mt7622 wifi is working on lede? Have not seen the driver till now…
Yes, the mt7622 wifi is working on the emmc_singleimage.img, it’s based on LEDE.
ifconfig
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:58
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:335 errors:170 dropped:0 overruns:0 frame:0
TX packets:132 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:20078 (19.6 KiB) TX bytes:12359 (12.0 KiB)
Interrupt:246
root@LEDE:/# iwconfig
gre0 no wir[ 264.147116] mtk_do_priv_ioctl ioctl 35585 is not supportedeless extensions
wds0 R[ 264.153744] mtk_do_priv_ioctl ioctl 35585 is not supportedTWIFI SoftAP ESSID:"MTK_AP1"
Mode:Master Channel=6 Access Point: 00:0C:43:26:60:58
Bit Rate=1 Mb/s
sit0 no wireless extensions.
lo no wireless extensions.
wds1 RTWIFI SoftAP ESSID:""
Mode:Master Channel=6 Access Point: Not-Associated
Bit Rate:1 Mb/s
apcli0 RTWIFI SoftAP ESSID:""
Mode:Managed Channel=6 Access Point: Not-Associated
Bit Rate:7 Mb/s
eth1 no wireless extensions.
wds3 RTWIFI SoftAP ESSID:""
Bit Rate:1 Mb/s
ra0 RTWIFI SoftAP ESSID:"MTK_AP1"
Bit Rate=288 Mb/s
br-lan no wireless extensions.
gretap0 no wireless extensions.
eth0 no wireless extensions.
wds2 RTWIFI SoftAP ESSID:""
Bit Rate:1 Mb/s
root@LEDE:/# opkg list | grep mt
kmod-ata-ahci-mtk - 4.4.177-1
kmod-mt_wifi - 4.4.177+TEST-1
kmod-sdhci-mtk - 4.4.177-1
luci-app-mtk - git-19.192.23199-2be7d1b-1
memtester - 4.3.0-1
mtd - 21
mtk-base-files - 1-r0-aec93540
mtk_factory_rw - 1-r0-aec93540
mtkhnat_util - 1-r0-aec93540
mtkiappd - 1
root@LEDE:/# lsmod | grep mt
ahci_mtk 3008 0
libahci 20891 2 ahci_mtk,libahci_platform
libahci_platform 6530 1 ahci_mtk
libata 138296 3 ahci_mtk,libahci_platform,libahci
mt_whnat 60089 0
mt_wifi 4014425 2 mt_whnat
mtkhnat 54038 2 mt_whnat,mt_wifi
usbcore 154280 9 usb_storage,xhci_mtk,xhci_plat_hcd,xhci_pci,xhci_hcd,ohci_platform,ohci_hcd,ehci_platform,ehci_hcd
xhci_hcd 111422 3 xhci_mtk,xhci_plat_hcd,xhci_pci
xhci_mtk 7872 0
How to mount the 2048M(usrdata) mtd partition? I try to use mount /dev/mtdblock8 /usrdata, but failed.
NTFS signature is missing.
Failed to mount '/dev/mtdblock8': Invalid argument
The device '/dev/mtdblock8' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
mount: mounting /dev/mtdblock8 on /usrdata failed: Invalid argument
[ 17.402717] 6 cmdlinepart partitions found on MTD device eMMC
[ 17.408638] Creating 6 MTD partitions on "eMMC":
[ 17.413413] 0x000000000000-0x0000000c0000 : "mbr"
[ 17.418702] 0x0000000c0000-0x000000140000 : "uboot"
[ 17.424108] 0x000000140000-0x0000001c0000 : "Config"
[ 17.429573] 0x0000001c0000-0x000000200000 : "Factory"
[ 17.435124] 0x000000200000-0x000004200000 : "Kernel"
[ 17.441753] 2 fit-fw partitions found on MTD device Kernel
[ 17.447409] 0x000000200000-0x000000520000 : "kernel"
[ 17.452930] 0x000000519db0-0x000004200000 : "rootfs"
[ 17.458379] mtd: device 6 (rootfs) set to be root filesystem
[ 17.464284] 1 squashfs-split partitions found on MTD device rootfs
[ 17.470667] 0x0000025c0000-0x000004200000 : "rootfs_data"
[ 17.476603] 0x000004200000-0x000084200000 : "usrdata"
[ 17.482153] block2mtd: mtd0: [eMMC] erase_size = 64KiB [65536]
[ 17.488356] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 00:00:15 UTC (946684815)
[ 17.500980] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[ 17.510015] devtmpfs: mounted
[ 17.513218] Freeing unused kernel memory: 320K
~# cat /proc/partitions
major minor #blocks name
179 0 7634944 mmcblk0
179 1 256 mmcblk0p1
179 2 512 mmcblk0p2
179 3 512 mmcblk0p3
179 4 256 mmcblk0p4
179 5 65536 mmcblk0p5
31 0 768 mtdblock0
31 1 512 mtdblock1
31 2 512 mtdblock2
31 3 256 mtdblock3
31 4 65536 mtdblock4
31 5 3200 mtdblock5
31 6 62360 mtdblock6
31 7 28928 mtdblock7
31 8 2097152 mtdblock8
The rootfs_data mtd partition is too small, only 28MB if use 64MB boot partition. The eMMC is 8G for R64, so i want to use most of eMMC space.
I integrated the driver not using mtd (load firmware from /lib/firmware/mediatek). You can try this too if you disable the eeprom option in dts
You have to make NTFS filesystem on the device before mounting
First you have to extend fifth partition (named as “boot”) of the image file. Use gdisk tool. Next modify bootargs of Uboot:
… block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),SIZE YOU NEED(Kernel),SIZE YOU NEED(usrdata)’
I think you are right, need make filesystem first for that mtd partition, I need ext4, i will build the ext4 filesystem module, and try it later.
… block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory), SIZE YOU NEED (Kernel), SIZE YOU NEED (usrdata)’
It’s working, i have try change the kernel partition size ot 512M and 2G, both working, but seems 5G size failed.
BTW, What’s the 65536 meaning in “block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts”
There is a mt7622 wifi driver patch from here: [BPI-R64] mt7622 mac80211 WiFi driver. It’s working with the latest openwrt source code, i have test it on R64 board.
And I try to build that mt7622 patch into openmptcprouter v0.52.3 branches, but failed, that patch only working with openwrt latest backports source code.
So I checkout the openmptcprouter master latest source code, the openwrt in it can build that mt7622 wifi driver patch.
