In menuconfig I found only kmod-mt7922-firmware and in /lib/firmware/mediatek/
But my lsmod output is too short
root@OpenWrt:~# opkg list | grep firmware
eip197-mini-firmware - 20240513-r1
kmod-mt7922-firmware - 6.6.30.2024.05.17~513c131c-r1
mt7922bt-firmware - 20240513-r1
root@OpenWrt:~# ls /lib/firmware/mediatek/
BT_RAM_CODE_MT7922_1_1_hdr.bin WIFI_RAM_CODE_MT7922_1.bin
WIFI_MT7922_patch_mcu_1_1_hdr.bin
root@OpenWrt:~# lsmod | grep mt
xhci_mtk_hcd 20480 0
xhci_hcd 131072 3 xhci_mtk_hcd,xhci_pci,xhci_plat_hcd
usbcore 192512 4 xhci_hcd,xhci_mtk_hcd,xhci_pci,xhci_plat_hcd
root@OpenWrt:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.6.30 (user@b28f5fbfad8b) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r26450-6510eb3b5d) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Wed May 29 09:19:08 2024
[ 0.000000] Machine model: Bananapi BPI-R4
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s34536 r8192 d31000 u73728
[ 0.000000] pcpu-alloc: s34536 r8192 d31000 u73728 alloc=18*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7b4000-0x00000000fe7b4000] (64MB)
[ 0.000000] Memory: 4034432K/4194304K available (8512K kernel code, 894K rwdata, 2504K rodata, 384K init, 287K bss, 159872K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000058] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000065] pid_max: default: 32768 minimum: 301
[ 0.002166] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002180] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003671] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.003950] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.004028] rcu: Hierarchical SRCU implementation.
[ 0.004031] rcu: Max phase no-delay instances is 1000.
[ 0.004309] smp: Bringing up secondary CPUs ...
[ 0.004523] Detected VIPT I-cache on CPU1
[ 0.004555] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.004575] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.004822] Detected VIPT I-cache on CPU2
[ 0.004842] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.004851] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.005081] Detected VIPT I-cache on CPU3
[ 0.005101] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.005110] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.005136] smp: Brought up 1 node, 4 CPUs
[ 0.005140] SMP: Total of 4 processors activated.
[ 0.005142] CPU features: detected: 32-bit EL0 Support
[ 0.005144] CPU features: detected: CRC32 instructions
[ 0.005162] spectre-bhb mitigation disabled by compile time option
[ 0.005176] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005179] CPU: All CPU(s) started at EL2
[ 0.005181] alternatives: applying system-wide alternatives
[ 0.008278] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008289] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.009244] pinctrl core: initialized pinctrl subsystem
[ 0.009935] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.010224] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.010325] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.010419] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.010679] thermal_sys: Registered thermal governor 'fair_share'
[ 0.010681] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.010683] thermal_sys: Registered thermal governor 'step_wise'
[ 0.010685] thermal_sys: Registered thermal governor 'user_space'
[ 0.010723] ASID allocator initialised with 65536 entries
[ 0.011441] pstore: Using crash dump compression: deflate
[ 0.011446] printk: console [ramoops-1] enabled
[ 0.011666] pstore: Registered ramoops as persistent store backend
[ 0.011671] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.018369] Modules: 29584 pages in range for non-PLT usage
[ 0.018377] Modules: 521104 pages in range for PLT usage
[ 0.019135] cryptd: max_cpu_qlen set to 1000
[ 0.020664] SCSI subsystem initialized
[ 0.020724] libata version 3.00 loaded.
