BPI-R4 with 2 mt7612E
Hello, I would like to install 2 MT7612E wifi cards to have 2 separate wifi networks, is this possible? Thank you.
Should work but i would use a mt7615/mt7915 as there you need only 1 card due to dbdc mode
thanks for the answer, I currently have a mt7615 this model: https://fr.aliexpress.com/item/4000260974924.html but I can’t have 2 networks a 2.4g and 5g on the same radio or I haven’t found how to do it.
some older boards needed to set a sysfs-value to have 2 phy, see here
https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#mt7615
to understand well I need to have 2 cards or 1?. thanks
so it works now but after restarting I lost the sys configuration.
Afair there were some non-dbdc variant…if you have a dbdc you need only one card
ok thanks a lot for your help. the power seems low 3 dBm power in luci, i see some people with 27dBm