But after i build and load the squashfs-sysupgrade.bin into R64 with the same steps, It have problem to start.
[ 17.194486] 6 cmdlinepart partitions found on MTD device eMMC
[ 17.200420] Creating 6 MTD partitions on "eMMC":
[ 17.205180] 0x000000000000-0x0000000c0000 : "mbr"
[ 17.210492] 0x0000000c0000-0x000000140000 : "uboot"
[ 17.215890] 0x000000140000-0x0000001c0000 : "Config"
[ 17.221370] 0x0000001c0000-0x000000200000 : "Factory"
[ 17.226908] 0x000000200000-0x000004200000 : "Kernel"
[ 17.233526] 2 fit-fw partitions found on MTD device Kernel
[ 17.239195] 0x000000200000-0x0000004b0000 : "kernel"
[ 17.244676] 0x0000004a6574-0x000004200000 : "rootfs"
[ 17.250168] mtd: device 6 (rootfs) set to be root filesystem
[ 17.256008] 1 squashfs-split partitions found on MTD device rootfs
[ 17.262442] 0x000003030000-0x000004200000 : "rootfs_data"
[ 17.268352] 0x000004200000-0x000084200000 : "usrdata"
[ 17.273948] block2mtd: mtd0: [eMMC] erase_size = 64KiB [65536]
[ 17.280014] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 00:13:15 UTC (946685595)
[ 17.291396] squashfs: SQUASHFS error: unable to read id index table
[ 17.298001] List of all partitions:
[ 17.301659] b300 7634944 mmcblk0
[ 17.301662] driver: mmcblk
[ 17.308674] b301 256 mmcblk0p1 f6ff0fdd-1e96-4a94-ba9b-89e55b8ea4ed
[ 17.308676]
[ 17.317917] b302 512 mmcblk0p2 e34c411c-1fb5-47f3-a295-4aa8686eff6e
[ 17.317918]
[ 17.327166] b303 512 mmcblk0p3 8660b620-97ca-4c76-b55b-bd47b11a37d9
[ 17.327168]
[ 17.336415] b304 256 mmcblk0p4 c246f1d0-56ee-4fd8-859a-c92f8e636e79
[ 17.336416]
[ 17.345662] b305 65536 mmcblk0p5 2126e09c-e358-4dfe-9579-d2597a729e75
[ 17.345664]
[ 17.354916] 1f00 768 mtdblock0
[ 17.354918] (driver?)
[ 17.361655] 1f01 512 mtdblock1
[ 17.361656] (driver?)
[ 17.368389] 1f02 512 mtdblock2
[ 17.368390] (driver?)
[ 17.375128] 1f03 256 mtdblock3
[ 17.375130] (driver?)
[ 17.381867] 1f04 65536 mtdblock4
[ 17.381869] (driver?)
[ 17.388607] 1f05 2752 mtdblock5
[ 17.388609] (driver?)
[ 17.395340] 1f06 62822 mtdblock6
[ 17.395342] (driver?)
[ 17.402080] 1f07 18240 mtdblock7
[ 17.402081] (driver?)
[ 17.408820] 1f08 2097152 mtdblock8
[ 17.408821] (driver?)
[ 17.415551] No filesystem could mount root, tried:
[ 17.415552] squashfs
[ 17.420582]
[ 17.424448] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,6)
[ 17.433058] SMP: stopping secondary CPUs
[ 17.437097] Kernel Offset: disabled
[ 17.440689] CPU features: 0x0,20002000
[ 17.444547] Memory Limit: none
[ 17.447691] Rebooting in 1 seconds..
@Ivan_Revyakin, Have you try to build the openmptcprouter master latest source?
Not yet…
Guess it corresponds to “Kernel” part of the MTD. So try to do like this:
… block2mtd.block2mtd=/dev/mmcblk0,[SIZE OF “Kernel” part IN a kB],eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory), [SIZE OF “Kernel” part](Kernel), [SIZE YOU NEED] (usrdata)’
I can build openmptcprouter-v0.52.3, and flash into R64 board success. But build and flash openmptcprouter-v0.53.2 failed. The boot log is:
mmc0 is current device
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 1 ... 1 blocks read: OK
[do_read_image_blks] This is a FIT image,img_size = 0x2e724c
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 5946 ... 5946 blocks read: OK
bootm flag=0, states=70f
## Loading kernel from FIT Image at 4007ff28 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: ARM64 OpenWrt Linux-4.19.84
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x40080010
Data Size: 3018966 Bytes = 2.9 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x41080000
Entry Point: 0x41080000
Hash algo: crc32
Hash value: 3f30a63f
Hash algo: sha1
Hash value: b0f0be6f73042bb5d7c5532895bd5721eb78871f
## Loading fdt from FIT Image at 4007ff28 ...
Trying 'fdt@1' fdt subimage
Description: ARM64 OpenWrt BPI-R64 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x40361220
Data Size: 23070 Bytes = 22.5 KiB
Hash algo: crc32
Hash value: 6f50902d
Hash algo: sha1
Hash value: a45cf7ff90b8c1baa5e7680293643f6d156ddda2
Booting using the fdt blob at 0x40361220
Uncompressing Kernel Image ... OK
Loading Device Tree to 6bff7000, end 6bfffa1d ... OK
Starting kernel ...
[ATF][ 14.152996]save kernel info
[ATF][ 14.155933]Kernel_EL2
[ATF][ 14.158603]Kernel is 64Bit
[ATF][ 14.161691]pc=0x41080000, r0=0x6bff7000, r1=0x0
INFO: BL3-1: Preparing for EL3 exit to normal world, Kernel
INFO: BL3-1: Next image address = 0x41080000
INFO: BL3-1: Next image spsr = 0x3c9
[ATF][ 14.179389]el3_exit
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.84 (ubuntu@ip-172-31-2-8) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r0+11546-a74095c68c)) #0 SMP Tue Nov 19 13:59:03 2019
[ 0.000000] Machine model: Bananapi BPI-R64
[ 0.000000] On node 0 totalpages: 262096
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 262096 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x3f0 with crng_init=0
[ 0.000000] percpu: Embedded 20 pages/cpu s42712 r8192 d31016 u81920
[ 0.000000] pcpu-alloc: s42712 r8192 d31016 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258000
[ 0.000000] Kernel command line: console=ttyS0,115200n1 rootfstype=squashfs earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),512M(Kernel),6144M(usrdata)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1020884K/1048384K available (6206K kernel code, 424K rwdata, 1724K rodata, 320K init, 305K bss, 27500K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.000179] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.000186] pid_max: default: 32768 minimum: 301
[ 0.000260] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000271] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001090] ASID allocator initialised with 65536 entries
[ 0.001144] rcu: Hierarchical SRCU implementation.
