BPI-R64 + OpenWRT + AW7916-NPD - no 6Ghz
I have a BPI-R64 with a AW7916-NPD Wi-Fi 6E AX3000 Mini PCIe installed running OpenWRT 25.05.2. I have the 5GHz radio working fine but I can’t seem to get it working at 6GHz. If I select the 6GHz band in OpenWRT I can’t see any 6GHz networks on my phone.
I tried adding the enable_ipa_6ghz parameter to the config for the mt7915e module after reading a long thread on github but the paramter is unknown. Excerpt from dmesg:
[    7.659933] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address ca:c1:66:cd:bf:58
[    7.675575] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    7.690678] mt7915e: unknown parameter 'enable_ipa_6ghz' ignored
[    7.697013] mt7915e 0000:01:00.0: assign IRQ: got 148
[    7.702172] mt7915e 0000:01:00.0: enabling device (0000 -> 0002)
[    7.708285] mt7915e 0000:01:00.0: enabling bus mastering
[    7.714346] mt7622-wmac 18000000.wmac: Failed to get patch semaphore
[    7.787307] mtk-pcie 1a143000.pcie: msi#0 address_hi 0x0 address_lo 0x44da50c0
[    7.839172] mt7915e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20230202144915a
[    7.839172]
[    7.888000] Bluetooth: hci0: Device setup in 319487 usecs
[    7.933838] mt7915e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20230202145005
[    7.997924] mt7915e 0000:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20230202143332
The AW7916-NPD appears in OpenWRT as a generic device. Is this expected:
Could someone that has an R64 with the 6GHz band working let me know their config please? What version of OpenWRT is working, the config in /etc/config/wireless, an excerpt from dmesg, etc. so I can try and find out what is different in my setup. I’ve seen posts from several people that have it working and I’d like to copy that config.
lspci -vvv in case it’s of any use:
01:00.0 Network controller: MEDIATEK Corp. Device 7906
        Subsystem: MEDIATEK Corp. Device 7906
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 154
        Region 0: Memory at 20000000 (64-bit, prefetchable) [size=1M]
        Region 2: Memory at 20100000 (64-bit, non-prefetchable) [size=32K]
        Region 4: Memory at 20108000 (64-bit, prefetchable) [size=4K]
        Capabilities: [80] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #1, Speed 5GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <2us, L1 <8us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x1 (downgraded)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
                         10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Disabled,
                         AtomicOpsCtl: ReqEn-
                LnkCap2: Supported Link Speeds: 2.5-5GT/s, Crosslink- Retimer- 2Retimers- DRS-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [e0] MSI: Enable+ Count=1/32 Maskable+ 64bit+
                Address: 0000000044da50c0  Data: 0000
                Masking: fffffffe  Pending: 00000000
        Capabilities: [f8] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [108 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [110 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=3us PortTPowerOnTime=52us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=0us LTR1.2_Threshold=65536ns
                L1SubCtl2: T_PwrOn=52us
        Capabilities: [200 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Kernel driver in use: mt7915e
Thanks.
Please type the following two commands to share the log. Thank you.
#iw phy
#hexdump -C /sys/kernel/debug/ieee80211/phy0/mt76/eeprom | head -n 20
BusyBox v1.36.1 (2023-11-14 13:38:11 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 23.05.2, r23630-842932a63d
root@OpenWrt:~# iw phy
Wiphy wl1.1
        wiphy index: 2
        max # scan SSIDs: 4
        max scan IEs length: 2190 bytes
        max # sched scan SSIDs: 0
        max # match sets: 0
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports AP-side u-APSD.
        Device supports T-DLS.
