Can you execute chroot as root on your commandline? If not you have to install chroot
Hi, thanks for the fast reply. chroot as well as arch-chroot are installed. Sudo chroot --help also provides the corresponding output. Manually mounting and executing chroot on the written SD card leads to the same error.
Maybe you miss qemu binary for target arch (aarch64 in case of r64)
sudo apt-get install qemu-user-static
And then copy matching binary to chroot
sudo cp /usr/bin/qemu-aarch64-static $targetdir/usr/bin/
Iāve installed the aur version 6.1.0-2 of qemu-user-static on the host. After copying the file to the corresponding folder on the SD card, the problem unfortunately persists⦠Does a service still have to be activated here?
Have you mounted the filesystem with the chroot-fs with exec rights? you can try remounting it with and try chroot again
sudo mount -o remount,exec /media/data_ext #mounting point where your chroot-target folder is located
Have you tried running
./build.sh -a
It installs the packages it needsā¦
But I have not tested an arch-linux host other then the R64 running on arch-linux. This means that the following 2 lines have not been tested:
$sudo pacman -Syu --needed --noconfirm debootstrap aarch64-linux-gnu-gcc
aurinstall qemu-user-static
Remove the rootfs-arch.tar.bz and try again.
Just run
./build.sh -r
To try building root only without creating a backup .tar.bz
Since pacman is also not found then maybe
https://raw.githubusercontent.com/tokland/arch-bootstrap/master/arch-bootstrap.sh
Is not executed correctly⦠It should install pacman on the chroot directory.
Edit: I think I see the qemu-user-static problem. I use my script aurinstall to get qemu-user-static installed. It gets installed on the rootfs by the script. So in my test on running from this rootfs I can directly use aurinstall. You need to install qemu-user-static manually.
Thank you very much for the hints. Unfortunately I was a bit too careless with the chroot and somehow managed to break my entire system. Yesterday I was not successful with the rescue via a live USB stick unfortunately. Tonight Iāll try it again. If that works, Iāll test the installation again and try out your ideas.
Iāve changed the script a little, when running on Arch-Linux, but not on the BPI R64, the script uses yay to get aarch64-linux-gnu-gcc and qemu-user-static installed.
Hope this helps.
Iām installing arch-linux on a laptop one of these days and will also try it out and seeā¦
After I was finally able to persuade my PC to boot again, I tested out the new script again. In fact, the BPI is now also making quite a bit of progress when booting. However, I now get an error message āKernel panic - not syncing: No working init found. ā¦ā.
The problem with chroot is also still there. I tried out qemu-aarch64-static path_to_sdcard/usr/bin/pacman as described in the arch-wiki but get the error message qemu-aarch64-static: Could not open ā/lib/ld-linux-aarch64.so.1ā: No such file or directoryā¦
mostly this error comes up if rootfs is not correctly mounted or there is no /sbin/init
do you have any warning/error before that rootfs cannot be mounted?
As a work around until I fix the script, you could use:
https://github.com/ericwoud/buildR64ubuntu/releases/download/v1.0-rc2/my-bpir64-sdmmc.img.xz
Write it to your sd card. This has arch linux rootfs on it.
Then you can still build an altered boot / kernel with:
./build.sh -b
or
./build.sh -k
Latest commit can now build Arch Linux from Arch Linux using qemu.
It installs package qemu-user-static-bin, which might be conflicting with the qemu that you tried before, so please remove that one first.
Install all neccesairy packages with:
./build.sh -a
If all packages are installed correctly, the rest of the script now should run fine.
Thank you for the support. I know the problem is mostly in front of the computer⦠But I just canāt get it to work. When booting, I get a kernel panic message again. In addition, some letters seem to be missing or mixed up on the serial port with Minicom. I no longer find any errors in the log file (build.log), everything seems to have worked now. /sbin/init is also present.
Hmz I checked the running of the script, not yet the resulting image.
Please use the prebuild image and I look in to it next week
It may have something to do with binfmt. It was installed together with qemu
I think so tooā¦binfmt is used to determine the ARCH specific binary format to call the right ldconfig/qemu-user-static.
For me it looks like related to the qemu problems i face with aarch64 in ubuntuā¦only in my case i get segfault when creating the rootfs (second stage while calling ldconfig)
I need to add some more to the script, I think I know now where to solve the last issue⦠Forgot something⦠Should be ok in a couple of daysā¦
Latest commit should be the fix for the last issueā¦
The build process completes ok, but I do not have time to check the result until somewhere next week. You are welcome to try it out, so I pushed the commit for you to try.
Iām also trying to use qemu to emulate the BPI-R64 MT7622. I canāt figure out what the appropriate machine spec is when I do qemu-system-aarch64 -machine help no machine I see listed seems appropriate. Iām running the qemu thatās packaged with Fedora 35, which is some version of qemu 6.1.0.
There are too much arm/arm64 devices/soc to define a machine for each. I think you can emulate a basic arm64 device but imho you cannot test soc specific functions
You could try something like this:
qemu-system-aarch64 -nographic -machine virt,gic-version=max
Here in the script I only use qemu for building the rootfs. It is indeed very generic qemu.