[ 0.021570] clocksource: Switched to clocksource arch_sys_counter
[ 0.023294] NET: Registered PF_INET protocol family
[ 0.023423] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.025742] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.025765] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.025774] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.025881] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.026291] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.026382] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.026441] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.026661] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.026706] PCI: CLS 0 bytes, default 64
[ 0.027574] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.031210] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.031217] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049535] jitterentropy: Initialization failed with host not compliant with requirements: 9
[ 0.050496] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.051062] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.051083] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.051095] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.051107] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.051197] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.051207] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.051217] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.051226] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.051243] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.051252] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.051314] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.051323] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.051331] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.051340] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.051356] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.051363] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.051433] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.051443] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.051451] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.051460] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.051474] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.051481] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.055933] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.056690] printk: console [ttyS0] disabled
[ 0.076954] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.076991] printk: console [ttyS0] enabled
[ 0.998936] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[ 1.028820] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[ 1.040735] loop: module loaded
[ 1.045237] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.050552] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 1.058797] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.065240] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.072123] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.079125] Creating 2 MTD partitions on "spi0.0":
[ 1.083918] 0x000000000000-0x000000200000 : "bl2"
[ 1.090030] 0x000000200000-0x000008000000 : "ubi"
[ 1.168248] ubi0: default fastmap pool size: 50
[ 1.172784] ubi0: default fastmap WL pool size: 25
[ 1.177564] ubi0: attaching mtd1
[ 1.994923] ubi0: scanning is finished
[ 2.008274] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 2.013765] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.020628] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.027405] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.034355] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 2.040436] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 2.047646] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1697192243
[ 2.056766] ubi0: available PEBs: 105, total reserved PEBs: 903, PEBs reserved for bad PEB handling: 20
[ 2.066151] ubi0: background thread "ubi_bgt0d" started, PID 239
[ 2.073774] block ubiblock0_1: created from ubi0:1(rootfs)
[ 2.079256] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
[ 2.212983] i2c_dev: i2c /dev entries driver
[ 2.220239] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.228322] mtk-cpufreq mtk-cpufreq: failed to initialize dvfs info for cpu0
[ 2.235852] mtk-msdc 11230000.mmc: Got CD GPIO
[ 2.235969] NET: Registered PF_INET6 protocol family
[ 2.245728] Segment Routing with IPv6
[ 2.249398] In-situ OAM (IOAM) with IPv6
[ 2.253347] NET: Registered PF_PACKET protocol family
[ 2.258439] 8021q: 802.1Q VLAN Support v1.8
[ 2.275019] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[ 2.282209] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.289527] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.295817] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.304260] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.335797] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.345774] mmc0: new high speed SDHC card at address 0001
[ 2.351901] mmcblk0: mmc0:0001 SD16G 14.6 GiB
[ 2.361260] Alternate GPT is invalid, using primary GPT.
[ 2.367243] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.661593] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.670399] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 2.677439] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.684756] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.691019] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.699458] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 3.041580] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.050362] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.057225] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.064535] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.070795] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.079231] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.421585] mtk-pcie-gen3 11300000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.430364] mtk-pcie-gen3: probe of 11300000.pcie failed with error -110
[ 3.437224] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 3.444532] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 3.450791] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 3.459223] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 3.704239] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 3.715620] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 3.727085] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 3.738548] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 3.750012] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 3.761565] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 3.773113] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 3.784896] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 3.791501] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.796983] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 3.806799] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 3.813663] pci_bus 0001:00: scanning bus