        Available Antennas: TX 0x3 RX 0x3
        Configured Antennas: TX 0x3 RX 0x3
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 2:
                Capabilities: 0x9ff
                        RX LDPC
                        HT20/HT40
                        SM Power Save disabled
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 7935 bytes
                        No DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: 4 usec (0x05)
                HT TX/RX MCS rate indexes supported: 0-15
                VHT Capabilities (0x339a59f6):
                        Max MPDU length: 11454
                        Supported Channel Width: 160 MHz
                        RX LDPC
                        short GI (80 MHz)
                        short GI (160/80+80 MHz)
                        TX STBC
                        SU Beamformer
                        SU Beamformee
                        MU Beamformer
                        MU Beamformee
                        RX antenna pattern consistency
                        TX antenna pattern consistency
                VHT RX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                        3 streams: not supported
                        4 streams: not supported
                        5 streams: not supported
                        6 streams: not supported
                        7 streams: not supported
                        8 streams: not supported
                VHT RX highest supported: 0 Mbps
                VHT TX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                VHT TX highest supported: 0 Mbps
                VHT extended NSS: supported
                HE Iftypes: managed
                        HE MAC Capabilities (0x08011a000040):
                                +HTC HE Supported
                                Trigger Frame MAC Padding Duration: 2
                                OM Control
                                Maximum A-MPDU Length Exponent: 3
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x4c70ce126d00f3164e3f00):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                242 tone RUs/5GHz
                                Device Class: 1
                                LDPC Coding in Payload
                                HE SU PPDU with 1x HE-LTF and 0.8us GI
                                NDP with 4x HE-LTF and 3.2us GI
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                Full Bandwidth UL MU-MIMO
                                Partial Bandwidth UL MU-MIMO
                                DCM Max Constellation: 2
                                DCM Max Constellation Rx: 2
                                SU Beamformee
                                Beamformee STS <= 80Mhz: 3
                                Beamformee STS > 80Mhz: 3
                                Codebook Size SU Feedback
                                Codebook Size MU Feedback
                                Triggered CQI Feedback
                                Partial Bandwidth Extended Range
                                Partial Bandwidth DL MU-MIMO
                                PPE Threshold Present
                                Power Boost Factor ar
                                HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
                                Max NC: 2
                                20MHz in 40MHz HE PPDU 2.4GHz
                                20MHz in 160/80+80MHz HE PPDU
                                80MHz in 160/80+80MHz HE PPDU
                                DCM Max BW: 1
                                Longer Than 16HE SIG-B OFDM Symbols
                                Non-Triggered CQI Feedback
                                TX 1024-QAM
                                RX 1024-QAM
                                RX Full BW SU Using HE MU PPDU with Compression SIGB
                                RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
                        HE RX MCS and NSS set <= 80 MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        HE TX MCS and NSS set <= 80 MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        HE RX MCS and NSS set 160 MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        HE TX MCS and NSS set 160 MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        PPE Threshold 0x39 0x1c 0xc7 0x71 0x1c 0x07
                EHT Iftypes: managed
                        EHT MAC Capabilities (0x0000):
                        EHT PHY Capabilities: (0x0000000000000000):
                        EHT MCS/NSS: (0x):
                        EHT bw <= 80 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
                        EHT bw <= 80 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
                        EHT bw <= 80 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
                        EHT bw=160 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
                        EHT bw=160 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
                        EHT bw=160 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
                HE Iftypes: AP
                        HE MAC Capabilities (0x00051a081044):
                                +HTC HE Supported
                                TWT Responder
                                BSR
                                OM Control
                                BQR
                                A-MSDU in A-MPDU