[ 0.001494] smp: Bringing up secondary CPUs ...
[ 0.001798] Detected VIPT I-cache on CPU1
[ 0.001836] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.001894] smp: Brought up 1 node, 2 CPUs
[ 0.001901] SMP: Total of 2 processors activated.
[ 0.001906] CPU features: detected: 32-bit EL0 Support
[ 0.001972] CPU: All CPU(s) started at EL2
[ 0.001981] alternatives: patching kernel code
[ 0.002340] devtmpfs: initialized
[ 0.005213] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005226] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.005307] pinctrl core: initialized pinctrl subsystem
[ 0.005486] reg-dummy reg-dummy: no of_node; not parsing pinctrl DT
[ 0.005858] NET: Registered protocol family 16
[ 0.006348] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.006477] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.015118] mt7622-pinctrl 10211000.pinctrl: try to register 103 pins ...
[ 0.016083] mt7622-pinctrl 10211000.pinctrl: no hogs found
[ 0.017659] gpiochip_find_base: found new base at 409
[ 0.017678] gpio gpiochip0: (pinctrl_moore): created GPIO range 0->102 ==> 10211000.pinctrl PIN 0->102
[ 0.017698] mt7622-pinctrl 10211000.pinctrl: request pin 90 (AUXIN3) for pinctrl_moore:499
[ 0.017710] gpio gpiochip0: Persistence not supported for GPIO 90
[ 0.017719] GPIO line 499 (asm_sel) hogged as output/high
[ 0.017851] gpio gpiochip0: (pinctrl_moore): added GPIO chardev (254:0)
[ 0.017857] gpiochip_setup_dev: registered GPIOs 409 to 511 on device: gpiochip0 (pinctrl_moore)
[ 0.026918] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-1p8v[0]'
[ 0.027096] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-3p3v[0]'
[ 0.027235] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-5v[0]'
[ 0.027524] SCSI subsystem initialized
[ 0.027648] libata version 3.00 loaded.
[ 0.027790] usbcore: registered new interface driver usbfs
[ 0.027818] usbcore: registered new interface driver hub
[ 0.027846] usbcore: registered new device driver usb
[ 0.028567] Bluetooth: Core ver 2.22
[ 0.028601] NET: Registered protocol family 31
[ 0.028605] Bluetooth: HCI device and connection manager initialized
[ 0.028612] Bluetooth: HCI socket layer initialized
[ 0.028620] Bluetooth: L2CAP socket layer initialized
[ 0.028648] Bluetooth: SCO socket layer initialized
[ 0.029016] clocksource: Switched to clocksource arch_sys_counter
[ 0.029916] NET: Registered protocol family 2
[ 0.030408] default registered
[ 0.030415] default registered
[ 0.030418] MPTCP: Stable release v0.95
[ 0.030428] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[ 0.030447] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.030497] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.030597] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.030687] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.030709] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.030802] NET: Registered protocol family 1
[ 0.030820] PCI: CLS 0 bytes, default 64
[ 0.031349] alarmtimer alarmtimer: no of_node; not parsing pinctrl DT
[ 0.031553] No memory allocated for crashlog
[ 0.031632] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.035261] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.035275] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.038039] io scheduler noop registered (default)
[ 0.038419] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[ 0.038704] pinctrl core: add 1 pinctrl maps
[ 0.038734] mt7622-pinctrl 10211000.pinctrl: found group selector 70 for pwm_ch7_2
[ 0.038745] mt7622-pinctrl 10211000.pinctrl: request pin 101 (PWM7) for 11006000.pwm
[ 0.038752] mt7622-pinctrl 10211000.pinctrl: enable function pwm group pwm_ch7_2
[ 0.039066] pinctrl core: add 3 pinctrl maps
[ 0.039080] pinctrl core: add 3 pinctrl maps
[ 0.039096] mt7622-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[ 0.039106] mt7622-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[ 0.039116] mt7622-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[ 0.039126] mt7622-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[ 0.039136] mt7622-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[ 0.039146] mt7622-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[ 0.039154] mt7622-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[ 0.039160] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[ 0.039168] mt7622-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[ 0.039173] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[ 0.039180] mt7622-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[ 0.039186] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[ 0.039192] mt7622-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[ 0.039198] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[ 0.039205] mt7622-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[ 0.039210] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[ 0.039217] mt7622-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[ 0.039222] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[ 0.041553] pinctrl core: add 1 pinctrl maps
[ 0.041580] mt7622-pinctrl 10211000.pinctrl: found group selector 47 for pmic_bus
[ 0.041590] mt7622-pinctrl 10211000.pinctrl: request pin 71 (PMIC_SCL) for 10001000.pwrap
[ 0.041597] mt7622-pinctrl 10211000.pinctrl: request pin 72 (PMIC_SDA) for 10001000.pwrap
[ 0.041603] mt7622-pinctrl 10211000.pinctrl: enable function pmic group pmic_bus
[ 0.041718] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[ 0.055735] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.057993] serial8250 serial8250: no of_node; not parsing pinctrl DT
[ 0.058121] pinctrl core: add 1 pinctrl maps
[ 0.058154] mt7622-pinctrl 10211000.pinctrl: found group selector 89 for uart0_0_tx_rx
[ 0.058164] mt7622-pinctrl 10211000.pinctrl: request pin 6 (TXD0) for 11002000.serial
[ 0.058170] mt7622-pinctrl 10211000.pinctrl: request pin 7 (RXD0) for 11002000.serial
[ 0.058177] mt7622-pinctrl 10211000.pinctrl: enable function uart group uart0_0_tx_rx
[ 0.058344] console [ttyS0] disabled
[ 0.078732] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 1562500) is a ST16650V2
[ 1.664966] console [ttyS0] enabled
[ 1.668880] pinctrl core: add 1 pinctrl maps
[ 1.673320] mt7622-pinctrl 10211000.pinctrl: found group selector 96 for uart2_1_tx_rx
[ 1.681495] mt7622-pinctrl 10211000.pinctrl: request pin 51 (MDI_TP_P0) for 11004000.serial
[ 1.690113] mt7622-pinctrl 10211000.pinctrl: request pin 52 (MDI_TN_P0) for 11004000.serial
[ 1.698723] mt7622-pinctrl 10211000.pinctrl: enable function uart group uart2_1_tx_rx
[ 1.727279] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 117, base_baud = 1562500) is a ST16650V2
