BPI-R4Pro x8 + SSD
Hi everyone! I’ve run into an issue connecting an SSD to the BPI-R4Pro x8. It is crucial for me to know exactly which SSD models are 100% compatible. The problem is as follows: the SSD I installed (using the MAP1202 controller, DRAM-less, revision 01) was initially detected, formatted, and partitioned correctly, but it stopped working after a reboot; however, it sometimes reappears in the system if I move it to a different slot. Does anyone have experience with this device? Which SSDs work flawlessly for you? Thanks in advance for your answers!
https://github.com/frank-w/BPI-Router-Linux/wiki/BPI%E2%80%90Router%E2%80%90Linux-Wiki