                                OM Control UL MU Data Disable RX
                        HE PHY Capabilities: (0x0c20ce926f12afd0000c00):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformer
                                SU Beamformee
                                MU Beamformer
                                Sounding Dimensions <= 80Mhz: 2
                                Sounding Dimensions > 80Mhz: 2
                                Triggered SU Beamforming Feedback
                                Triggered MU Beamforming Feedback
                                Max NC: 2
                                STBC Tx > 80MHz
                                STBC Rx > 80MHz
                                TX 1024-QAM
                                RX 1024-QAM
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                EHT Iftypes: AP
                        EHT MCS/NSS: (0x):
                HE Iftypes: mesh point
                        HE MAC Capabilities (0x00011a000040):
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x0c200c0000000000008000):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                EHT Iftypes: mesh point
                        EHT MCS/NSS: (0x):
                Frequencies:
                        * 5180 MHz [36] (23.0 dBm)
                        * 5200 MHz [40] (23.0 dBm)
                        * 5220 MHz [44] (23.0 dBm)
                        * 5240 MHz [48] (23.0 dBm)
                        * 5260 MHz [52] (20.0 dBm) (radar detection)
                        * 5280 MHz [56] (20.0 dBm) (radar detection)
                        * 5300 MHz [60] (20.0 dBm) (radar detection)
                        * 5320 MHz [64] (20.0 dBm) (radar detection)
                        * 5500 MHz [100] (26.0 dBm) (radar detection)
                        * 5520 MHz [104] (26.0 dBm) (radar detection)
                        * 5540 MHz [108] (26.0 dBm) (radar detection)
                        * 5560 MHz [112] (26.0 dBm) (radar detection)
                        * 5580 MHz [116] (26.0 dBm) (radar detection)
                        * 5600 MHz [120] (26.0 dBm) (radar detection)
                        * 5620 MHz [124] (26.0 dBm) (radar detection)
                        * 5640 MHz [128] (26.0 dBm) (radar detection)
                        * 5660 MHz [132] (26.0 dBm) (radar detection)
                        * 5680 MHz [136] (26.0 dBm) (radar detection)
                        * 5700 MHz [140] (26.0 dBm) (radar detection)
                        * 5720 MHz [144] (26.0 dBm) (radar detection)
                        * 5745 MHz [149] (23.0 dBm)
                        * 5765 MHz [153] (23.0 dBm)
                        * 5785 MHz [157] (23.0 dBm)
                        * 5805 MHz [161] (23.0 dBm)
                        * 5825 MHz [165] (23.0 dBm)
                        * 5845 MHz [169] (disabled)
                        * 5865 MHz [173] (disabled)
                        * 5885 MHz [177] (disabled)
        Band 4:
                HE Iftypes: managed
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                                HE40/HE80/5GHz
                                HE160/5GHz
                                242 tone RUs/5GHz
                                Device Class: 1
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformee
                                Max NC: 2
                                DCM Max BW: 1
                                TX 1024-QAM
                                RX 1024-QAM
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        EHT MCS/NSS: (0x):
                HE Iftypes: AP
                                +HTC HE Supported
                                TWT Responder
                                BSR
                                OM Control
                                BQR
                                A-MSDU in A-MPDU
                                HE40/HE80/5GHz
                                HE160/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformer
                                SU Beamformee
                                MU Beamformer
                                Max NC: 2
                                STBC Tx > 80MHz
                                STBC Rx > 80MHz
                                TX 1024-QAM
                                RX 1024-QAM
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                EHT Iftypes: AP
                        EHT MCS/NSS: (0x):
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                                HE40/HE80/5GHz
                                HE160/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        EHT MCS/NSS: (0x):
                Frequencies:
                        * 5955 MHz [1] (23.0 dBm)
                        * 5975 MHz [5] (23.0 dBm)
                        * 5995 MHz [9] (23.0 dBm)
                        * 6015 MHz [13] (23.0 dBm)
                        * 6035 MHz [17] (23.0 dBm)
                        * 6055 MHz [21] (23.0 dBm)
                        * 6075 MHz [25] (23.0 dBm)
                        * 6095 MHz [29] (23.0 dBm)
                        * 6115 MHz [33] (23.0 dBm)
                        * 6135 MHz [37] (23.0 dBm)
                        * 6155 MHz [41] (23.0 dBm)
                        * 6175 MHz [45] (23.0 dBm)
                        * 6195 MHz [49] (23.0 dBm)
                        * 6215 MHz [53] (23.0 dBm)
                        * 6235 MHz [57] (23.0 dBm)
                        * 6255 MHz [61] (23.0 dBm)