[ 1.737350] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 123, base_baud = 17499995) is a MediaTek BTIF
[ 1.747409] serial serial0: tty port ttyS2 registered
[ 1.752939] mtk_rng 1020f000.rng: registered RNG driver
[ 1.753069] random: fast init done
[ 1.758495] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.761983] random: crng init done
[ 1.771094] loop: module loaded
[ 1.775586] pinctrl core: add 1 pinctrl maps
[ 1.780037] mt7622-pinctrl 10211000.pinctrl: found group selector 75 for spic0_0
[ 1.787667] mt7622-pinctrl 10211000.pinctrl: request pin 63 (MDI_TP_P3) for 1100a000.spi
[ 1.796017] mt7622-pinctrl 10211000.pinctrl: request pin 64 (MDI_TN_P3) for 1100a000.spi
[ 1.804364] mt7622-pinctrl 10211000.pinctrl: request pin 65 (MDI_RP_P3) for 1100a000.spi
[ 1.812711] mt7622-pinctrl 10211000.pinctrl: request pin 66 (MDI_RN_P3) for 1100a000.spi
[ 1.821058] mt7622-pinctrl 10211000.pinctrl: enable function spi group spic0_0
[ 1.828836] pinctrl core: add 1 pinctrl maps
[ 1.833269] mt7622-pinctrl 10211000.pinctrl: found group selector 77 for spic1_0
[ 1.840930] mt7622-pinctrl 10211000.pinctrl: request pin 67 (MDI_RP_P4) for 11016000.spi
[ 1.849279] mt7622-pinctrl 10211000.pinctrl: request pin 68 (MDI_RN_P4) for 11016000.spi
[ 1.857620] mt7622-pinctrl 10211000.pinctrl: request pin 69 (MDI_TP_P4) for 11016000.spi
[ 1.865967] mt7622-pinctrl 10211000.pinctrl: request pin 70 (MDI_TN_P4) for 11016000.spi
[ 1.874313] mt7622-pinctrl 10211000.pinctrl: enable function spi group spic1_0
[ 1.882259] mdio_bus fixed-0: GPIO lookup for consumer reset
[ 1.888092] mdio_bus fixed-0: using lookup tables for GPIO lookup
[ 1.894388] mdio_bus fixed-0: No GPIO consumer reset found
[ 1.900065] libphy: Fixed MDIO Bus: probed
[ 1.904736] sean debug physpeed = 2500
[ 1.931265] mdio_bus mdio-bus: GPIO lookup for consumer reset
[ 1.937189] mdio_bus mdio-bus: using device tree for GPIO lookup
[ 1.943400] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus[0]'
[ 1.953992] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ethernet@1b100000/mdio-bus[0]'
[ 1.964491] mdio_bus mdio-bus: using lookup tables for GPIO lookup
[ 1.970867] mdio_bus mdio-bus: No GPIO consumer reset found
[ 1.976609] libphy: mdio: probed
[ 1.979953] mtk_soc_eth 1b100000.ethernet: generated random MAC address 4a:0a:e8:f0:6f:8e
[ 1.988391] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@0/fixed-link[0]'
[ 1.999701] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@0[0]'
[ 2.010150] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gdm1_to_gmac1_esw updated = 1
[ 2.019573] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[ 2.028630] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[ 2.037338] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 1
[ 2.047566] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[ 2.056763] mtk_soc_eth 1b100000.ethernet: connected mac 0 to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[ 2.067738] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffff8009400000, irq 131
[ 2.077177] mtk_soc_eth 1b100000.ethernet: generated random MAC address 3e:38:30:f5:80:25
[ 2.085621] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@1/fixed-link[0]'
[ 2.096929] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@1[0]'
[ 2.107314] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gdm1_to_gmac1_esw updated = 0
[ 2.116751] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[ 2.125815] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[ 2.134523] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 0
[ 2.144749] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[ 2.153937] mtk_soc_eth 1b100000.ethernet: connected mac 1 to PHY at fixed-0:01 [uid=00000000, driver=Generic PHY]
[ 2.164857] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffff8009400000, irq 131
[ 2.174283] netif_napi_add() called with weight 256 on device
[ 2.180598] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[ 2.187352] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[ 2.194284] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.2
[ 2.200799] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.3
[ 2.207577] rtc_mt7622 10212800.rtc: rtc core: registered 10212800.rtc as rtc0
[ 2.215272] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 2.224593] pinctrl core: add 1 pinctrl maps
[ 2.229027] mt7622-pinctrl 10211000.pinctrl: found group selector 109 for watchdog
[ 2.236835] mt7622-pinctrl 10211000.pinctrl: request pin 78 (WATCHDOG) for 10212000.watchdog
[ 2.245541] mt7622-pinctrl 10211000.pinctrl: enable function watchdog group watchdog
[ 2.253549] MTK_WDT_NONRST_REG(20000000)
[ 2.257590] RGU get IRQ ID failed
[ 2.261146] Bluetooth: HCI UART driver ver 2.3
[ 2.265724] Bluetooth: HCI UART protocol H4 registered
[ 2.271073] Bluetooth: HCI UART protocol BCSP registered
[ 2.276545] Bluetooth: HCI UART protocol ATH3K registered
[ 2.282170] Bluetooth: HCI UART protocol Broadcom registered
[ 2.288017] Bluetooth: HCI UART protocol QCA registered
[ 2.293548] mtk-cpufreq mtk-cpufreq: no of_node; not parsing pinctrl DT
[ 2.294053] bluetooth hci0: Direct firmware load for mediatek/mt7622pr2h.bin failed with error -2
[ 2.300477] cpu cpu0: Linked as a consumer to regulator.4
[ 2.309538] bluetooth hci0: Falling back to syfs fallback for: mediatek/mt7622pr2h.bin
[ 2.315152] cpu cpu0: Linked as a consumer to regulator.7
[ 2.329567] generic pinconfig core: found bias-pull-up with value 1
[ 2.336030] generic pinconfig core: found input-enable with value 1
[ 2.342506] generic pinconfig core: found bias-pull-down with value 1
[ 2.349154] pinctrl core: add 11 pinctrl maps
[ 2.353657] generic pinconfig core: found bias-pull-up with value 1
[ 2.360121] generic pinconfig core: found drive-strength with value 4
[ 2.366758] generic pinconfig core: found input-enable with value 1
[ 2.373231] generic pinconfig core: found bias-pull-down with value 1
[ 2.379877] generic pinconfig core: found drive-strength with value 4
[ 2.386518] pinctrl core: add 11 pinctrl maps
[ 2.391023] mt7622-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[ 2.398331] mt7622-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[ 2.405644] mt7622-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[ 2.413544] mt7622-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[ 2.421442] mt7622-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[ 2.429339] mt7622-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[ 2.437232] mt7622-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[ 2.445040] mt7622-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[ 2.452937] mt7622-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[ 2.460836] mt7622-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[ 2.468728] mt7622-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[ 2.476625] mt7622-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[ 2.484523] mt7622-pinctrl 10211000.pinctrl: enable function emmc group emmc
