I have OpenWrt version: OpenWrt SNAPSHOT, r18394-962c585580 Installed on my BPI-R64
And the Ethernet ports seem to be capped at 100 Mbps even though they are supposed to be Gig Ethernet ports.
I can measure the internet speed upstream from the BPI-R64 router and the speed is ~800 Mbps, plugging a computer directly into any of the BPI-R64’s Ethernet ports results in speeds of ~80 Mbps.
Is there some firmware setting that has to be updated for the Ethernet ports to be capable of Gig Ethernet speed?
Hi Frank, It looks like the OpenWrt imgbuilder is for the BPI-R2. Will that also work on the BPI-R64? The only OpenWrt release for the BPI-R64 is a Snapshot and not an actual release. I would rather be on an actual release, so if I can use it I will probably try and switch to it.
The results from ethtool seems to suggest that the port are set for 1000Mb/s, but that is not the speed I am getting.
ethtool results:
root@OpenWrt:~# ethtool eth0
Settings for eth0:
Supported ports: [ MII ]
Link partner advertised link modes: 2500baseX/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: No
Speed: 2500Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Link detected: yes
root@OpenWrt:~# ethtool lan3
Settings for lan3:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 3
Transceiver: external
Supports Wake-on: d
Wake-on: d
Link detected: yes
please post your out put in code-tags (select the text and press the <> button).
with ethtool i meant the statistics
ethtool -S interface
to see if there are CRC errors, dropped packets and such
and the other thread is mention rps, cpu affinity and hwnat. without them much traffic is done by (single) CPU and this reduces throughput. These are independ of SOC (at least r2 and r64 are using it). you can look on cpu load and interrupts to see if this is the bottleneck.
In your case 80Mbit/s are really less throughput, i guess more a HW problem or maybe the temperature throtteling again…not sure this is fixed on openwrt