                        * 6275 MHz [65] (23.0 dBm)
                        * 6295 MHz [69] (23.0 dBm)
                        * 6315 MHz [73] (23.0 dBm)
                        * 6335 MHz [77] (23.0 dBm)
                        * 6355 MHz [81] (23.0 dBm)
                        * 6375 MHz [85] (23.0 dBm)
                        * 6395 MHz [89] (23.0 dBm)
                        * 6415 MHz [93] (23.0 dBm)
                        * 6435 MHz [97] (disabled)
                        * 6455 MHz [101] (disabled)
                        * 6475 MHz [105] (disabled)
                        * 6495 MHz [109] (disabled)
                        * 6515 MHz [113] (disabled)
                        * 6535 MHz [117] (disabled)
                        * 6555 MHz [121] (disabled)
                        * 6575 MHz [125] (disabled)
                        * 6595 MHz [129] (disabled)
                        * 6615 MHz [133] (disabled)
                        * 6635 MHz [137] (disabled)
                        * 6655 MHz [141] (disabled)
                        * 6675 MHz [145] (disabled)
                        * 6695 MHz [149] (disabled)
                        * 6715 MHz [153] (disabled)
                        * 6735 MHz [157] (disabled)
                        * 6755 MHz [161] (disabled)
                        * 6775 MHz [165] (disabled)
                        * 6795 MHz [169] (disabled)
                        * 6815 MHz [173] (disabled)
                        * 6835 MHz [177] (disabled)
                        * 6855 MHz [181] (disabled)
                        * 6875 MHz [185] (disabled)
                        * 6895 MHz [189] (disabled)
                        * 6915 MHz [193] (disabled)
                        * 6935 MHz [197] (disabled)
                        * 6955 MHz [201] (disabled)
                        * 6975 MHz [205] (disabled)
                        * 6995 MHz [209] (disabled)
                        * 7015 MHz [213] (disabled)
                        * 7035 MHz [217] (disabled)
                        * 7055 MHz [221] (disabled)
                        * 7075 MHz [225] (disabled)
                        * 7095 MHz [229] (disabled)
                        * 7115 MHz [233] (disabled)
        valid interface combinations:
                 * #{ IBSS } <= 1, #{ AP, mesh point } <= 16, #{ managed } <= 19,
                   total <= 19, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 160 MHz }
        HT Capability overrides:
                 * MCS: ff ff ff ff ff ff ff ff ff ff
                 * maximum A-MSDU length
                 * supported channel width
                 * short GI for 40 MHz
                 * max A-MPDU length exponent
                 * min MPDU start spacing
        max # scan plans: 1
        max scan plan interval: -1
        max scan plan iterations: 0
        Supported extended features:
                * [ VHT_IBSS ]: VHT-IBSS
                * [ RRM ]: RRM
                * [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
                * [ BEACON_RATE_HT ]: HT beacon rate setting
                * [ BEACON_RATE_VHT ]: VHT beacon rate setting
                * [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
                * [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
                * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
                * [ ACK_SIGNAL_SUPPORT ]: ack signal level support
                * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
                * [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
                * [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
                * [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
                * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
                * [ STA_TX_PWR ]: TX power control per station
                * [ AQL ]: Airtime Queue Limits (AQL)
                * [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
                * [ DEL_IBSS_STA ]: deletion of IBSS station support
                * [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
                * [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
                * [ FILS_DISCOVERY ]: FILS discovery frame transmission support
                * [ UNSOL_BCAST_PROBE_RESP ]: unsolicated broadcast probe response transmission support
                * [ BEACON_RATE_HE ]: HE beacon rate support (AP/mesh)
                * [ BSS_COLOR ]: BSS coloring support
                * [ RADAR_BACKGROUND ]: Radar background support
Wiphy phy1
        wiphy index: 1
        max # scan SSIDs: 4
        max scan IEs length: 2200 bytes
        max # match sets: 0
        Retry long limit: 4
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 1:
                Capabilities: 0x9ff
                        RX LDPC
                        HT20/HT40
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        No DSSS/CCK HT40
                HE Iftypes: managed
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x2270ce126d00f30e4e3f00):
                                HE40/2.4GHz
                                242 tone RUs/2.4GHz
                                Device Class: 1
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformee
                                Max NC: 1
                                DCM Max BW: 1
                                TX 1024-QAM
                                RX 1024-QAM
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        EHT MCS/NSS: (0x):