[ 2.491906] mtk-msdc 11230000.mmc: GPIO lookup for consumer wp
[ 2.497918] mtk-msdc 11230000.mmc: using device tree for GPIO lookup
[ 2.504480] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11230000[0]'
[ 2.513549] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11230000[0]'
[ 2.522524] mtk-msdc 11230000.mmc: using lookup tables for GPIO lookup
[ 2.529257] mtk-msdc 11230000.mmc: No GPIO consumer wp found
[ 2.535167] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.2
[ 2.541937] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.1
[ 2.548692] mtk-msdc 11230000.mmc: obtain a copy of previously claimed pinctrl
[ 2.556395] mt7622-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[ 2.564296] mt7622-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[ 2.572194] mt7622-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[ 2.580092] mt7622-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[ 2.587985] mt7622-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[ 2.595792] mt7622-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[ 2.603690] mt7622-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[ 2.611587] mt7622-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[ 2.619484] mt7622-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[ 2.627377] mt7622-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[ 2.635275] mt7622-pinctrl 10211000.pinctrl: enable function emmc group emmc
[ 2.667798] generic pinconfig core: found bias-pull-up with value 1
[ 2.674268] generic pinconfig core: found drive-strength with value 8
[ 2.680917] generic pinconfig core: found input-enable with value 1
[ 2.687385] generic pinconfig core: found bias-pull-down with value 1
[ 2.694028] generic pinconfig core: found drive-strength with value 12
[ 2.700767] generic pinconfig core: found bias-pull-up with value 1
[ 2.707230] pinctrl core: add 8 pinctrl maps
[ 2.711646] generic pinconfig core: found bias-pull-up with value 1
[ 2.718105] generic pinconfig core: found input-enable with value 1
[ 2.724578] generic pinconfig core: found bias-pull-down with value 1
[ 2.731225] pinctrl core: add 7 pinctrl maps
[ 2.735646] mt7622-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[ 2.743036] mt7622-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[ 2.750411] mt7622-pinctrl 10211000.pinctrl: request pin 16 (I2S2_IN) for 11240000.mmc
[ 2.758572] mt7622-pinctrl 10211000.pinctrl: request pin 17 (I2S3_IN) for 11240000.mmc
[ 2.766739] mt7622-pinctrl 10211000.pinctrl: request pin 18 (I2S4_IN) for 11240000.mmc
[ 2.774905] mt7622-pinctrl 10211000.pinctrl: request pin 19 (I2S2_OUT) for 11240000.mmc
[ 2.783160] mt7622-pinctrl 10211000.pinctrl: request pin 20 (I2S3_OUT) for 11240000.mmc
[ 2.791418] mt7622-pinctrl 10211000.pinctrl: request pin 21 (I2S4_OUT) for 11240000.mmc
[ 2.799675] mt7622-pinctrl 10211000.pinctrl: enable function sd group sd_0
[ 2.806883] mtk-msdc 11240000.mmc: GPIO lookup for consumer cd
[ 2.812899] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[ 2.819465] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@11240000[0]' - status (0)
[ 2.829251] mt7622-pinctrl 10211000.pinctrl: request pin 81 (TXD3) for pinctrl_moore:490
[ 2.837596] gpio gpiochip0: Persistence not supported for GPIO 81
[ 2.843886] mtk-msdc 11240000.mmc: Got CD GPIO
[ 2.848464] mtk-msdc 11240000.mmc: GPIO lookup for consumer wp
[ 2.854479] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[ 2.861037] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11240000[0]'
[ 2.870104] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11240000[0]'
[ 2.879078] mtk-msdc 11240000.mmc: using lookup tables for GPIO lookup
[ 2.885804] mtk-msdc 11240000.mmc: No GPIO consumer wp found
[ 2.891715] mtk-msdc 11240000.mmc: Linked as a consumer to regulator.2
[ 2.898488] mtk-msdc 11240000.mmc: obtain a copy of previously claimed pinctrl
[ 2.931010] NET: Registered protocol family 10
[ 2.936288] Segment Routing with IPv6
[ 2.940128] fullmesh registered
[ 2.943360] ndiffports registered
[ 2.946774] binder registered
[ 2.949858] netlink registered
[ 2.953002] roundrobin registered
[ 2.956411] redundant registered
[ 2.959739] blest registered
[ 2.962701] ecf registered
[ 2.965486] NET: Registered protocol family 17
[ 2.970092] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.983514] 8021q: 802.1Q VLAN Support v1.8
[ 2.995767] pinctrl core: add 3 pinctrl maps
[ 3.000223] pinctrl core: add 3 pinctrl maps
[ 3.004673] mt7622-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[ 3.013038] mt7622-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[ 3.021219] mt7622-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[ 3.029489] mt7622-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[ 3.037842] mt7622-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[ 3.046022] mt7622-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[ 3.054291] mt7622-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[ 3.062652] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[ 3.070922] mt7622-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[ 3.079098] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[ 3.087179] mt7622-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[ 3.095368] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[ 3.103558] mt7622-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[ 3.111927] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[ 3.120207] mt7622-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[ 3.128479] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[ 3.136580] mt7622-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[ 3.144858] mt7622-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[ 3.156263] mtk-msdc 11230000.mmc: phase: [map:7fffffff] [maxlen:31] [final:10]
[ 3.165272] mtk-msdc 11230000.mmc: phase: [map:fffffff] [maxlen:28] [final:9]
[ 3.173406] mmc0: new HS200 MMC card at address 0001
[ 3.178624] mmcblk mmc0:0001: no of_node; not parsing pinctrl DT
[ 3.185863] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 3.191411] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[ 3.198377] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[ 3.204597] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[ 3.214609] Alternate GPT is invalid, using primary GPT.
