I added UTS_NS, BRIDGE_NETFILTER, EXT4_FS_POSIX_ACL, EXT4_FS_SECURITY, SECURITY_APPARMOR and fuse
I don’t know why, but look at this. I can’t change scaling_max_freq to anything other than 30MHz.
root@bpi-r64:/sys/devices/system/cpu/cpu1# cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to [email protected], please.
analyzing CPU 0:
  driver: mtk-cpufreq
  CPUs which run at the same hardware frequency: 0 1
  CPUs which need to have their frequency coordinated by software: 0 1
  maximum transition latency: 4294.55 ms.
  hardware limits: 30.0 MHz - 1.35 GHz
  available frequency steps: 30.0 MHz, 438 MHz, 600 MHz, 813 MHz, 1.03 GHz, 1.14 GHz, 1.26 GHz, 1.35 GHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  current policy: frequency should be within 30.0 MHz and 30.0 MHz.
                  The governor "ondemand" may decide which speed to use
                  within this range.
  current CPU frequency is 120 MHz (asserted by call to hardware).
  cpufreq stats: 30.0 MHz:99.68%, 438 MHz:0.10%, 600 MHz:0.08%, 813 MHz:0.06%, 1.03 GHz:0.02%, 1.14 GHz:0.02%, 1.26 GHz:0.04%, 1.35 GHz:0.00%  (7)
analyzing CPU 1:
  driver: mtk-cpufreq
                  within this range.