                        EHT bw=20 MHz, max NSS for MCS 0-7: Rx=0, Tx=0
                        EHT bw=20 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
                        EHT bw=20 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
                        EHT bw=20 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
                HE Iftypes: AP
                                +HTC HE Supported
                                TWT Responder
                                BSR
                                OM Control
                                BQR
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x0220ce926f09afc8000c00):
                                HE40/2.4GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformer
                                SU Beamformee
                                MU Beamformer
                                Sounding Dimensions <= 80Mhz: 1
                                Sounding Dimensions > 80Mhz: 1
                                Max NC: 1
                                STBC Tx > 80MHz
                                STBC Rx > 80MHz
                                TX 1024-QAM
                                RX 1024-QAM
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                EHT Iftypes: AP
                        EHT MCS/NSS: (0x):
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x02200c0000000000008000):
                                HE40/2.4GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                                1 streams: MCS 0-11
                                2 streams: MCS 0-11
                        EHT MCS/NSS: (0x):
                Frequencies:
                        * 2412 MHz [1] (17.0 dBm)
                        * 2417 MHz [2] (17.0 dBm)
                        * 2422 MHz [3] (17.0 dBm)
                        * 2427 MHz [4] (17.0 dBm)
                        * 2432 MHz [5] (17.0 dBm)
                        * 2437 MHz [6] (17.0 dBm)
                        * 2442 MHz [7] (17.0 dBm)
                        * 2447 MHz [8] (17.0 dBm)
                        * 2452 MHz [9] (17.0 dBm)
                        * 2457 MHz [10] (17.0 dBm)
                        * 2462 MHz [11] (17.0 dBm)
                        * 2467 MHz [12] (17.0 dBm)
                        * 2472 MHz [13] (17.0 dBm)
                        * 2484 MHz [14] (disabled)
        max # scan plans: 1
                * [ RRM ]: RRM
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 4
        max scan IEs length: 2304 bytes
        max # match sets: 0
        Retry long limit: 4
        Available Antennas: TX 0xf RX 0xf
        Configured Antennas: TX 0xf RX 0xf
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 1:
                Capabilities: 0x1ff
                        RX LDPC
                        HT20/HT40
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 3839 bytes
                        No DSSS/CCK HT40
                Minimum RX AMPDU time spacing: No restriction (0x00)
                HT TX/RX MCS rate indexes supported: 0-31
                Frequencies:
                        * 2412 MHz [1] (20.0 dBm)
                        * 2417 MHz [2] (20.0 dBm)
                        * 2422 MHz [3] (20.0 dBm)
                        * 2427 MHz [4] (20.0 dBm)
                        * 2432 MHz [5] (20.0 dBm)
                        * 2437 MHz [6] (20.0 dBm)
                        * 2442 MHz [7] (20.0 dBm)
                        * 2447 MHz [8] (20.0 dBm)
                        * 2452 MHz [9] (20.0 dBm)
                        * 2457 MHz [10] (20.0 dBm)
                        * 2462 MHz [11] (20.0 dBm)
                        * 2467 MHz [12] (20.0 dBm)
                        * 2472 MHz [13] (20.0 dBm)
                 * #{ IBSS } <= 1, #{ managed, AP, mesh point, P2P-client, P2P-GO } <= 16,
                   total <= 16, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 80+80 MHz, 160 MHz }
        max # scan plans: 1
        max scan plan interval: 0
                * [ RRM ]: RRM
                * [ SET_SCAN_DWELL ]: scan dwell setting
root@OpenWrt:~# hexdump -C /sys/kernel/debug/ieee80211/phy0/mt76/eeprom | head -n 20
00000000  22 76 05 00 00 00 00 00  00 00 00 00 00 00 00 00  |"v..............|
00000010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000030  00 00 00 00 44 00 00 20  00 00 00 00 10 00 20 00  |....D.. ...... .|
00000040  00 00 44 00 04 00 00 00  00 00 00 00 00 00 00 00  |..D.............|
00000050  20 00 00 b3 40 b6 c3 c3  26 00 00 00 41 c4 26 00  | ...@...&...A.&.|
00000060  00 00 41 c4 26 00 00 00  c0 c5 26 00 00 00 00 00  |..A.&.....&.....|
00000070  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000000b0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 c6 c6  |................|
000000c0  c3 c3 c2 c1 00 c3 00 c3  00 81 81 81 83 c1 c1 82  |................|
000000d0  83 83 83 82 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000000e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000000f0  84 00 2e 00 90 00 00 87  8a 00 00 00 00 00 00 00  |................|
00000100  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000120  0b 00 00 09 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000130  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000150  00 00 00 00 00 00 00 00  00 00 00 00 00 00 77 07  |..............w.|
root@OpenWrt:~#
Thank you for your help
The log shows that both the 5G and 6G channels are initialized in band 1. please provide the information below.