[ 3.220110] mmcblk0: p1 p2 p3 p4 p5
[ 3.253288] mtk-pcie 1a140000.pcie: Port0 link down
[ 3.358366] mtk-pcie 1a140000.pcie: Port1 link down
[ 3.363544] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[ 3.369926] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 3.376924] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[ 3.384018] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.389676] pci_bus 0000:00: scanning bus
[ 3.394955] pci_bus 0000:00: fixups for bus
[ 3.399270] pci_bus 0000:00: bus scan returning with max=00
[ 3.405168] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[ 3.413617] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[ 3.421311] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/gsw@0[0]' - status (0)
[ 3.430744] mt7622-pinctrl 10211000.pinctrl: request pin 54 (MDI_RN_P0) for pinctrl_moore:463
[ 4.009019] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[ 4.014609] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[ 6.691065] mt753x gsw@0: >>>>>>>>>>>>>>>>>>>>>>>>>>>>> START CALIBRATION:
[ 6.700141] mt753x gsw@0: -------- gephy-calbration (port:0) --------
[ 6.723274] CALDLY = 40
[ 7.067696] GE Rext AnaCal Saturation!
[ 7.071922] GE Rxet cal something wrong2
[ 7.361353] GE R50 AnaCal Saturation!
[ 7.365482] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 7.647124] GE R50 AnaCal Saturation!
[ 7.651260] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 7.932947] GE R50 AnaCal Saturation!
[ 7.937076] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 8.218888] GE R50 AnaCal Saturation!
[ 8.223024] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 8.233248] GE 1e_174(0x8080), 1e_175(0x8080)
[ 8.304586] GE Tx offset AnaCal Done! (pair-0)(3)(0x22) 0x1e_172=0x2220
[ 8.352166] GE Tx offset AnaCal Done! (pair-1)(3)(0x22) 0x1e_172=0x2222
[ 8.424150] GE Tx offset AnaCal Done! (pair-2)(6)(0x25) 0x1e_173=0x2520
[ 8.455445] GE Tx offset AnaCal Done! (pair-3)(1)(0x1) 0x1e_173=0x2501
[ 8.593959] GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x4812)
[ 8.657674] GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1515)
[ 8.727558] GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x131b)
[ 8.807549] GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x131b)
[ 8.902930] PORT 0 RX_DC_OFFSET
[ 8.923202] before pairA output = f
[ 8.929932] after pairA output = 1
[ 8.936491] before pairB output = f
[ 8.943228] after pairB output = 1
[ 8.949795] before pairC output = 1d
[ 8.956611] after pairC output = fe
[ 8.963266] before pairD output = 1e
[ 8.970089] after pairD output = 1
[ 8.974052] mt753x gsw@0: -------- gephy-calbration (port:1) --------
[ 8.997192] CALDLY = 40
[ 9.277227] GE R50 AnaCal Saturation!
[ 9.281365] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 9.563027] GE R50 AnaCal Saturation!
[ 9.567157] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 9.848716] GE R50 AnaCal Saturation!
[ 9.852853] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 10.134470] GE R50 AnaCal Saturation!
[ 10.138599] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 10.148824] GE 1e_174(0x8080), 1e_175(0x8080)
[ 10.244546] GE Tx offset AnaCal Done! (pair-0)(6)(0x25) 0x1e_172=0x2520
[ 10.283985] GE Tx offset AnaCal Done! (pair-1)(2)(0x21) 0x1e_172=0x2521
[ 10.339695] GE Tx offset AnaCal Done! (pair-2)(4)(0x23) 0x1e_173=0x2320
[ 10.387242] GE Tx offset AnaCal Done! (pair-3)(3)(0x3) 0x1e_173=0x2303
[ 10.494981] GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x5816)
[ 10.548561] GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1919)
[ 10.638661] GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1c24)
[ 10.738909] GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1d25)
[ 10.834272] PORT 1 RX_DC_OFFSET
[ 10.854549] before pairA output = f
[ 10.861277] after pairA output = ff
[ 10.867923] before pairB output = 1e
[ 10.874746] after pairB output = 0
[ 10.881302] before pairC output = 1e
[ 10.888117] after pairC output = 0
[ 10.894682] before pairD output = 1b
[ 10.901500] after pairD output = fe
[ 10.905552] mt753x gsw@0: -------- gephy-calbration (port:2) --------
[ 10.928690] CALDLY = 40
[ 11.208743] GE R50 AnaCal Saturation!
[ 11.212881] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 11.494123] GE R50 AnaCal Saturation!
[ 11.498252] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 11.779437] GE R50 AnaCal Saturation!
[ 11.783566] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 12.065162] GE R50 AnaCal Saturation!
[ 12.069299] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 12.079519] GE 1e_174(0x8080), 1e_175(0x8080)
[ 12.150823] GE Tx offset AnaCal Done! (pair-0)(3)(0x22) 0x1e_172=0x2220
[ 12.190230] GE Tx offset AnaCal Done! (pair-1)(2)(0x21) 0x1e_172=0x2221
[ 12.237777] GE Tx offset AnaCal Done! (pair-2)(3)(0x22) 0x1e_173=0x2220
[ 12.269060] GE Tx offset AnaCal Done! (pair-3)(1)(0x1) 0x1e_173=0x2201
[ 12.448057] GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x4010)
[ 12.592726] GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0xd0d)
[ 12.682723] GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x131b)
[ 12.793064] GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1018)
[ 12.888408] PORT 2 RX_DC_OFFSET
[ 12.908683] before pairA output = f
[ 12.915417] after pairA output = ff
[ 12.922070] before pairB output = 1e
[ 12.928888] after pairB output = 2
[ 12.935453] before pairC output = d
[ 12.942187] after pairC output = ff
[ 12.948834] before pairD output = e
[ 12.955569] after pairD output = 0
[ 12.959538] mt753x gsw@0: -------- gephy-calbration (port:3) --------
[ 12.982678] CALDLY = 40
[ 13.262749] GE R50 AnaCal Saturation!
[ 13.266878] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 13.548540] GE R50 AnaCal Saturation!
[ 13.552678] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 13.834378] GE R50 AnaCal Saturation!
[ 13.838507] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 14.120105] GE R50 AnaCal Saturation!
