h as far as i see are only sd-card-relevant (inside #elif defined(OFF_BOARD_SD_CARD_COMPONENT) )
i guess it’s last one because mmc1 block 0 is printed and not only 0 can i check if the right HW-Partition is read?
BPI-R64> mmc init 1
raise: Signal # 8 caught
ret2 = 1
ret2 = 1
<= [mmc1 block 0] =>
[0x00000000] 8c 7c f2 7c 00 00 00 00
[0x00000008] 0a 00 00 00 d0 b9 f5 7e
[0x00000010] 0a 00 00 00 ff ff ff ff
[0x00000018] ff ff ff ff 02 00 00 00
[0x00000020] 40 7c f2 7c 0b 7c f6 7e
[0x00000028] c0 c2 f2 7c dc 00 00 00
i had read out my emmc from linux userspace:
root@bpi-r64:~# hd /dev/mmcblk1 | less
00000000  53 44 4d 4d 43 5f 42 4f  4f 54 00 00 01 00 00 00  |SDMMC_BOOT......|
00000010  00 02 00 00 ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000020  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
root@bpi-r64:~# hd /dev/mmcblk1boot0 | less
00000000  45 4d 4d 43 5f 42 4f 4f  54 00 00 00 01 00 00 00  |EMMC_BOOT.......|
root@bpi-r64:~# hd /dev/mmcblk1boot1 | less
00000000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
root@bpi-r64:~# hd /dev/mmcblk1p1 | less
00000000  eb 58 90 6d 6b 66 73 2e  66 61 74 00 02 01 20 00  |.X.mkfs.fat... .|
00000010  02 00 00 00 00 f8 00 00  20 00 40 00 00 00 00 00  |........ .@.....|
00000020  00 00 08 00 c1 0f 00 00  00 00 00 00 02 00 00 00  |................|
root@bpi-r64:~# hd /dev/mmcblk1p2 | less
00000400  f0 c7 06 00 00 1b 1b 00  f3 5a 01 00 2a 78 12 00  |.........Z..*x..|
00000410  c2 2d 06 00 00 00 00 00  02 00 00 00 02 00 00 00  |.-..............|
root@bpi-r64:~# hd /dev/mmcblk1rpmb | less
hd: /dev/mmcblk1rpmb: Invalid argument
so none of my emmc-partitions start with the bytes printed by uboot (8c 7c f2 7c 00 00 00 00)
Edit (cannot make new reply):
Got emmc working here
Old uboot always access sdcard. At least the debian-image is affected. But you can flash this and after that replace uboot with one of my binaries (matching your switch-chip)
Hi @Jackzeng @sinovoip does your repo contain wifi-/bt-driver? I have not found it yet…