1. /etc/config/wireless
2. use 'logread' to get a failed log after the wifi init fails.
3. hexdump -C /sys/kernel/debug/ieee80211/phy0/mt76/eeprom | head -n 50
This is /etc/config/wireless when using 5G. 5G works:
config wifi-device 'radio0'
        option type 'mac80211'
        option path 'platform/18000000.wmac'
        option channel '1'
        option band '2g'
        option htmode 'HT20'
        option disabled '1'
config wifi-iface 'default_radio0'
        option device 'radio0'
        option network 'lan'
        option mode 'ap'
        option ssid 'OpenWrt'
        option encryption 'none'
config wifi-device 'radio1'
        option phy 'wl1'
        option channel '1'
        option band '2g'
        option htmode 'HE20'
        option disabled '1'
config wifi-iface 'default_radio1'
        option device 'radio1'
        option mode 'ap'
config wifi-device 'radio2'
        option phy 'wl1.1'
        option cell_density '0'
        option htmode 'HE80'
        option band '5g'
        option channel '149'
        option country 'GB'
config wifi-iface 'wifinet2'
        option device 'radio2'
        option mode 'ap'
        option ssid 'toffee'
        option encryption 'psk2'
        option key <removed>
        option ieee80211r '1'
        option mobility_domain 'def2'
        option ft_over_ds '0'
        option ft_psk_generate_local '1'
        option wnm_sleep_mode '1'
        option bss_transition '1'
        option ieee80211k '1'
        option time_advertisement '2'
        option time_zone 'GMT0BST,M3.5.0/1,M10.5.0'
        option proxy_arp '1'
        option nasid 'def3'
After changing to 6G channel 1 in LUCI:
        option mode 'ap'
        option encryption 'sae'
        option nasid 'def3'
        option ieee80211w '0'
Logread:
Thu Jan  4 10:06:58 2024 kern.info kernel: [2467362.151749] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 10:06:59 2024 daemon.notice wpa_supplicant[1491]: Set new config for phy wl1.1
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Set new config for phy wl1.1: /var/run/hostapd-wl1.1.conf
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Reload config for bss 'wl1.1-ap0' on phy 'wl1.1'
Thu Jan  4 10:06:59 2024 daemon.err hostapd: Management frame protection is required in 6 GHz
Thu Jan  4 10:06:59 2024 daemon.err hostapd: 1 errors found in configuration file '<inline>'
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Failed to set config for bss wl1.1-ap0
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Restart interface for phy wl1.1
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Remove interface 'wl1.1'
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: wl1.1-ap0: interface state ENABLED->DISABLED
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: wl1.1-ap0: AP-DISABLED
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: wl1.1-ap0: CTRL-EVENT-TERMINATING
Thu Jan  4 10:06:59 2024 daemon.err hostapd: rmdir[ctrl_interface=/var/run/hostapd]: Permission denied
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: nl80211: deinit ifname=wl1.1-ap0 disabled_11b_rates=0
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: nl80211: Failed to remove interface wl1.1-ap0 from bridge br-lan: Invalid argument
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=GB ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 chanlist=1 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] op_class=133 ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=7 vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-3][BF-ANTENNA-3][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=1 he_oper_centr_freq_seg0_idx=7 he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_
Thu Jan  4 10:06:59 2024 daemon.err hostapd: Failed to set up interface with data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=GB ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 chanlist=1 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] op_class=133 ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=7 vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-3][BF-ANTENNA-3][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=1 he_oper_centr_freq_seg0_idx=7 he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0
Thu Jan  4 10:06:59 2024 daemon.notice hostapd: hostapd.add_iface failed for phy wl1.1 ifname=wl1.1-ap0
Thu Jan  4 10:06:59 2024 daemon.notice netifd: Wireless device 'radio2' is now up
So I need to enable management frame protection:
/etc/config/wireless after enabling management frame protection:
        option mode 'ap'
        option nasid 'def3'
logread:
Thu Jan  4 10:09:13 2024 daemon.notice wpa_supplicant[1491]: Set new config for phy wl1.1
Thu Jan  4 10:09:13 2024 daemon.notice hostapd: Set new config for phy wl1.1: /var/run/hostapd-wl1.1.conf
Thu Jan  4 10:09:13 2024 daemon.notice hostapd: Error reloading config: { "type": "Reference error", "message": "access to undeclared variable iface_name", "stacktrace": [ { "filename": "/usr/share/hostap/hostapd.uc", "line": 282, "byte": 55, "function": "iface_reload_config", "context": "In iface_reload_config(), file /usr/share/hostap/hostapd.uc, line 282, byte 55:\n  called from function iface_set_config (/usr/share/hostap/hostapd.uc:529:59)\n  called from function [anonymous function] (/usr/share/hostap/hostapd.uc:747:32)\n  called from anonymous function (/usr/share/hostap/hostapd.uc:630:22)\n\n `        hostapd.printf(`Could not find previous interface ${iface_name}`);`\n  Near here --------------------------------------------------^\n" }, { "filename": "/usr/share/hostap/hostapd.uc", "line": 529, "byte": 59, "function": "iface_set_config" }, { "filename": "/usr/share/hostap/hostapd.uc", "line": 747, "byte": 32, "function": "[anonymous function]" }, { "filename": "/usr/share/hostap/hostapd.uc", "line": 630, "byte": 22 }
Thu Jan  4 10:09:13 2024 daemon.notice hostapd: Restart interface for phy wl1.1
Thu Jan  4 10:09:13 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=GB ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 chanlist=1 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] op_class=133 ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=7 vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-3][BF-ANTENNA-3][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=1 he_oper_centr_freq_seg0_idx=7 he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.268084] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.273939] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.280131] device wl1.1-ap0 entered promiscuous mode
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.285527] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.291384] br-lan: port 5(wl1.1-ap0) entered forwarding state
Thu Jan  4 10:09:13 2024 daemon.notice hostapd: wl1.1-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.298250] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.306571] device wl1.1-ap0 left promiscuous mode
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.311691] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.341800] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.347726] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 10:09:13 2024 kern.info kernel: [2467497.353946] device wl1.1-ap0 entered promiscuous mode
Thu Jan  4 10:09:14 2024 user.info usteer: Creating local node hostapd.wl1.1-ap0
Thu Jan  4 10:09:14 2024 kern.info kernel: [2467497.842274] IPv6: ADDRCONF(NETDEV_CHANGE): wl1.1-ap0: link becomes ready
Thu Jan  4 10:09:14 2024 kern.info kernel: [2467497.849410] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 10:09:14 2024 kern.info kernel: [2467497.855261] br-lan: port 5(wl1.1-ap0) entered forwarding state
Thu Jan  4 10:09:14 2024 daemon.notice netifd: Network device 'wl1.1-ap0' link is up
Thu Jan  4 10:09:14 2024 daemon.notice hostapd: wl1.1-ap0: interface state COUNTRY_UPDATE->ENABLED
Thu Jan  4 10:09:14 2024 daemon.notice hostapd: wl1.1-ap0: AP-ENABLED
Thu Jan  4 10:09:14 2024 user.info usteer: Found nl80211 phy on wdev hostapd.wl1.1-ap0, ssid=toffee
Thu Jan  4 10:09:14 2024 user.info usteer: Connecting to local node hostapd.wl1.1-ap0
Thu Jan  4 10:09:14 2024 daemon.notice netifd: Wireless device 'radio2' is now up
I can’t see any errors there but still can’t see the 6G access point using the WIFIanalyzer app on my android phone. I’ve tested that app at a friends house who has a 6G tp-link access point and it works.