[ 14.124234] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 14.134462] GE 1e_174(0x8080), 1e_175(0x8080)
[ 14.197635] GE Tx offset AnaCal Done! (pair-0)(2)(0x21) 0x1e_172=0x2120
[ 14.237046] GE Tx offset AnaCal Done! (pair-1)(2)(0x21) 0x1e_172=0x2121
[ 14.292733] GE Tx offset AnaCal Done! (pair-2)(4)(0x23) 0x1e_173=0x2320
[ 14.348415] GE Tx offset AnaCal Done! (pair-3)(4)(0x23) 0x1e_173=0x2323
[ 14.537647] GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x3c0f)
[ 14.651959] GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1111)
[ 14.701562] GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1921)
[ 14.791683] GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x131b)
[ 14.887035] PORT 3 RX_DC_OFFSET
[ 14.907313] before pairA output = c
[ 14.914047] after pairA output = 0
[ 14.920604] before pairB output = 1d
[ 14.927419] after pairB output = fe
[ 14.934074] before pairC output = e
[ 14.940802] after pairC output = ff
[ 14.947448] before pairD output = e
[ 14.954182] after pairD output = 1
[ 14.958144] mt753x gsw@0: -------- gephy-calbration (port:4) --------
[ 14.981286] CALDLY = 40
[ 15.261492] GE R50 AnaCal Saturation!
[ 15.265621] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 15.547350] GE R50 AnaCal Saturation!
[ 15.551487] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 15.833261] GE R50 AnaCal Saturation!
[ 15.837390] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 16.119038] GE R50 AnaCal Saturation!
[ 16.123166] GE R50 AnaCal Done! (32) (0x0)(0x80)
[ 16.133384] GE 1e_174(0x8080), 1e_175(0x8080)
[ 16.196544] GE Tx offset AnaCal Done! (pair-0)(2)(0x21) 0x1e_172=0x2120
[ 16.276632] GE Tx offset AnaCal Done! (pair-1)(7)(0x26) 0x1e_172=0x2126
[ 16.324180] GE Tx offset AnaCal Done! (pair-2)(3)(0x22) 0x1e_173=0x2220
[ 16.355462] GE Tx offset AnaCal Done! (pair-3)(1)(0x20) 0x1e_173=0x2220
[ 16.504227] GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x4c13)
[ 16.608396] GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1111)
[ 16.769292] GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0xc14)
[ 16.980793] GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x70f)
[ 17.076057] PORT 4 RX_DC_OFFSET
[ 17.096328] before pairA output = e
[ 17.103063] after pairA output = 0
[ 17.109620] before pairB output = f
[ 17.116344] after pairB output = 0
[ 17.122906] before pairC output = 1e
[ 17.129721] after pairC output = ff
[ 17.136367] before pairD output = d
[ 17.143102] after pairD output = 0
[ 17.150515] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[ 17.157268] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[ 17.164168] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 17.169577] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[ 17.178088] mt753x gsw@0: Port 1 Link is Up - 1Gbps/Full
[ 17.183665] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[ 17.193030] xhci-mtk 1a0c0000.usb: irq 127, io mem 0x1a0c0000
[ 17.199465] hub 1-0:1.0: USB hub found
[ 17.203345] hub 1-0:1.0: 2 ports detected
[ 17.207700] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 17.213103] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[ 17.220739] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[ 17.227241] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 17.235873] hub 2-0:1.0: USB hub found
[ 17.239758] hub 2-0:1.0: 1 port detected
[ 17.244159] 6 cmdlinepart partitions found on MTD device eMMC
[ 17.250092] Creating 6 MTD partitions on "eMMC":
[ 17.254851] 0x000000000000-0x0000000c0000 : "mbr"
[ 17.260147] 0x0000000c0000-0x000000140000 : "uboot"
[ 17.265542] 0x000000140000-0x0000001c0000 : "Config"
[ 17.271052] 0x0000001c0000-0x000000200000 : "Factory"
[ 17.276618] 0x000000200000-0x000020200000 : "Kernel"
[ 17.283251] 2 fit-fw partitions found on MTD device Kernel
[ 17.288908] 0x000000200000-0x0000004f0000 : "kernel"
[ 17.294416] 0x0000004e724c-0x000020200000 : "rootfs"
[ 17.299937] mtd: device 6 (rootfs) set to be root filesystem
[ 17.305776] 1 squashfs-split partitions found on MTD device rootfs
[ 17.312195] 0x0000031b0000-0x000020200000 : "rootfs_data"
[ 17.318140] 0x000020200000-0x0001a0200000 : "usrdata"
[ 17.323753] block2mtd: mtd0: [eMMC] erase_size = 64KiB [65536]
[ 17.329808] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 00:14:46 UTC (946685686)
[ 17.340960] squashfs: SQUASHFS error: unable to read id index table
[ 17.347567] List of all partitions:
[ 17.351211] b300 7634944 mmcblk0
[ 17.351213] driver: mmcblk
[ 17.358216] b301 256 mmcblk0p1 f6ff0fdd-1e96-4a94-ba9b-89e55b8ea4ed
[ 17.358218]
[ 17.367475] b302 512 mmcblk0p2 e34c411c-1fb5-47f3-a295-4aa8686eff6e
[ 17.367476]
[ 17.376725] b303 512 mmcblk0p3 8660b620-97ca-4c76-b55b-bd47b11a37d9
[ 17.376726]
[ 17.385973] b304 256 mmcblk0p4 c246f1d0-56ee-4fd8-859a-c92f8e636e79
[ 17.385974]
[ 17.395221] b305 524288 mmcblk0p5 fb7e66fe-12c6-4144-ac50-de42867d8871
[ 17.395223]
[ 17.404472] 1f00 768 mtdblock0
[ 17.404474] (driver?)
[ 17.411214] 1f01 512 mtdblock1
[ 17.411216] (driver?)
[ 17.417948] 1f02 512 mtdblock2
[ 17.417950] (driver?)
[ 17.424688] 1f03 256 mtdblock3
[ 17.424689] (driver?)
[ 17.431427] 1f04 524288 mtdblock4
[ 17.431429] (driver?)
[ 17.438161] 1f05 3008 mtdblock5
[ 17.438162] (driver?)
[ 17.444900] 1f06 521315 mtdblock6
[ 17.444902] (driver?)
[ 17.451638] 1f07 475456 mtdblock7
[ 17.451639] (driver?)
[ 17.458371] 1f08 6291456 mtdblock8
[ 17.458373] (driver?)
[ 17.465107] No filesystem could mount root, tried:
[ 17.465109] squashfs
[ 17.470136]
[ 17.474001] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,6)
[ 17.482611] SMP: stopping secondary CPUs
[ 17.486650] Kernel Offset: disabled
[ 17.490242] CPU features: 0x0,20002000
[ 17.494100] Memory Limit: none
[ 17.497244] Rebooting in 1 seconds..
