[BPI-R64] PWM-support
device is banana pi r3
pwm0 on r3 is mapped to fan-socket (aquired pwm-fan) via dts, pwm1 is exposed on gpio-header
log.txt (13.0 KB) No help. Some demsg info shown in log.
[    0.047861] pwm-mediatek 10048000.pwm: clock: top fail: -517
Your pwm controller is not setup right, 517 should be deferred probe (try later because depencies missing),but i do not see a later attempt…there are also pcie errors…have you modified code/dts of your kernel?
I do not modify code/dts of kernel.
Here is the default dts in the default source code.mt7986a-bananapi-bpi-r3.dts (16.0 KB)
The address of source code is at https://github.com/coolsnowwolf/lede.
you should open a new topic as this is for r64 and completely different. and please do not create 3 postings in same thread in a few minutes…you can edit your postings to add additional information ("…" and then the pen)
you should also first try with official openwrt and then switch to the specific fork.