Output of hexdump -C /sys/kernel/debug/ieee80211/phy0/mt76/eeprom | head -n 50:
00000160  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00004da0  00 00 00 00 00 00 00 00                           |........|
00004da8
I changed the channel to 21 and can see the access point on my phone!!!
Output of logread:
Thu Jan  4 11:24:54 2024 kern.info kernel: [2472037.896967] device wl1.1-ap0 left promiscuous mode
Thu Jan  4 11:24:54 2024 kern.info kernel: [2472037.902102] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 11:24:54 2024 daemon.notice wpa_supplicant[1491]: Set new config for phy wl1.1
Thu Jan  4 11:24:54 2024 daemon.notice hostapd: Set new config for phy wl1.1: /var/run/hostapd-wl1.1.conf
Thu Jan  4 11:24:54 2024 daemon.notice hostapd: Reload config for bss 'wl1.1-ap0' on phy 'wl1.1'
Thu Jan  4 11:24:55 2024 user.info usteer: Creating local node hostapd.wl1.1-ap0
Thu Jan  4 11:24:55 2024 daemon.notice hostapd: Reloaded settings for phy wl1.1
Thu Jan  4 11:24:55 2024 user.info usteer: Found nl80211 phy on wdev hostapd.wl1.1-ap0, ssid=toffee2
Thu Jan  4 11:24:55 2024 user.info usteer: Connecting to local node hostapd.wl1.1-ap0
Thu Jan  4 11:24:55 2024 daemon.notice netifd: Wireless device 'radio2' is now up
Thu Jan  4 11:24:55 2024 daemon.notice netifd: Network device 'wl1.1-ap0' link is up
Thu Jan  4 11:24:56 2024 kern.info kernel: [2472039.530203] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 11:24:56 2024 kern.info kernel: [2472039.536048] br-lan: port 5(wl1.1-ap0) entered disabled state
Thu Jan  4 11:24:56 2024 kern.info kernel: [2472039.542170] device wl1.1-ap0 entered promiscuous mode
Thu Jan  4 11:24:56 2024 kern.info kernel: [2472039.547559] br-lan: port 5(wl1.1-ap0) entered blocking state
Thu Jan  4 11:24:56 2024 kern.info kernel: [2472039.553428] br-lan: port 5(wl1.1-ap0) entered forwarding state
Thu Jan  4 11:25:42 2024 daemon.info hostapd: wl1.1-ap0: STA 76:10:62:35:dc:69 IEEE 802.11: associated (aid 1)
Thu Jan  4 11:25:42 2024 daemon.notice hostapd: wl1.1-ap0: AP-STA-CONNECTED 76:10:62:35:dc:69 auth_alg=sae
Thu Jan  4 11:25:42 2024 daemon.info hostapd: wl1.1-ap0: STA 76:10:62:35:dc:69 RADIUS: starting accounting session 58B4F5631ACEF8F1
Thu Jan  4 11:25:42 2024 daemon.info hostapd: wl1.1-ap0: STA 76:10:62:35:dc:69 WPA: pairwise key handshake completed (RSN)
Thu Jan  4 11:25:42 2024 daemon.notice hostapd: wl1.1-ap0: EAPOL-4WAY-HS-COMPLETED 76:10:62:35:dc:69
It seems that turning on management frame protection and changing to channel 21 solved the issue.
Many many many thanks for your help!