I also try to upgrade from v0.52.3 to v0.53.2 with sysupgrade, also failed.
root@OpenMPTCProuter:~# sysupgrade -F /tmp/openmptcprouter-v0.53.2-r0\+11546-a74
095c68c-mediatek-mt7622-BPI-R64-initramfs-kernel.bin
Image metadata not found
Sysupgrade is not supported on your board yet.
Image check failed but --force given - will update anyway!
Saving config files...
Commencing upgrade. Closing all shell sessions.
killall: telnetd: no process killed
Sending TERM to remaining processes ... ubusd urngd sh sh sh sh ntpd sh adb adb dnsmasq vnstatd sh sleep sleep sh sleep sleep logd rpcd netifd rngd odhcpd crond uhttpd unbound
Sending KILL to remaining processes ...
Switching to ramdisk...
Performing system upgrade...
Could not open mtd device: firmware
Can't open device for writing!
sysupgrade aborted with ret[ 152.122889] reboot: Restarting system
@bourne_hlm How did you build openmptcprouter image?? I see that there is no official support for R64. Can you share what need to be modify there?
BTW I do have exactly same issue when I build latest OpenWRT (with kernel 5.4) and load into eMMC. I remember that I build it few months ago and load with exactly same steps and there was no issue. It was definitely 4.19 but do not know more details.
Ok I maneged to load latest Openwrt into R64 and start from eMMC.
Steps that I did:
- clone OpenWRT,
- change kernel to 4.19 in openwrt/target/linux/mediatek/makefile
- set target in make menuconfig 4 make defconfig (im not sure if that is needed)
- do kernel config as @bourne_hlm
"Device Drivers"-->"Memory Technology Device (MTD) support"-->"Command line partition table parsing"
"Device Drivers"-->"Memory Technology Device (MTD) support""Self-contained MTD device drivers"-->"MTD using block device"
"Device Drivers"-->"MMC/SD/SDIO card suport"->"MMC block device driver"
- add attached patch into openwrt/target/linux/mediatek/patches-4.19 1000-R64_OpenWRT_4_19_eMMC.patch (2.9 KB), it is modified patch @nagi fromhttp://forum.banana-pi.org/t/bpi-r64-mt7622-mac80211-wifi-driver/10246
- build and then use openwrt-mediatek-mt7622-bpi_bananapi-r64-squashfs-sysupgrade.bin with option 2 in u-boot.
I try to do the same without changing kernel to 4.19 and this patch 1000-R64_OpenWRT_5_4_eMMC.patch (1.9 KB) , but it do not mount rootfs and stuck on :
6 cmdlinepart partitions found on MTD device eMMC<\r> Creating 6 MTD partitions on “eMMC”:<\r> 0x000000000000-0x0000000c0000 : “preloader”<\r> 0x0000000c0000-0x000000140000 : “uboot”<\r> 0x000000140000-0x0000001c0000 : “uboot-env”<\r> 0x0000001c0000-0x000000200000 : “Factory”<\r> 0x000000200000-0x000004200000 : “firmware”<\r> 2 fit-fw partitions found on MTD device firmware<\r> 0x000000200000-0x0000004f0000 : “kernel”<\r> 0x0000004e71ec-0x000004200000 : “rootfs”<\r> mtd: device 6 (rootfs) set to be root filesystem<\r> 1 squashfs-split partitions found on MTD device rootfs<\r> 0x000000d50000-0x000004200000 : “rootfs_data”<\r> 0x000004200000-0x000084200000 : “usrdata”<\r> block2mtd: mtd0: [eMMC] erase_size = 64KiB [65536]<\r>
kernel is not hanging as I can see logs when I disconnect ethernet cable. It just not going forward. I try to trace where it stuck and as far as I go is to
int vfs_get_tree(struct fs_context *fc)
in linux/fs/super.c whitch is call by
static int do_new_mount(struct path *path, const char *fstype, int sb_flags, int mnt_flags, const char *name, void *data)
from linux/fs/namespace.c
The omr 0.53 have problem to build into R64, but 0.54.7 can build into R64. It’s the same steps in this post.
But in OMR there are no config files for R64 only for R2, do I have to manually create them?
I am too try compile OpenWrt by yourse instruction but I get error during compilation:
Applying /home/osboxes/openwrt/target/linux/mediatek/patches-4.19/1000-R64_OpenWRT_4_19_eMMC.patch using plaintext:
patching file arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dts
Hunk #1 FAILED at 16.
1 out of 3 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dts.rej
patching file arch/arm64/boot/dts/mediatek/mt7622-lynx-rfb1.dts
Hunk #1 succeeded at 549 with fuzz 2.
patching file arch/arm64/boot/dts/mediatek/mt7622-rfb1.dts
Patch failed! Please fix /home/osboxes/openwrt/target/linux/mediatek/patches-4.19/1000-R64_OpenWRT_4_19_eMMC.patch!
make[4]: *** [Makefile:28: /home/osboxes/openwrt/build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7622/linux-4.19.108/.prepared_11e8f7ae2a19576aff9cc35fd671fae0] Error 1
make[4]: Leaving directory '/home/osboxes/openwrt/target/linux/mediatek'
make[3]: *** [Makefile:13: compile] Error 2
make[3]: Leaving directory '/home/osboxes/openwrt/target/linux'
time: target/linux/compile#7.71#5.48#11.62
make[2]: *** [target/Makefile:25: target/linux/compile] Error 2
make[2]: Leaving directory '/home/osboxes/openwrt'
make[1]: *** [target/Makefile:18: /home/osboxes/openwrt/staging_dir/target-aarch64_cortex-a53_musl/stamp/.target_compile] Error 2
make[1]: Leaving directory '/home/osboxes/openwrt'
make: *** [/home/osboxes/openwrt/include/toplevel.mk:220: world] Error 2
I am patching files manualy (in file target/linux/mediatek/files-4.19/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dts) and its works.
it seems kernel 5.4 doesn’t have this option
Try make kernel_menuconfig,search for this option (/) and look at depencies…i guess there is one not set maybe it is renamed:
https://cateee.net/lkddb/web-lkddb/MTD_CMDLINE_PARTS.html
says 5.4+
looks like it is moved
- <5.4 found in
drivers/mtd/Kconfig - 5.4+ found in
drivers/mtd/parsers/Kconfig
drivers/mtd/parsers is always included
if CONFIG_MTD is set
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/Makefile?h=v5.4.32#n83
cmdline_parts depends only on mtd
looks similar on 4.19:
