[BPI-R64] Cannot change GPIO90 state
I am trying get Openwrt in BPI-R64 working with Quectel EC25 but I cannot change the GPIO90 state, it is always asm_sel in lo. echo “499” > /sys/class/gpio/export says ”ash: write error: Resource busy”. I have tested almost all versions of Openwrt I could find. Is there anything I could still do?
Gpio 90 is reserved in dts for switching between pcie and sata. So you have to change it there (or via dt overlay).
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dts#n311
See comment above the node
Maybe it is not blocked if the gpio-hog driver is not loaded (if used as module).