[ 3.817683] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 3.823696] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 3.830533] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.836619] pci 0001:00:00.0: PME# disabled
[ 3.841935] pci_bus 0001:00: fixups for bus
[ 3.846109] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 3.852801] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.860797] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 3.867536] pci_bus 0001:01: scanning bus
[ 3.871559] pci 0001:01:00.0: [14c3:0616] type 00 class 0x028000
[ 3.877580] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 3.884807] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[ 3.891702] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 3.897787] pci 0001:01:00.0: PME# disabled
[ 3.931609] pci_bus 0001:01: fixups for bus
[ 3.935782] pci_bus 0001:01: bus scan returning with max=01
[ 3.941342] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.947954] pci_bus 0001:00: bus scan returning with max=01
[ 3.953529] pci 0001:00:00.0: BAR 8: assigned [mem 0x38200000-0x382fffff]
[ 3.960307] pci 0001:00:00.0: BAR 9: assigned [mem 0x38300000-0x383fffff 64bit pref]
[ 3.968040] pci 0001:00:00.0: BAR 0: assigned [mem 0x38400000-0x38407fff 64bit]
[ 3.975346] pci 0001:01:00.0: BAR 0: assigned [mem 0x38300000-0x383fffff 64bit pref]
[ 3.983090] pci 0001:01:00.0: BAR 2: assigned [mem 0x38200000-0x38207fff 64bit]
[ 3.990397] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.995356] pci 0001:00:00.0: bridge window [mem 0x38200000-0x382fffff]
[ 4.002134] pci 0001:00:00.0: bridge window [mem 0x38300000-0x383fffff 64bit pref]
[ 4.009873] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 4.018317] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 4.026824] pcieport 0001:00:00.0: assign IRQ: got 112
[ 4.031961] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 4.038051] pcieport 0001:00:00.0: enabling bus mastering
[ 4.043818] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.052257] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 4.060683] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 4.069110] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 4.077537] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 4.085963] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 4.094390] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 4.102815] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 4.111240] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 4.119666] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 4.128091] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 4.136604] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 4.145117] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 4.153633] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 4.162146] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 4.170656] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 4.179171] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 4.187771] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 4.196371] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 4.204971] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 4.213572] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 4.222172] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 4.230770] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 4.239370] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 4.247969] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 4.256569] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 4.265170] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 4.273769] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 4.282369] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 4.290966] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 4.299566] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 4.308166] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 4.317188] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.325687] pcieport 0001:00:00.0: PME: Signaling with IRQ 113
[ 4.331640] pcieport 0001:00:00.0: AER: enabled with IRQ 113
[ 4.337333] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[ 4.343274] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[ 4.349183] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[ 4.355094] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[ 4.361002] pcieport 0001:00:00.0: save config 0x10: 0x38400004
[ 4.366912] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[ 4.372823] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[ 4.378730] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[ 4.384643] pcieport 0001:00:00.0: save config 0x20: 0x38203820
[ 4.390551] pcieport 0001:00:00.0: save config 0x24: 0x38313831
[ 4.396461] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[ 4.402371] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[ 4.408279] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[ 4.414188] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[ 4.420095] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[ 4.426005] pcieport 0001:00:00.0: save config 0x3c: 0x00020170
[ 4.432806] FIT: Detected U-Boot 2024.01-OpenWrt-r26450-6510eb3b5d
[ 4.438980] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 4.448027] FIT: kernel sub-image 0x00001000..0x00561783 "kernel-1" (ARM64 OpenWrt Linux-6.6.30)
[ 4.457763] FIT: flat_dt sub-image 0x00562000..0x0056c921 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[ 4.468974] FIT: flat_dt sub-image 0x0056d000..0x0056d611 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 4.485304] FIT: flat_dt sub-image 0x0056e000..0x0056e11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 4.501460] FIT: flat_dt sub-image 0x0056f000..0x0056f5c9 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 4.517445] FIT: flat_dt sub-image 0x00570000..0x005708eb "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 4.535160] FIT: filesystem sub-image 0x00571000..0x01088fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[ 4.546007] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 4.553758] block mmcblk0p7: mapped remaing space as /dev/fitrw
[ 4.683088] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 4.693466] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082600000, irq 103
[ 4.703164] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082600000, irq 103
[ 4.712822] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082600000, irq 103
[ 4.804365] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 4.811874] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 4.836029] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=115)
[ 4.871327] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=116)
[ 4.906610] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=117)
[ 4.941883] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=118)
[ 4.952867] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 4.959576] DSA: tree 0 setup
[ 4.963150] UBI: auto-attach mtd1
[ 4.966458] ubi: mtd1 is already attached to ubi0
[ 4.971151] UBI error: cannot attach mtd1
[ 4.975224] clk: Disabling unused clocks
[ 4.984457] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 4.991679] Freeing unused kernel memory: 384K
[ 4.996157] Run /sbin/init as init process
[ 5.000242] with arguments:
[ 5.003203] /sbin/init
[ 5.005899] with environment:
[ 5.009028] HOME=/
[ 5.011376] TERM=linux
[ 5.130591] init: Console is alive
[ 5.134097] init: - watchdog -
[ 5.370541] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.387607] usbcore: registered new interface driver usbfs
[ 5.393164] usbcore: registered new interface driver hub
[ 5.398495] usbcore: registered new device driver usb
[ 5.404136] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 5.413973] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 5.421357] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 5.429305] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.434538] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 5.444973] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 5.454208] xhci-mtk 11200000.usb: irq 119, io mem 0x11200000
[ 5.460002] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.465224] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 5.472612] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 5.479951] hub 1-0:1.0: USB hub found
[ 5.483724] hub 1-0:1.0: 1 port detected
[ 5.487825] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.496160] hub 2-0:1.0: USB hub found
[ 5.499914] hub 2-0:1.0: 1 port detected
[ 5.506163] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.516165] init: - preinit -
[ 5.725517] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 5.733677] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 5.782575] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 5.891641] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 5.924508] hub 2-1:1.0: USB hub found
[ 5.928416] hub 2-1:1.0: 4 ports detected
[ 6.071575] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 6.253885] hub 1-1:1.0: USB hub found
[ 6.257765] hub 1-1:1.0: 5 ports detected
[ 7.001579] usb 1-1.2: new high-speed USB device number 3 using xhci-mtk
[ 7.081576] random: crng init done
[ 7.281572] usb 1-1.5: new high-speed USB device number 4 using xhci-mtk
[ 8.167017] F2FS-fs (fitrw): Disable nat_bits due to incorrect cp_ver (3784384522500363945, 10237275604284003999)
[ 8.181088] F2FS-fs (fitrw): Mounted with checkpoint version = 351ed6a9
[ 8.189631] mount_root: switching to f2fs overlay
[ 8.196236] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 8.208169] urandom-seed: Seeding with /etc/urandom.seed
[ 8.245712] procd: - early -
[ 8.248634] procd: - watchdog -
[ 8.783618] procd: - watchdog -
[ 8.792033] procd: - ubus -
[ 8.945580] procd: - init -
[ 9.118821] kmodloader: loading kernel modules from /etc/modules.d/*
[ 9.136559] pca954x 1-0070: supply vdd not found, using dummy regulator
[ 9.143789] i2c i2c-1: Added multiplexed i2c bus 2
[ 9.148649] i2c i2c-1: Added multiplexed i2c bus 3
[ 9.153518] i2c i2c-1: Added multiplexed i2c bus 4
[ 9.158365] i2c i2c-1: Added multiplexed i2c bus 5
[ 9.163159] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[ 9.173346] crypto-safexcel 15600000.crypto: can't request region for resource [mem 0x15600000-0x1577ffff]
[ 9.183017] crypto-safexcel 15600000.crypto: failed to get resource
[ 9.189272] crypto-safexcel: probe of 15600000.crypto failed with error -16
[ 9.199191] at24 2-0050: supply vcc not found, using dummy regulator
[ 9.218491] urngd: v1.0.2 started.
[ 9.233492] at24 2-0057: supply vcc not found, using dummy regulator
[ 9.240402] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 9.250594] sfp sfp1: Host maximum power 3.0W
[ 9.255483] sfp sfp2: Host maximum power 3.0W
[ 9.270984] PPP generic driver version 2.4.2
[ 9.275848] NET: Registered PF_PPPOX protocol family
[ 9.282141] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 10.751709] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 10.763674] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 10.771843] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 10.775437] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 10.788514] br-lan: port 1(lan1) entered blocking state
[ 10.793803] br-lan: port 1(lan1) entered disabled state
[ 10.799055] mt7530-mmio 15020000.switch lan1: entered allmulticast mode
[ 10.805697] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[ 10.812712] mt7530-mmio 15020000.switch lan1: entered promiscuous mode
[ 10.824052] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 10.832580] br-lan: port 2(lan2) entered blocking state
[ 10.837819] br-lan: port 2(lan2) entered disabled state
[ 10.843145] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[ 10.849979] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[ 10.859716] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 10.867813] br-lan: port 3(lan3) entered blocking state
[ 10.873071] br-lan: port 3(lan3) entered disabled state
[ 10.878314] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[ 10.885165] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[ 10.893328] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[ 10.925536] br-lan: port 4(eth1) entered blocking state
[ 10.930775] br-lan: port 4(eth1) entered disabled state
[ 10.936051] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[ 10.942995] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[ 10.952454] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 10.961119] br-wan: port 1(wan) entered blocking state
[ 10.966312] br-wan: port 1(wan) entered disabled state
[ 10.971474] mt7530-mmio 15020000.switch wan: entered allmulticast mode
[ 10.978238] mt7530-mmio 15020000.switch wan: entered promiscuous mode
[ 10.987305] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
[ 11.020055] br-wan: port 2(eth2) entered blocking state
[ 11.025317] br-wan: port 2(eth2) entered disabled state
[ 11.030566] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[ 11.037527] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[ 13.976914] mt7530-mmio 15020000.switch lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.985593] br-lan: port 2(lan2) entered blocking state
[ 13.990811] br-lan: port 2(lan2) entered forwarding state
